[petsc-users] Constructing a MATNEST with blocks defined in different procs
Mark Adams
mfadams at lbl.gov
Fri Apr 5 07:38:46 CDT 2019
On Fri, Apr 5, 2019 at 7:19 AM Diogo FERREIRA SABINO via petsc-users <
petsc-users at mcs.anl.gov> wrote:
> Hi,
> I'm new in petsc and I'm trying to construct a MATNEST in two procs, by
> setting each block of the nested matrix with a MATMPIAIJ matrix defined in
> each proc.
> I'm trying to use MatCreateNest or MatNestSetSubMats, but I'm not being
> able to do it.
> Using MatNestSetSubMats, I'm trying to construct the MATNEST, giving a
> pointer to the correct matrices depending on the MPIrank of that proc.
> I'm obtaining the error message for the line
> :MatNestSetSubMats(AfullNEST,1,&IS_ROW,2,&IS_COL,AfullNESTpointer);
> [0]PETSC ERROR: Invalid argument
> [0]PETSC ERROR: Wrong type of object: Parameter # 5
> Is there a way of doing it, or all the blocks of the MATNEST have to exist
> in the same communicator as the MATNEST matrix?
Yes, they must all have the same communicator. A matrix can be empty on a
process, so you just create them with the global communicator, set the
local sizes that you want (eg, 0 on some procs).
> A simple test is given below, lunching it with: mpirun -n 2
> ./Main_petsc.exe
> static char help[] = "Create MPI Nest";
> #include <petscmat.h>
> #undef __FUNCT__
> #define __FUNCT__ "main"
> int main(int argc,char **argv)
> PetscInitialize(&argc,&argv,(char*)0,help);
> PetscErrorCode ierr;
> PetscMPIInt MPIrank,MPIsize;
> MPI_Comm_rank(PETSC_COMM_WORLD,&MPIrank);
> MPI_Comm_size(PETSC_COMM_WORLD,&MPIsize);
> //////////////////////////////////////////////////////// Create Each
> Matrix:
> Mat Adiag;
> //Create a Adiag different on each proc:
> ierr = MatCreate(PETSC_COMM_SELF,&Adiag);
> CHKERRQ(ierr);
> ierr = MatSetSizes(Adiag,2,2,PETSC_DECIDE,PETSC_DECIDE);
> CHKERRQ(ierr);
> ierr = MatSetType(Adiag,MATMPIAIJ);
> CHKERRQ(ierr);
> ierr = MatSetFromOptions(Adiag);
> CHKERRQ(ierr);
> ierr = MatMPIAIJSetPreallocation(Adiag,2,NULL,2,NULL);
> CHKERRQ(ierr);
> MatSetValue(Adiag,0,0,(MPIrank+5),INSERT_VALUES);
> MatSetValue(Adiag,0,1,(MPIrank+10),INSERT_VALUES);
> MatSetValue(Adiag,1,0,(MPIrank+15),INSERT_VALUES);
> MatSetValue(Adiag,1,1,(MPIrank+20),INSERT_VALUES);
> MatAssemblyBegin(Adiag,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(Adiag,MAT_FINAL_ASSEMBLY);
> /////////////////////////////////////////////////////////////// Create
> Nest:
> MPI_Barrier(PETSC_COMM_WORLD);
> Mat AfullNEST, *AfullNESTpointer;
> PetscMalloc1(2,&AfullNESTpointer);
> AfullNESTpointer[0]=NULL;
> AfullNESTpointer[1]=NULL;
> AfullNESTpointer[MPIrank]=Adiag;
> // Rank=0 --> AfullNESTpointer[0]=Adiag; AfullNESTpointer[1]=NULL;
> // Rank=1 --> AfullNESTpointer[0]=NULL; AfullNESTpointer[1]=Adiag;
> IS IS_ROW,IS_COL;
> ISCreateStride(PETSC_COMM_SELF,1,MPIrank,0,&IS_ROW);
> ISCreateStride(PETSC_COMM_SELF,2,0,1,&IS_COL);
> // Rank=0 --> IS_ROW= [ 0 ] ; IS_COL= [ 0, 1 ] ;
> // Rank=1 --> IS_ROW= [ 1 ] ; IS_COL= [ 0, 1 ] ;
> MatCreate(PETSC_COMM_WORLD,&AfullNEST);
> MatSetSizes(AfullNEST,2,2,PETSC_DECIDE,PETSC_DECIDE);
> // MatSetSizes(AfullNEST,PETSC_DECIDE,PETSC_DECIDE,4,4);
> MatCreateNest(PETSC_COMM_WORLD,1,&IS_ROW,1,&IS_COL,AfullNESTpointer,&AfullNEST);
> ierr =
> CHKERRQ(ierr);
> ierr = PetscFinalize(); CHKERRQ(ierr);
> return 0;
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20190405/12d3e7e6/attachment.html>
