[petsc-users] Question on KSPSetReusePreconditioner
Yuyun Yang yyang85 at stanford.edu
Thu Apr 18 13:46:39 CDT 2019
Let’s say I’m using HYPRE’s boomeramg preconditioner. Could we say anything about convergence/pc construction time if the matrix changes significantly from one solve to the next vs. slightly changes?
Yuyun
Sent: Thursday, April 18, 2019 9:32 AM
To: Yuyun Yang <yyang85 at stanford.edu>
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] Question on KSPSetReusePreconditioner
On Thu, Apr 18, 2019 at 11:44 AM Yuyun Yang via petsc-users <petsc-users at mcs.anl.gov<mailto:petsc-users at mcs.anl.gov>> wrote:
Hello team,
I have a question on when I should be setting KSPSetReusePreconditioner to PETSC_TRUE or PETSC_FALSE. It made a pretty big difference in the solutions I get when I ran my code testing both settings, so is recalculating the preconditioner better since it will make the convergence faster and the solution more accurate? On the other hand, if the operator is updated every time step (but same nonzero pattern), will reconstructing the pc become time-consuming?
We cannot say anything since it (at least) depends on a) how much your matrix changes from one solve to the next, and b)  what preconditioner you are reusing.
    Matt
Thank you!
Yuyun
-- Norbert Wiener
https://www.cse.buffalo.edu/~knepley/<http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190418/80449ecd/attachment.html>
