[petsc-users] Error with KSPSetUp and MatNest
Manuel Colera Rico m.colera at upm.es
Thu Apr 11 05:13:33 CDT 2019
OK, many thanks,
Manuel
On 4/11/19 12:07 PM, Matthew Knepley wrote:
> On Thu, Apr 11, 2019 at 5:57 AM Manuel Colera Rico <m.colera at upm.es
> <mailto:m.colera at upm.es>> wrote:
>     MatCreateLocalRef() seems to be useful to extract submatrices from
>     a global matrix. But how to construct A from the beginning from
>     its submatrices? I.e., with MatNest, I can just do:
>         Mat A;
>         Mat matA[] = {A00, A01, NULL, A11};
>         MatCreateNest(PETSC_COMM_SELF, 2, NULL, 2, NULL, matA, &A);
>     without worrying about memory preallocations for A. Can I do the
>     same with MatCreateLocalRef(), or do I first have to preallocate
>     memory for A?
> It is a good point. You would have to preallocate the large matrix.
> However, the preallocation is just the sum for the
> preallocations of the small matrices, which you are already
> specifying. It would be no problem to give a similar
> LocalRef interface to preallocation to do that sum automatically for
> the user.
> Moreover, we now have a MatPreallocator interface. You can run your
> matrix assembly twice. Once with the
> MatPreallocator matrix, which can then preallocate you matrix exactly,
> and then again with the real matrix. This
> is more expensive of course, but in many applications, this expense is
> negligible compared to the solver.
>   Thanks,
>      Matt
>     Manuel
>     On 4/11/19 11:30 AM, Matthew Knepley wrote:
>>     On Thu, Apr 11, 2019 at 2:07 AM Smith, Barry F.
>>     <bsmith at mcs.anl.gov <mailto:bsmith at mcs.anl.gov>> wrote:
>>            Matt,
>>              You can't have some functionality in the public API for
>>         a library and then criticize someone for using it. I looked
>>         at the manual page for MatCreateNest() and it doesn't say in
>>         big letters "don't use this", nor does the compiler tell the
>>         user "don't use this". Either MatCreateNest() and/or MATNEST
>>         is so horrible it needs to be stripped from the face of the
>>         earth or it needs to be supported. It can't be in this
>>         nebulous state of "yeah it exists but don't ever use it".
>>     I agree this is a documentation problem. That is why I try to
>>     provide complete explanations for my recommendations.
>>            Barry
>>            In order to support easy testing of MatCreateNest() based
>>         user code perhaps we could add a little bit of code that
>>         allowed users to call either
>>         MatCreateNest() or MatNestSetSubMats() but with an option to
>>         have it generate a regular AIJ matrix instead. For example
>>         -mat_nest_use_aij (and MatNestUseAIJ()) This would allow
>>         users to always write and think about their code as nested
>>         matrices but have it "fall back" to AIJ for testing/debugging
>>         purposes.
>>     I think we should remove MatCreateNest() completely. We should
>>     have 1 mechanism for getting submatrices for creation, not 2, so
>>     we retain
>>     MatCreateLocalRef(). Then if -mat_type nest was specified, it
>>     gives you back an actually submatrix, otherwise it gives a view.
>>     This would do
>>     everything that we currently do without this horrible MatNest
>>     interface bubbling to the top.
>>        Matt
>>         > On Apr 10, 2019, at 11:49 AM, Manuel Colera Rico via
>>         petsc-users <petsc-users at mcs.anl.gov
>>         <mailto:petsc-users at mcs.anl.gov>> wrote:
>>         > Thank you for your answer, Matt. In the MWE example
>>         attached before, both Nest vectors (the r.h.s. of the system
>>         and the vector of unknowns) are composed of the same number
>>         of blocks (2). Indeed, PETSc is able to solve the system if
>>         KSPSetUp() is not called, so the system/MatNest/MatVec's must
>>         not incompatible at all. Therefore, I wonder if I have missed
>>         to called something before this routine or if this is a
>>         KSPSetUp's bug.
>>         > Of course one can always directly define a single matrix
>>         and a single vector, but I find it easier to work with Nest
>>         matrices and vectors. Moreover, I think that the moment to
>>         use them is from the beginning... once all the code is
>>         developed, it is very hard to switch matrices types.
>>         > Regards,
>>         > Manuel
>>         > On 4/10/19 5:41 PM, Matthew Knepley wrote:
>>         >> On Wed, Apr 10, 2019 at 11:29 AM Manuel Colera Rico via
>>         >> Hello,
>>         >> I am trying to solve a system whose matrix is of type
>>         MatNest. If I
>>         >> don't use KSPSetUp(), everything is fine. However, if I
>>         use that
>>         >> routine, I get the following error:
>>         >> 0]PETSC ERROR: --------------------- Error Message
>>         >> [0]PETSC ERROR: Invalid argument
>>         >> [0]PETSC ERROR: Nest vector arguments 1 and 2 have
>>         different numbers of
>>         >> blocks.
>>         >> This seems self-explanatory. Nest vectors must have the
>>         same number of blocks to be compatible.
>>         >> More broadly, there should be no reason to use Nest
>>         vectors or matrices. It is an optimization to
>>         >> be used at the very end, only after you have profiled the
>>         code and seen that its important. You can
>>         >> do everything you want to do without ever touching Nest,
>>         and it looks like the Nest interface is a
>>         >> problem for your code right now.
>>         >>   Thanks,
>>         >>     Matt
>>         >> [0]PETSC ERROR: See
>>         http://www.mcs.anl.gov/petsc/documentation/faq.html
>>         >> for trouble shooting.
>>         >> [0]PETSC ERROR: Petsc Release Version 3.11.0, unknown
>>         >> [0]PETSC ERROR:
>>         /home/manu/Documents/FEM-fluids/C-codes/CLG2-ConvectionDiffusion/Debug/CLG2-ConvectionDiffusion
>>         >> on a mcr_20190405 named mancolric by Unknown Wed Apr 10
>>         17:20:16 2019
>>         >> [0]PETSC ERROR: Configure options --with-cc=gcc
>>         --with-cxx=g++
>>         >> --with-fc=gfortran COPTFLAGS="-O3 -march=native
>>         -mtune=native"
>>         >> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
>>         >> -march=native -mtune=native" --with-debugging=0
>>         --download-fblaslapack
>>         >> --download--f2cblaslapack --download-mpich --download--hypre
>>         >> --download-scalapack --download-mumps --download-suitesparse
>>         >> --download-ptscotch --download-pastix --with-matlab
>>         --with-openmp
>>         >> [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
>>         /opt/PETSc_library/petsc-3.11.0/src/vec/vec/impls/nest/vecnest.c
>>         >> [0]PETSC ERROR: #2 VecCopy() line 1614 in
>>         >> /opt/PETSc_library/petsc-3.11.0/src/vec/vec/interface/vector.c
>>         >> [0]PETSC ERROR: #3 KSPInitialResidual() line 63 in
>>         >> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itres.c
>>         >> [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
>>         /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/impls/gmres/gmres.c
>>         >> [0]PETSC ERROR: #5 KSPSolve() line 782 in
>>         >> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itfunc.c
>>         >> [0]PETSC ERROR: #6 mwe() line 55 in ../Tests/tests.c
>>         >> Please find attached a MWE (it is a slight modification of
>>         that of the
>>         >> post opened by Ce Qin,
>>         https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024230.html,
>>         >> whose answer I have not found).
>>         >> By the way, with the newest version of PETSc, Eclipse
>>         marks as errors
>>         >> the commands PetscFree, CHKERRQ, PETSC_COMM_SELF,...
>>         although it
>>         >> compiles and executes well. Perhaps it is a problem
>>         related to Eclipse,
>>         >> but this did not happen with the older versions of PETSc.
>>         >> Thanks and regards,
>>         >> Manuel
>>         >> What most experimenters take for granted before they begin
>>         their experiments is infinitely more interesting than any
>>         results to which their experiments lead.
>>         >> -- Norbert Wiener
>>         >> https://www.cse.buffalo.edu/~knepley/
>>     What most experimenters take for granted before they begin their
>>     experiments is infinitely more interesting than any results to
>>     -- Norbert Wiener
>>     <http://www.cse.buffalo.edu/~knepley/>
> experiments is infinitely more interesting than any results to which
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190411/49aa75a8/attachment.html>
