[petsc-users] Error with KSPSetUp and MatNest
Smith, Barry F. bsmith at mcs.anl.gov
Thu Apr 11 01:07:55 CDT 2019
   Matt,
     You can't have some functionality in the public API for a library and then criticize someone for using it. I looked at the manual page for MatCreateNest() and it doesn't say in big letters "don't use this", nor does the compiler tell the user "don't use this". Either MatCreateNest() and/or MATNEST is so horrible it needs to be stripped from the face of the earth or it needs to be supported. It can't be in this nebulous state of "yeah it exists but don't ever use it".
   Barry
   In order to support easy testing of MatCreateNest() based user code perhaps we could add a little bit of code that allowed users to call either
MatCreateNest() or MatNestSetSubMats() but with an option to have it generate a regular AIJ matrix instead. For example -mat_nest_use_aij (and MatNestUseAIJ()) This would allow  users to always write and think about their code as nested matrices but have it "fall back" to AIJ for testing/debugging purposes.
> On Apr 10, 2019, at 11:49 AM, Manuel Colera Rico via petsc-users <petsc-users at mcs.anl.gov> wrote:
> Thank you for your answer, Matt. In the MWE example attached before, both Nest vectors (the r.h.s. of the system and the vector of unknowns) are composed of the same number of blocks (2). Indeed, PETSc is able to solve the system if KSPSetUp() is not called, so the system/MatNest/MatVec's must not incompatible at all. Therefore, I wonder if I have missed to called something before this routine or if this is a KSPSetUp's bug.
> Of course one can always directly define a single matrix and a single vector, but I find it easier to work with Nest matrices and vectors. Moreover, I think that the moment to use them is from the beginning... once all the code is developed, it is very hard to switch matrices types.
> Regards,
> Manuel
> On 4/10/19 5:41 PM, Matthew Knepley wrote:
>> On Wed, Apr 10, 2019 at 11:29 AM Manuel Colera Rico via petsc-users <petsc-users at mcs.anl.gov> wrote:
>> Hello,
>> I am trying to solve a system whose matrix is of type MatNest. If I
>> don't use KSPSetUp(), everything is fine. However, if I use that
>> routine, I get the following error:
>> 0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Invalid argument
>> [0]PETSC ERROR: Nest vector arguments 1 and 2 have different numbers of
>> blocks.
>> This seems self-explanatory. Nest vectors must have the same number of blocks to be compatible.
>> More broadly, there should be no reason to use Nest vectors or matrices. It is an optimization to
>> be used at the very end, only after you have profiled the code and seen that its important. You can
>> do everything you want to do without ever touching Nest, and it looks like the Nest interface is a
>> problem for your code right now.
>>   Thanks,
>>     Matt
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.11.0, unknown
>> [0]PETSC ERROR:
>> /home/manu/Documents/FEM-fluids/C-codes/CLG2-ConvectionDiffusion/Debug/CLG2-ConvectionDiffusion
>> on a mcr_20190405 named mancolric by Unknown Wed Apr 10 17:20:16 2019
>> [0]PETSC ERROR: Configure options --with-cc=gcc --with-cxx=g++
>> --with-fc=gfortran COPTFLAGS="-O3 -march=native -mtune=native"
>> CXXOPTFLAGS="-O3 -march=native -mtune=native" FOPTFLAGS="-O3
>> -march=native -mtune=native" --with-debugging=0 --download-fblaslapack
>> --download--f2cblaslapack --download-mpich --download--hypre
>> --download-scalapack --download-mumps --download-suitesparse
>> --download-ptscotch --download-pastix --with-matlab --with-openmp
>> [0]PETSC ERROR: #1 VecCopy_Nest() line 68 in
>> /opt/PETSc_library/petsc-3.11.0/src/vec/vec/impls/nest/vecnest.c
>> [0]PETSC ERROR: #2 VecCopy() line 1614 in
>> /opt/PETSc_library/petsc-3.11.0/src/vec/vec/interface/vector.c
>> [0]PETSC ERROR: #3 KSPInitialResidual() line 63 in
>> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itres.c
>> [0]PETSC ERROR: #4 KSPSolve_GMRES() line 236 in
>> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/impls/gmres/gmres.c
>> [0]PETSC ERROR: #5 KSPSolve() line 782 in
>> /opt/PETSc_library/petsc-3.11.0/src/ksp/ksp/interface/itfunc.c
>> [0]PETSC ERROR: #6 mwe() line 55 in ../Tests/tests.c
>> Please find attached a MWE (it is a slight modification of that of the
>> post opened by Ce Qin,
>> https://lists.mcs.anl.gov/pipermail/petsc-users/2015-February/024230.html,
>> whose answer I have not found).
>> By the way, with the newest version of PETSc, Eclipse marks as errors
>> the commands PetscFree, CHKERRQ, PETSC_COMM_SELF,... although it
>> compiles and executes well. Perhaps it is a problem related to Eclipse,
>> but this did not happen with the older versions of PETSc.
>> Thanks and regards,
>> Manuel
>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
