[petsc-users] Fwd: Implementing a homotopy solver
zakaryah zakaryah at gmail.com
Sat Sep 29 08:47:19 CDT 2018
Hi Matt - thanks for all your help.
Let's say I want exactly the same solver for the tangent vector and the
SNES update, so I should reuse the KSP.
My attempt to do this looks like the summary of FormJacobian() in the
previous message:
   - assemble Jacobian
   - assemble RHS
   - get KSP from the SNES passed to FormJacobian()
   - KSPSetFromOptions()
   - KSPSetOperators()
   - KSPSolve()
I'm not sure that's the right approach, but it doesn't work - the
KSPSolve() in the summary, i.e. the one for the tangent vector, seems to
work fine.  But the next KSPSolve() looks strange - it seems to use a
preconditioner even with -pc_type none, etc.  This makes me think I am
doing something seriously wrong.
On Sat, Sep 29, 2018, 8:16 AM Matthew Knepley <knepley at gmail.com> wrote:
> On Fri, Sep 28, 2018 at 11:13 PM zakaryah <zakaryah at gmail.com> wrote:
>> I'm working on a homotopy solver which follows a zero curve through
>> solution space.  A central aspect of this method is to calculate the vector
>> tangent to the curve, predict the next point, then correct using iteration
>> of, e.g. Newton's method, orthogonal to the tangent vector.
>> Previously, we discussed the possibilities of implementing this within
>> PETSc's SNES.  Within my FormJacobian() function, I construct the linear
>> system which defines the tangent vector, solve it, then add the vector to
>> the nullspace of the Jacobian.  I think that in principle this can work,
>> but I suspect I'm doing something wrong.
>> Here's a summary of the code within FormJacobian():
>>    - Set values and assemble Jacobian matrix A - this is working fine
>>    - Set values and assemble RHS vector b for linear system defining
>>    tangent vector n - this is working fine
>>    - SNESGetKSP(snes,&my_ksp) - I thought it made sense to use the KSP
>>    associated with the SNES, hoping that PCs which use a factorization could
>>    be reused when the SNES calls KSPSolve() to calculate the update
>>    - KSPSetFromOptions(my_ksp) - not sure this is necessary but one of
>>    my problems is setting options for this KSP from the command line and even
>>    with this call it doesn't seem to be working properly
>>    - MatSetNullSpace(A,NULL) - remove any existing null space from
>>    Jacobian
>>    - KSPSetOperators(my_ksp,A,P) - P is the other matrix in
>>    FormJacobian()
>>    - VecSet(n,0) - set initial guess to zero
>>    - KSPSolve(my_ksp,b,n) - these solves appear to work, i.e. use the
>>    options passed from the command line with -ksp_XXX or -pc_XXX
>>    - VecNormalize(n,NULL)
>>    MatNullSpaceCreate(PetscObjectComm((PetscObject)A),PETSC_FALSE,1,&n,&nullsp)
>>    - MatSetNullSpace(A,nullsp)
>>    - MatNullSpaceDestroy(&nullsp)
>>    - return
>> The immediate problem is that the subsequent KSPSolve(), i.e. the one
>> called internally by SNESSolve(), behaves strangely.  For example, if I use
>> -pc_type none -ksp_monitor -ksp_monitor_true_residual, then the KSPSolve()
>> that I call within FormJacobian() looks correct - "preconditioned" norm and
>> true norm are identical, and both converge as I expect (i.e. slowly but
>> geometrically).  However, the subsequent KSPSolve(), internal to the
>> SNESSolve(), has large differences between the preconditioned norm and the
>> true norm.  In addition, the KSP does not converge in the true residual,
>> but I'll have a hard time debugging that without knowing how to properly
>> set the options.
> We need to clear up the usage first. If you want EXACTLY the same solver
> for both solvers, then reuse
> the KSP, otherwise do not do it. Does it work then?
>   Thanks,
>      Matt
>> I hope someone can help me see what I'm doing wrong.
>> On Sun, Jul 22, 2018 at 9:09 PM zakaryah <zakaryah at gmail.com> wrote:
>>> Thanks Matt and Barry,
>>> Matt - if I do the calculation in FormJacobian(), which makes by far the
>>> most sense and is as per your suggestion, do I need to set the operators of
>>> the SNES's KSP back to whatever they were before I set them?  The
>>> linear system I want to solve within FormJacobian() involves the Jacobian
>>> matrix itself, and I want to remove the "nullspace" from that same matrix
>>> within FormFunction().
>>> Barry - I'm trying to implement a homotopy solver.  In short, I have a
>>> system of n nonlinear equations in n variables, F(x), which is hard to
>>> solve because the Jacobian tends to become singular using standard
>>> methods.  I want to add an auxiliary variable, lambda, to create a
>>> homotopy: H(lambda,x) = lambda*F(x) + (1-lambda)G(x), where G is "easy to
>>> solve", and the idea is that the Jacobian of the n+1 variable system will
>>> not become singular along the curve H(lambda,x) = 0.
>>> The method involves adding an equation to H so that the Jacobian H' is
>>> square.  The "submatrix" refers to the n x (n+1) matrix which represents
>>> the Jacobian without the added equation, whereas my FormJacobian() forms
>>> the entire (n+1) x (n+1) matrix H'.  I only refer to the submatrix because
>>> it has a nullspace, and I want to find it by solving a linear system
>>> designed for this purpose, H' u = b, where b is not the zero vector.  H'
>>> has no nullspace, but I want to remove the projection of u from my SNES
>>> solution vector, as u IS in the nullspace of the submatrix.
>>> The RHS vector b can be calculated outside the SNES solve.  I guess my
>>> FormJacobian() should look like this:
>>> FormJacobian(SNES snes, Vec x, Mat Amat, Mat Pmat, void *ctx) {
>>>   KSP ksp;
>>>   MatNullSpace unull;
>>>   user_struct *user = (user_struct*)ctx;
>>>   calculate Amat
>>>   assemble Amat
>>>   if (Pmat != Amat) {
>>>     assemble Amat
>>>   SNESGetKSP(snes,&ksp);
>>>   KSPSetOperators(ksp,Amat,Pmat);
>>>   KSPSolve(ksp,user->b,user->u);
>>>   MatNullSpaceCreate(PetscObjectComm((PetscObject)Amat), PETSC_FALSE, 1,
>>> &(user->u),&unull);
>>>   MatSetNullSpace(Amat,unull);
>>>   MatNullSpaceDestroy(&unull);
>>> Does this look right?
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180929/e9574aa8/attachment.html>
