[petsc-users] Question about KSP, and makefile linking MPICH
Yuyun Yang yyang85 at stanford.edu
Thu Apr 11 17:44:44 CDT 2019
Hello team,
I'd like to check if it's ok to use the same ksp object and change its operator (the matrix A) later on in the code to solve a different problem?
Also, I know I've asked this before about linking to MPICH when I call mpirun, instead of using my computer's default MPI, but I want to check again. The same problem was solved on my cluster by using a different CLINKER (called mpiicc) in the Makefile and a different intel compiler, which will link my compiled code with MPICH. Is there a similar thing I can do on my own computer, instead of having to use a very long path to locate the MPICH I configured with PETSc, and then calling the executable? (I tried making CLINKER = mpiicc on my own computer but that didn't work.)
The final question is related to valgrind. I have defined a setupKSP function to do all the solver/pc setup. It seems like there is a problem with memory allocation but I don't really understand why. This only happens for MUMPSCHOLESKY though (running CG, AMG etc. was fine):
==830== Invalid read of size 8
==830==    at 0x6977C95: dmumps_ana_o_ (dana_aux.F:2054)
==830==    by 0x6913B5A: dmumps_ana_driver_ (dana_driver.F:390)
==830==    by 0x68C152C: dmumps_ (dmumps_driver.F:1213)
==830==    by 0x68BBE1C: dmumps_f77_ (dmumps_f77.F:267)
==830==    by 0x68BA4EB: dmumps_c (mumps_c.c:417)
==830==    by 0x5A070D6: MatCholeskyFactorSymbolic_MUMPS (mumps.c:1654)
==830==    by 0x54071F2: MatCholeskyFactorSymbolic (matrix.c:3179)
==830==    by 0x614AFE9: PCSetUp_Cholesky (cholesky.c:88)
==830==    by 0x62BA574: PCSetUp (precon.c:932)
==830==    by 0x640BB29: KSPSetUp (itfunc.c:391)
==830==    by 0x4A1192: PressureEq::setupKSP(_p_KSP*&, _p_PC*&, _p_Mat*&) (pressureEq.cpp:834)
==830==    by 0x4A1258: PressureEq::computeInitialSteadyStatePressure(Domain&) (pressureEq.cpp:862)
==830==  Address 0xb8149c0 is 0 bytes after a block of size 7,872 alloc'd
==830==    at 0x4C2FFC6: memalign (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==830==    by 0x500E7E0: PetscMallocAlign (mal.c:41)
==830==    by 0x59F8A16: MatConvertToTriples_seqaij_seqsbaij (mumps.c:402)
==830==    by 0x5A06B53: MatCholeskyFactorSymbolic_MUMPS (mumps.c:1618)
==830==    by 0x49B809: PressureEq::PressureEq(Domain&) (pressureEq.cpp:62)
==830==    by 0x4A88E9: StrikeSlip_LinearElastic_qd::StrikeSlip_LinearElastic_qd(Domain&) (strikeSlip_linearElastic_qd.cpp:57)
Thank you!
Yuyun
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/4e74462b/attachment.html>
