[petsc-users] Usage of AMG as preconditioner
Michael Werner
michael.werner at dlr.de
Fri Sep 28 07:13:24 CDT 2018
Matthew Knepley writes:
> On Fri, Sep 28, 2018 at 7:43 AM Michael Werner
> <michael.werner at dlr.de>
>> > On Fri, Sep 28, 2018 at 3:23 AM Michael Werner
>> > wrote:
>> >> Hello,
>> >> I'm having trouble with getting the AMG preconditioners
>> >> working. I
>> >> tried all of them (gamg, ml, hypre-boomeramg), with varying
>> >> degrees of "success":
>> >> - GAMG:
>> >> CMD options: -ksp_rtol 1e-8 -ksp_monitor_true_residual
>> >> -ksp_max_it
>> >> 20 -ksp_type fgmres -pc_type gamg -pc_gamg_sym_graph TRUE
>> >> -pc_gamg_agg_nsmooths 1 -ksp_view
>> >> always crashes with the following error:
>> >> Error: error code 77
>> >> [0] KSPSolve() line 780 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/interface/itfunc.c
>> >> [0] KSPSolve_GMRES() line 233 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/impls/gmres/gmres.c
>> >> [0] KSPInitialResidual() line 67 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/interface/itres.c
>> >> [0] KSP_PCApply() line 281 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/include/petsc/private/kspimpl.h
>> >> [0] PCApply() line 462 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/interface/precon.c
>> >> [0] PCApply_MG() line 377 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/impls/mg/mg.c
>> >> [0] PCMGMCycle_Private() line 20 in
>> >> [0] KSPSolve_Chebyshev() line 381 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/impls/cheby/cheby.c
>> >> [0] Petsc has generated inconsistent data
>> >> [0] Eigen estimator failed: DIVERGED_NANORINF at iteration 0
>> >> When I'm using a different solver for -mg_levels_ksp_type,
>> >> such
>> >> as
>> >> gmres, GAMG no longer crashes, but I don't see convergence
>> >> of
>> >> the
>> >> problem (convergence history and ksp_view output are
>> >> attached
>> >> below).
>> > It uses unpreconditioned GMRES to estimate spectral bounds
>> > for
>> > the operator
>> > before using a Chebychev smoother.
>> > If your matrix does not have a nice, connected, positive
>> > spectrum,
>> > Chebychev will not work. However, the fact that
>> > you get DIVERGED_NANORINF in the estimator tells me that you
>> > have a problem
>> > in the matrix.
>> The error above (DIVERGED_NANORINF) only appears for
>> -mg_levels_ksp_type chebyshev. When I use GMRES
>> (-mg_levels_ksp_type gmres) there are no errors, the KSP just
>> never converges.
>> >> - Hypre
>> >> With the default settings, BoomerAMG just returns a Vector
>> >> of
>> >> all
>> >> zeros after one iteration.
>> >> When I change the relaxation type
>> >> -pc_hypre_boomeramg_relax_type_all to Jacobi, I get similar
>> >> results than with GAMG: the solver works without errors, but
>> >> doesn't converge. The output for Hypre is also attached
>> >> below.
>> >> - ML
>> >> With default settings the result is just like Boomeramg: a
>> >> vector
>> >> of all zeros after one iteration.
>> >> When I change -mg_levels_ksp_type the behaviour is identical
>> >> to
>> >> GAMG.
>> >> Since none of the packages worked, I'm assuming that the
>> >> error
>> >> lies with me/ my code,
>> > It looks like a value in the matrix might be bad.
>> >> so I'll give a short overview over what I'm
>> >> trying to do.
>> >> The matrix I'm trying to precondition is the Jacobian of a
>> >> flow
>> >> field originating from an unstructured finite-volume CFD
>> >> code.
> Compressible or incompressible?
> Mstt
The matrix is generated by a compressible CFD code. The current
test case is quasi-incompressible due to very low flow velocity
(flow around a cylinder).
Kind regards,
Michael
>> It
>> >> has a blocked structure as each node of the original mesh
>> >> holds
>> >> several variables (pressure, density, velocities). However,
>> >> I'm
>> >> not using a DM-Plex since I get the assembled Jacobian in
>> >> binary
>> >> format from the external CFD code.
>> >> When I'm using direct (lu) I get correct results, so the
>> >> basic
>> >> code should be fine.
>> > So LU works for the same problem that gave the NANORINF in
>> > GMRES?
>> > I would recommend using a Manufactured Solution to check the
>> > operation. Then
>> > you can start by feeding in the exact solution, and see that
>> > nothing fails.
>> > Also, I
>> > would make a very small test case, so that you can send the
>> > matrix and/or
>> > code
>> > to us to check.
>> Yes, LU works for the same matrix/ problem. I didn't change
>> anything besides using -pc_type lu instead of -pc_type gamg.
>> What do you mean by "Manufactured Solution"?
>> Concerning the test case: I'll set one up and send you the
>> matrix
>> in binary format.
>> >> However, for larger problems lu is not
>> >> feasible due the very large memory requirements, therefore I
>> >> wanted to switch over to multigrid.
>> >> Currently, PETSc has no information about the original
>> >> geometry. I
>> >> tried using setCoordinates, but for Hypre and ml it didn't
>> >> make
>> >> a
>> >> difference, and GAMG crashed with an error:
>> > This is only an optimization, and currently GAMG does not
>> > know
>> > what to
>> > do for multiple fields (it handles single field problems by
>> > building the
>> > nullspace of the symbol for the coarse grid). You could
>> > provide
>> > this when
>> > you want to optimize things.
>> > Thanks,
>> > Matt
>> Ok, thanks for the clarification. In that case I won't bother
>> with
>> it for now. No need to optimize the code before the other
>> problems
>> are solved.
>> Thank you for your answer!
>> Kind regards,
>> Michael
>> >> [0] PCSetCoordinates() line 1883 in
>> >> [0] PCSetCoordinates_AGG() line 199 in
>> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/impls/gamg/agg.c
>> >> [0] Don't know how to create null space for ndm=2, ndf=4.
>> >> Use
>> >> MatSetNearNullSpace.
>> >> I would be glad if you could give me some advice on how to
>> >> deal
>> >> with this.
>> >> Kind regards,
>> >> Michael
____________________________________________________
Deutsches Zentrum für Luft- und Raumfahrt e.V. (DLR)
Institut für Aerodynamik und Strömungstechnik | Bunsenstr. 10 |
37073 Göttingen
Michael Werner
Telefon 0551 709-2627 | Telefax 0551 709-2811 |
Michael.Werner at dlr.de
DLR.de
