[petsc-users] Solution Diverging
Mark Adams mfadams at lbl.gov
Fri Apr 5 16:21:10 CDT 2019
So you have a 2D Poisson solver and it is working on large problems but the
linear solver is diverging on small problems.
I would verify the the solution is good on the large problem.
You might have a problem with boundary conditions. What BCs do you think
you are using?
On Fri, Apr 5, 2019 at 4:33 PM Maahi Talukder via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Dear All,
> I am solving a linear system arising from 9-point discretization of
> Poisson equation to generate grid. KSP solvers are giving nice converged
> result when I am dealing with a large matrix. But when I am trying to
> implement KSP solvers when the matrix is smaller and the values are smaller
> too, the solution is diverging.
> Any suggestions how to get around this problem?
> Regards,
> Maahi Talukder
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/54a4a371/attachment.html>
