[petsc-users] Error with VecDestroy_MPIFFTW+0x61
    Sajid Ali
    sajidsyed2021 at u.northwestern.edu
    Wed Apr 17 09:25:12 CDT 2019
Hi Matt/Barry,
I've implemented this for 1D-complex-mpi vec and tested it.
Here is the modified source file ->
https://bitbucket.org/sajid__ali/petsc/src/86fb19b57a7c4f8f42644e5160d2afbdc5e03639/src/mat/impls/fft/fftw/fftw.c
Functions definitions at
https://bitbucket.org/sajid__ali/petsc/src/86fb19b57a7c4f8f42644e5160d2afbdc5e03639/src/mat/impls/fft/fftw/fftw.c#lines-395
New op at
https://bitbucket.org/sajid__ali/petsc/src/86fb19b57a7c4f8f42644e5160d2afbdc5e03639/src/mat/impls/fft/fftw/fftw.c#lines-514
If this looks good, I can extend it to all cases (1/2/3 dims +
real/complex) and add a vecdupliate/vecdestroy pair in the tests.
Thank You,
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190417/dd0de41e/attachment.html>
