[petsc-users] Fwd: Implementing a homotopy solver
Sat Sep 29 09:09:24 CDT 2018
On Sat, Sep 29, 2018 at 9:47 AM zakaryah <zakaryah at gmail.com> wrote:
> Hi Matt - thanks for all your help.
> Let's say I want exactly the same solver for the tangent vector and the
> SNES update, so I should reuse the KSP.
> My attempt to do this looks like the summary of FormJacobian() in the
> previous message:
>    - assemble Jacobian
>    - assemble RHS
>    - get KSP from the SNES passed to FormJacobian()
>    - KSPSetFromOptions()
>    - KSPSetOperators()
>    - KSPSolve()
> I'm not sure that's the right approach, but it doesn't work - the
> KSPSolve() in the summary, i.e. the one for the tangent vector, seems to
> work fine.  But the next KSPSolve() looks strange - it seems to use a
> preconditioner even with -pc_type none, etc.  This makes me think I am
> doing something seriously wrong.
1) To get things going, just make the separate. Then we can optimize.
2) Give -ksp_view -ksp_monitor_true_residual -ksp_converged_reason to see
what is happening
  Matt
> On Sat, Sep 29, 2018, 8:16 AM Matthew Knepley <knepley at gmail.com> wrote:
>> On Fri, Sep 28, 2018 at 11:13 PM zakaryah <zakaryah at gmail.com> wrote:
>>> I'm working on a homotopy solver which follows a zero curve through
>>> solution space.  A central aspect of this method is to calculate the vector
>>> tangent to the curve, predict the next point, then correct using iteration
>>> of, e.g. Newton's method, orthogonal to the tangent vector.
>>> Previously, we discussed the possibilities of implementing this within
>>> PETSc's SNES.  Within my FormJacobian() function, I construct the linear
>>> system which defines the tangent vector, solve it, then add the vector to
>>> the nullspace of the Jacobian.  I think that in principle this can work,
>>> but I suspect I'm doing something wrong.
>>> Here's a summary of the code within FormJacobian():
>>>    - Set values and assemble Jacobian matrix A - this is working fine
>>>    - Set values and assemble RHS vector b for linear system defining
>>>    tangent vector n - this is working fine
>>>    - SNESGetKSP(snes,&my_ksp) - I thought it made sense to use the KSP
>>>    associated with the SNES, hoping that PCs which use a factorization could
>>>    be reused when the SNES calls KSPSolve() to calculate the update
>>>    - KSPSetFromOptions(my_ksp) - not sure this is necessary but one of
>>>    my problems is setting options for this KSP from the command line and even
>>>    with this call it doesn't seem to be working properly
>>>    - MatSetNullSpace(A,NULL) - remove any existing null space from
>>>    Jacobian
>>>    - KSPSetOperators(my_ksp,A,P) - P is the other matrix in
>>>    FormJacobian()
>>>    - VecSet(n,0) - set initial guess to zero
>>>    - KSPSolve(my_ksp,b,n) - these solves appear to work, i.e. use the
>>>    options passed from the command line with -ksp_XXX or -pc_XXX
>>>    - VecNormalize(n,NULL)
>>>    MatNullSpaceCreate(PetscObjectComm((PetscObject)A),PETSC_FALSE,1,&n,&nullsp)
>>>    - MatSetNullSpace(A,nullsp)
>>>    - MatNullSpaceDestroy(&nullsp)
>>>    - return
>>> The immediate problem is that the subsequent KSPSolve(), i.e. the one
>>> called internally by SNESSolve(), behaves strangely.  For example, if I use
>>> -pc_type none -ksp_monitor -ksp_monitor_true_residual, then the KSPSolve()
>>> that I call within FormJacobian() looks correct - "preconditioned" norm and
>>> true norm are identical, and both converge as I expect (i.e. slowly but
>>> geometrically).  However, the subsequent KSPSolve(), internal to the
>>> SNESSolve(), has large differences between the preconditioned norm and the
>>> true norm.  In addition, the KSP does not converge in the true residual,
>>> but I'll have a hard time debugging that without knowing how to properly
>>> set the options.
>> We need to clear up the usage first. If you want EXACTLY the same solver
>> for both solvers, then reuse
>> the KSP, otherwise do not do it. Does it work then?
>>   Thanks,
>>      Matt
>>> I hope someone can help me see what I'm doing wrong.
>>> On Sun, Jul 22, 2018 at 9:09 PM zakaryah <zakaryah at gmail.com> wrote:
>>>> Thanks Matt and Barry,
>>>> Matt - if I do the calculation in FormJacobian(), which makes by far
>>>> the most sense and is as per your suggestion, do I need to set the
>>>> operators of the SNES's KSP back to whatever they were before I set them?  The
>>>> linear system I want to solve within FormJacobian() involves the Jacobian
>>>> matrix itself, and I want to remove the "nullspace" from that same matrix
>>>> within FormFunction().
>>>> Barry - I'm trying to implement a homotopy solver.  In short, I have a
>>>> system of n nonlinear equations in n variables, F(x), which is hard to
>>>> solve because the Jacobian tends to become singular using standard
>>>> methods.  I want to add an auxiliary variable, lambda, to create a
>>>> homotopy: H(lambda,x) = lambda*F(x) + (1-lambda)G(x), where G is "easy to
>>>> solve", and the idea is that the Jacobian of the n+1 variable system will
>>>> not become singular along the curve H(lambda,x) = 0.
>>>> The method involves adding an equation to H so that the Jacobian H' is
>>>> square.  The "submatrix" refers to the n x (n+1) matrix which represents
>>>> the Jacobian without the added equation, whereas my FormJacobian() forms
>>>> the entire (n+1) x (n+1) matrix H'.  I only refer to the submatrix because
>>>> it has a nullspace, and I want to find it by solving a linear system
>>>> designed for this purpose, H' u = b, where b is not the zero vector.  H'
>>>> has no nullspace, but I want to remove the projection of u from my SNES
>>>> solution vector, as u IS in the nullspace of the submatrix.
>>>> The RHS vector b can be calculated outside the SNES solve.  I guess my
>>>> FormJacobian() should look like this:
>>>> FormJacobian(SNES snes, Vec x, Mat Amat, Mat Pmat, void *ctx) {
>>>>   KSP ksp;
>>>>   MatNullSpace unull;
>>>>   user_struct *user = (user_struct*)ctx;
>>>>   calculate Amat
>>>>   assemble Amat
>>>>   if (Pmat != Amat) {
>>>>     assemble Amat
>>>>   SNESGetKSP(snes,&ksp);
>>>>   KSPSetOperators(ksp,Amat,Pmat);
>>>>   KSPSolve(ksp,user->b,user->u);
>>>>   MatNullSpaceCreate(PetscObjectComm((PetscObject)Amat), PETSC_FALSE,
>>>> 1, &(user->u),&unull);
>>>>   MatSetNullSpace(Amat,unull);
>>>>   MatNullSpaceDestroy(&unull);
>>>> Does this look right?
>> experiments lead.
>> -- Norbert Wiener
>> https://www.cse.buffalo.edu/~knepley/
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180929/42d33a2a/attachment-0001.html>
