[petsc-users] Solution Diverging
Mark Adams mfadams at lbl.gov
Fri Apr 5 17:23:04 CDT 2019
On Fri, Apr 5, 2019 at 5:27 PM Maahi Talukder <maahi.buet at gmail.com> wrote:
> Hi,
> Thank you for your reply.
> Well, I have verified the solution on large problems, and I have converged
> the solution to machine accuracy using different solvers. So I guess the
> setup okay in that respect.
I am suspicious that it "worked" on large problems but failed on small. But
you never know.
> The BC I am using is of Dirichlet type.
> On Fri, Apr 5, 2019 at 5:21 PM Mark Adams <mfadams at lbl.gov> wrote:
>> So you have a 2D Poisson solver and it is working on large problems but
>> the linear solver is diverging on small problems.
>> I would verify the the solution is good on the large problem.
>> You might have a problem with boundary conditions. What BCs do you think
>> you are using?
>> On Fri, Apr 5, 2019 at 4:33 PM Maahi Talukder via petsc-users <
>> petsc-users at mcs.anl.gov> wrote:
>>> Dear All,
>>> I am solving a linear system arising from 9-point discretization of
>>> Poisson equation to generate grid. KSP solvers are giving nice converged
>>> result when I am dealing with a large matrix. But when I am trying to
>>> implement KSP solvers when the matrix is smaller and the values are smaller
>>> too, the solution is diverging.
>>> Any suggestions how to get around this problem?
>>> Regards,
>>> Maahi Talukder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/41421bf1/attachment.html>
