[petsc-users] Constructing a MATNEST with blocks defined in different procs
Diogo FERREIRA SABINO diogo.ferreira-sabino at univ-tlse3.fr
Fri Apr 5 06:19:34 CDT 2019
I'm new in petsc and I'm trying to construct a MATNEST in two procs, by setting each block of the nested matrix with a MATMPIAIJ matrix defined in each proc.
I'm trying to use MatCreateNest or MatNestSetSubMats, but I'm not being able to do it.
Using MatNestSetSubMats, I'm trying to construct the MATNEST, giving a pointer to the correct matrices depending on the MPIrank of that proc.
I'm obtaining the error message for the line :MatNestSetSubMats(AfullNEST,1,&IS_ROW,2,&IS_COL,AfullNESTpointer);
[0]PETSC ERROR: Invalid argument
[0]PETSC ERROR: Wrong type of object: Parameter # 5
Is there a way of doing it, or all the blocks of the MATNEST have to exist in the same communicator as the MATNEST matrix?
A simple test is given below, lunching it with: mpirun -n 2 ./Main_petsc.exe
static char help[]     = "Create MPI Nest";
#include <petscmat.h>
#undef __FUNCT__
#define __FUNCT__ "main"
int main(int argc,char **argv)
  PetscInitialize(&argc,&argv,(char*)0,help);
  PetscErrorCode  ierr;
  PetscMPIInt MPIrank,MPIsize;
  MPI_Comm_rank(PETSC_COMM_WORLD,&MPIrank);
  MPI_Comm_size(PETSC_COMM_WORLD,&MPIsize);
  ////////////////////////////////////////////////////////   Create Each Matrix:
  Mat Adiag;
  //Create a Adiag different on each proc:
  ierr = MatCreate(PETSC_COMM_SELF,&Adiag);                     CHKERRQ(ierr);
  ierr = MatSetSizes(Adiag,2,2,PETSC_DECIDE,PETSC_DECIDE);      CHKERRQ(ierr);
  ierr = MatSetType(Adiag,MATMPIAIJ);                           CHKERRQ(ierr);
  ierr = MatSetFromOptions(Adiag);                              CHKERRQ(ierr);
  ierr = MatMPIAIJSetPreallocation(Adiag,2,NULL,2,NULL);        CHKERRQ(ierr);
  MatSetValue(Adiag,0,0,(MPIrank+5),INSERT_VALUES);
  MatSetValue(Adiag,0,1,(MPIrank+10),INSERT_VALUES);
  MatSetValue(Adiag,1,0,(MPIrank+15),INSERT_VALUES);
  MatSetValue(Adiag,1,1,(MPIrank+20),INSERT_VALUES);
  MatAssemblyBegin(Adiag,MAT_FINAL_ASSEMBLY);     MatAssemblyEnd(Adiag,MAT_FINAL_ASSEMBLY);
  ///////////////////////////////////////////////////////////////   Create Nest:
  MPI_Barrier(PETSC_COMM_WORLD);
  Mat       AfullNEST, *AfullNESTpointer;
  PetscMalloc1(2,&AfullNESTpointer);
  AfullNESTpointer[0]=NULL;
  AfullNESTpointer[1]=NULL;
  AfullNESTpointer[MPIrank]=Adiag;
  // Rank=0 --> AfullNESTpointer[0]=Adiag; AfullNESTpointer[1]=NULL;
  // Rank=1 --> AfullNESTpointer[0]=NULL;  AfullNESTpointer[1]=Adiag;
  IS        IS_ROW,IS_COL;
  ISCreateStride(PETSC_COMM_SELF,1,MPIrank,0,&IS_ROW);
  ISCreateStride(PETSC_COMM_SELF,2,0,1,&IS_COL);
  // Rank=0 --> IS_ROW= [ 0 ] ; IS_COL= [ 0, 1 ] ;
  // Rank=1 --> IS_ROW= [ 1 ] ; IS_COL= [ 0, 1 ] ;
  MatCreate(PETSC_COMM_WORLD,&AfullNEST);
  MatSetSizes(AfullNEST,2,2,PETSC_DECIDE,PETSC_DECIDE);
  // MatSetSizes(AfullNEST,PETSC_DECIDE,PETSC_DECIDE,4,4);
  // MatCreateNest(PETSC_COMM_WORLD,1,&IS_ROW,1,&IS_COL,AfullNESTpointer,&AfullNEST);
    ierr = MatNestSetSubMats(AfullNEST,1,&IS_ROW,2,&IS_COL,AfullNESTpointer); CHKERRQ(ierr);
  ierr = PetscFinalize(); CHKERRQ(ierr);
  return 0;
