[petsc-users] Usage of AMG as preconditioner
Fri Sep 28 06:55:08 CDT 2018
On Fri, Sep 28, 2018 at 7:43 AM Michael Werner <michael.werner at dlr.de>
wrote:
> Matthew Knepley writes:
> > On Fri, Sep 28, 2018 at 3:23 AM Michael Werner
> > wrote:
> >> Hello,
> >> I'm having trouble with getting the AMG preconditioners
> >> working. I
> >> tried all of them (gamg, ml, hypre-boomeramg), with varying
> >> degrees of "success":
> >> - GAMG:
> >> CMD options: -ksp_rtol 1e-8 -ksp_monitor_true_residual
> >> -ksp_max_it
> >> 20 -ksp_type fgmres -pc_type gamg -pc_gamg_sym_graph TRUE
> >> -pc_gamg_agg_nsmooths 1 -ksp_view
> >> always crashes with the following error:
> >> Error: error code 77
> >> [0] KSPSolve() line 780 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/interface/itfunc.c
> >> [0] KSPSolve_GMRES() line 233 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/impls/gmres/gmres.c
> >> [0] KSPInitialResidual() line 67 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/interface/itres.c
> >> [0] KSP_PCApply() line 281 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/include/petsc/private/kspimpl.h
> >> [0] PCApply() line 462 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/interface/precon.c
> >> [0] PCApply_MG() line 377 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/impls/mg/mg.c
> >> [0] PCMGMCycle_Private() line 20 in
> >> [0] KSPSolve_Chebyshev() line 381 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/ksp/impls/cheby/cheby.c
> >> [0] Petsc has generated inconsistent data
> >> [0] Eigen estimator failed: DIVERGED_NANORINF at iteration 0
> >> When I'm using a different solver for -mg_levels_ksp_type, such
> >> as
> >> gmres, GAMG no longer crashes, but I don't see convergence of
> >> the
> >> problem (convergence history and ksp_view output are attached
> >> below).
> > It uses unpreconditioned GMRES to estimate spectral bounds for
> > the operator
> > before using a Chebychev smoother.
> > If your matrix does not have a nice, connected, positive
> > spectrum,
> > Chebychev will not work. However, the fact that
> > you get DIVERGED_NANORINF in the estimator tells me that you
> > have a problem
> > in the matrix.
> The error above (DIVERGED_NANORINF) only appears for
> -mg_levels_ksp_type chebyshev. When I use GMRES
> (-mg_levels_ksp_type gmres) there are no errors, the KSP just
> never converges.
> >> - Hypre
> >> With the default settings, BoomerAMG just returns a Vector of
> >> all
> >> zeros after one iteration.
> >> When I change the relaxation type
> >> -pc_hypre_boomeramg_relax_type_all to Jacobi, I get similar
> >> results than with GAMG: the solver works without errors, but
> >> doesn't converge. The output for Hypre is also attached below.
> >> - ML
> >> With default settings the result is just like Boomeramg: a
> >> vector
> >> of all zeros after one iteration.
> >> When I change -mg_levels_ksp_type the behaviour is identical to
> >> GAMG.
> >> Since none of the packages worked, I'm assuming that the error
> >> lies with me/ my code,
> > It looks like a value in the matrix might be bad.
> >> so I'll give a short overview over what I'm
> >> trying to do.
> >> The matrix I'm trying to precondition is the Jacobian of a flow
> >> field originating from an unstructured finite-volume CFD
> >> code.
Compressible or incompressible?
  Mstt
> It
> >> has a blocked structure as each node of the original mesh holds
> >> several variables (pressure, density, velocities). However, I'm
> >> not using a DM-Plex since I get the assembled Jacobian in
> >> binary
> >> format from the external CFD code.
> >> When I'm using direct (lu) I get correct results, so the basic
> >> code should be fine.
> > So LU works for the same problem that gave the NANORINF in
> > GMRES?
> > I would recommend using a Manufactured Solution to check the
> > operation. Then
> > you can start by feeding in the exact solution, and see that
> > nothing fails.
> > Also, I
> > would make a very small test case, so that you can send the
> > matrix and/or
> > code
> > to us to check.
> Yes, LU works for the same matrix/ problem. I didn't change
> anything besides using -pc_type lu instead of -pc_type gamg.
> What do you mean by "Manufactured Solution"?
> Concerning the test case: I'll set one up and send you the matrix
> in binary format.
> >> However, for larger problems lu is not
> >> feasible due the very large memory requirements, therefore I
> >> wanted to switch over to multigrid.
> >> Currently, PETSc has no information about the original
> >> geometry. I
> >> tried using setCoordinates, but for Hypre and ml it didn't make
> >> a
> >> difference, and GAMG crashed with an error:
> > This is only an optimization, and currently GAMG does not know
> > what to
> > do for multiple fields (it handles single field problems by
> > building the
> > nullspace of the symbol for the coarse grid). You could provide
> > this when
> > you want to optimize things.
> >   Thanks,
> >     Matt
> Ok, thanks for the clarification. In that case I won't bother with
> it for now. No need to optimize the code before the other problems
> are solved.
> Thank you for your answer!
> Kind regards,
> Michael
> >> [0] PCSetCoordinates() line 1883 in
> >> [0] PCSetCoordinates_AGG() line 199 in
> /home/yoda/wern_mc/Programme/Anaconda/envs/GSA_27/weitere_programme/petsc-3.10.0/src/ksp/pc/impls/gamg/agg.c
> >> [0] Don't know how to create null space for ndm=2, ndf=4.  Use
> >> MatSetNearNullSpace.
> >> I would be glad if you could give me some advice on how to deal
> >> with this.
> >> Kind regards,
> >> Michael
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180928/abef617f/attachment.html>
