[petsc-users] Question on KSPSetReusePreconditioner
Thu Apr 18 14:10:46 CDT 2019
On Thu, Apr 18, 2019 at 2:46 PM Yuyun Yang <yyang85 at stanford.edu> wrote:
> Let’s say I’m using HYPRE’s boomeramg preconditioner. Could we say
> anything about convergence/pc construction time if the matrix changes
> significantly from one solve to the next vs. slightly changes?
Hypre does not store anything (I believe), so it does not matter at all.
     Matt
> Thanks,
> Yuyun
> *From:* Matthew Knepley <knepley at gmail.com>
> *Sent:* Thursday, April 18, 2019 9:32 AM
> *To:* Yuyun Yang <yyang85 at stanford.edu>
> *Cc:* petsc-users at mcs.anl.gov
> *Subject:* Re: [petsc-users] Question on KSPSetReusePreconditioner
> On Thu, Apr 18, 2019 at 11:44 AM Yuyun Yang via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
> Hello team,
> I have a question on when I should be setting KSPSetReusePreconditioner to
> PETSC_TRUE or PETSC_FALSE. It made a pretty big difference in the solutions
> I get when I ran my code testing both settings, so is recalculating the
> preconditioner better since it will make the convergence faster and the
> solution more accurate? On the other hand, if the operator is updated every
> time step (but same nonzero pattern), will reconstructing the pc become
> time-consuming?
> We cannot say anything since it (at least) depends on a) how much your
> matrix changes from one solve to the next, and b)  what preconditioner you
> are reusing.
>   Thanks,
>     Matt
> Thank you!
> Yuyun
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190418/1ae5f5b3/attachment.html>
