[petsc-users] Argument out of range error only in certain mpi sizes
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Wed Apr 10 18:12:38 CDT 2019
Thanks a lot for the advice Matt and Barry.
One thing I wanted to confirm is that when I change from using a regular
Vec to a Vec created using DMDACreateGlobalVector, to fill these with data
from hdf5, I have to change the dimensions of hdf5 vectors from
(dim_x*dim_y) to (dim_x,dim_y), right?
Because I see that if I write to hdf5 from a complex vector created using
DMDA, I get a vector that has dimensions (dim_x,dim_y,2) but before I saw
the dimension of the same to be (dim_x*dim_y,2).
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190410/a043d5ed/attachment-0001.html>
