[petsc-users] questions regarding simple petsc matrix vector operation
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Apr 25 00:34:55 CDT 2019
I ran your problem fine on one process. no errors.
Suggest you run under valgrind on your system: https://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind or if that is not useful
Run in the debugger with the option -start_in_debugger noxterm
Good luck,
Barry
> On Apr 24, 2019, at 10:36 PM, Zhang, Junchao via petsc-users <petsc-users at mcs.anl.gov> wrote:
> How many MPI ranks do you use? The following line is suspicious. I guess you do not want a vector of global length 1.
> 66 VecSetSizes(b,PETSC_DECIDE,1);
> --Junchao Zhang
> On Wed, Apr 24, 2019 at 4:14 PM Karl Lin via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Hi, there
> I have been trying to get a simple program run with the following code:
> 12 int main(int argc,char **args)
> 13 {
> 14 PetscErrorCode ierr;
> 15 Mat A;
> 16 Mat AT;
> 17 Mat N;
> 18 char name[1024];
> 19 char vname[1024];
> 20 char pass[1024];
> 21 PetscBool flg;
> 22 Vec b,x,u,Ab,Au;
> 23 PetscViewer viewer; /* viewer */
> 24 PetscMPIInt rank,size;
> 25
> 26 KSP QRsolver;
> 27 PC pc;
> 28 PetscInt its;
> 29 PetscReal norm;
> 30
> 31 PetscInt n1, n2, n3, np1, np2, np3, p, jj;
> 32
> 33 PetscInt *cols, *dnz, *onz;
> 34 PetscScalar *vals;
> 35
> 36 ierr = PetscInitialize(&argc,&args,0,help);if (ierr) return ierr;
> 37
> 38 ierr = MPI_Comm_size(PETSC_COMM_WORLD,&size);CHKERRQ(ierr);
> 39 ierr = MPI_Comm_rank(PETSC_COMM_WORLD,&rank);CHKERRQ(ierr);
> 40
> 41 PetscMalloc1(1, &dnz);
> 42 PetscMalloc1(1, &onz);
> 43
> 44 dnz[0]=2;
> 45 onz[0]=1;
> 46
> 47 MatCreateMPIAIJMKL(PETSC_COMM_WORLD, 1, 2, 1, 2, 2, dnz, 2, onz, &A); CHKERRQ(ierr);
> 48
> 49 PetscMalloc1(2, &cols);
> 50 PetscMalloc1(2, &vals);
> 51
> 52 jj = rank;
> 53 cols[0]=0; cols[1]=1;
> 54 vals[0]=1.0;vals[1]=1.0;
> 55
> 56 MatSetValues(A, 1, &jj, 2, cols, vals, INSERT_VALUES);
> 57
> 58 MatAssemblyBegin(A, MAT_FINAL_ASSEMBLY);
> 59 MatAssemblyEnd(A, MAT_FINAL_ASSEMBLY);
> 60
> 61 VecCreate(PETSC_COMM_WORLD,&x);
> 62 VecSetSizes(x,PETSC_DECIDE,2);
> 63 VecSetFromOptions(x);
> 64
> 65 VecCreate(PETSC_COMM_WORLD,&b);
> 67 VecSetFromOptions(b);
> 68
> 69 VecCreate(PETSC_COMM_WORLD,&u);
> 70 VecSetSizes(u,PETSC_DECIDE,1);
> 71 VecSetFromOptions(u);
> 72
> 73 VecSet(b, 2.0);
> 74 VecSet(u, 0.0);
> 75 VecSet(x, 0.0);
> 76
> 77 MatMult(A, x, u);
> 78
> 79 VecView(x, PETSC_VIEWER_STDOUT_WORLD);
> 80 VecView(b, PETSC_VIEWER_STDOUT_WORLD);
> 81 VecView(u, PETSC_VIEWER_STDOUT_WORLD);
> 82
> 83 VecAXPY(u,-1.0,b);
> However, it always crashes at line 83 even with single process saying:
> [0]PETSC ERROR: ------------------------------------------------------------------------
> [0]PETSC ERROR: Caught signal number 11 SEGV: Segmentation Violation, probably memory access out of range
> [0]PETSC ERROR: Try option -start_in_debugger or -on_error_attach_debugger
> [0]PETSC ERROR: or see http://www.mcs.anl.gov/petsc/documentation/faq.html#valgrind
> [0]PETSC ERROR: or try http://valgrind.org on GNU/linux and Apple Mac OS X to find memory corruption errors
> [0]PETSC ERROR: configure using --with-debugging=yes, recompile, link, and run
> [0]PETSC ERROR: to get more information on the crash.
> [0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
> [0]PETSC ERROR: Signal received
> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
> [0]PETSC ERROR: Petsc Release Version 3.10.4, Feb, 26, 2019
> I can't figure out why this would happen. The printout from VecView shows every vec value is correct. I will greatly appreciate any tips.
> Regards,
> Karl
