[petsc-users] Retireve eigenvectors from a paralell job/ Spectrum slicing in order to solve big eigenvalue problem
Matthew Knepley
knepley at gmail.com
Tue Sep 18 11:19:16 CDT 2018
On Tue, Sep 18, 2018 at 11:53 AM Jan Grießer <griesser.jan at googlemail.com>
wrote:
> But i'am still struggling a little bit with copying the vector entries
> from the processes to one sequentiel proces. I tried to use the comment
> with Scatter().toZero() in Python and tried the following code:
> vecs = np.zeros((69999,nconv))
> for i in range(nconv):
> val = E.getEigenpair(i, vr, vi)
> scatter, vec_full = PETSc.Scatter().toZero(vr)
> scatter.scatter(vr, vec_full, False, PETSc.ScatterMode.FORWARD)
> if rank == 0:
> vecs[:,i] = vec_full.getArray()
> but when i take a look at the eigenvectors there are some entries which
> are strange, because in this exampled i printed 4 eigenvalues and vectors
> and get nconv=4, but when i print the vectors i get lines
> with 4 entries but they are all zero and also get lines with strange
> entries e.g.
> 6.386079897185445800e-05 3.675310683411162830e-04 9.068495707804999221e-06
> 7.43627600.000000000000000000e+00 0.000000000000000000e+00
> where i have more than 4 entries. Can somebody explain to me why this
> happens or what is wrong with the code. (Sorry for asking such beginner
> questions, but i just started to work with PETSc and SLEPc)
We can definitely figure that out. However, can you try
vr.view(PETSC_VIEWER_STDOUT_WORLD)
just to check your vectors initially?
Matt
> Am Di., 18. Sep. 2018 um 09:26 Uhr schrieb Jan Grießer <
> griesser.jan at googlemail.com>:
>> Now it works. Thank you very much!
>> Am Mo., 17. Sep. 2018 um 10:54 Uhr schrieb Jose E. Roman <
>> jroman at dsic.upv.es>:
>>> For this you have to set a number of partitions equal to the number of
>>> MPI processes. If you get this error it is because these values are
>>> different.
>>> Jose
>>> > El 17 sept 2018, a las 10:50, Jan Grießer <griesser.jan at googlemail.com>
>>> escribió:
>>> > Is this relly necessary, because in the last sentences of the chapter
>>> it states that:
>>> > An additional benefit of multi-communicator support is that it enables
>>> parallel spectrum slicing runs without the need to install a parallel
>>> direct solver (MUMPS). The following commandline example uses sequential
>>> linear solves in 4 partitions, one process each:
>>> > Therefore i assumed that it is not necessary to compile PETsc4py with
>>> an external solver e.g. MUMPS
>>> > Am Mo., 17. Sep. 2018 um 10:47 Uhr schrieb Jose E. Roman <
>>> > You need a parallel direct solver such as MUMPS. This is explained in
>>> section 3.4.5.
>>> > Jose
>>> > > El 17 sept 2018, a las 10:41, Jan Grießer <
>>> griesser.jan at googlemail.com> escribió:
>>> > > def solve_eigensystem(DynMatrix_nn, Unity_nn, Dimension, LowerLimit,
>>> UpperLimit):
>>> > > # Create the EPS solver
>>> > > E = SLEPc.EPS().create()
>>> > > # Create the preconditioner and set it to Cholesky
>>> > > pc = PETSc.PC().create()
>>> > > pc.setType(pc.Type.CHOLESKY)
>>> > > # Create the KSP object
>>> > > ksp = PETSc.KSP().create()
>>> > > ksp.setType(ksp.Type.PREONLY)
>>> > > ksp.setPC(pc)
>>> > > # Set up the spectral transformations
>>> > > st = SLEPc.ST().create()
>>> > > st.setType("sinvert")
>>> > > st.setKSP(ksp)
>>> > > # Setup spectral transformation
>>> > > E.setST(st)
>>> > > # Eigenvalues should be real, therefore we start to order them
>>> from the smallest real value |l.real|
>>> > > E.setWhichEigenpairs(E.Which.ALL)
>>> > > # Set the interval of spectrum slicing
>>> > > E.setInterval(LowerLimit, UpperLimit)
>>> > > # Since the dynamical matrix is symmetric and real it is
>>> hermitian. Use GHEP for the spectrum slicing. Operatormatrix B is just a
>>> unit matrix
>>> > > E.setProblemType(SLEPc.EPS.ProblemType.GHEP)
>>> > > # Use the Krylov Schur method to solve the eigenvalue problem
>>> > > E.setType(E.Type.KRYLOVSCHUR)
>>> > > # Partition the Krylov schnur problem in npart procceses
>>> > > E.setKrylovSchurPartitions(10)
>>> > > # Set the convergence criterion to relative to the eigenvalue
>>> and the maximal number of iterations
>>> > > E.setConvergenceTest(E.Conv.REL)
>>> > > E.setTolerances(tol = 1e-7, max_it = 1000)
>>> > > # Set the matrix in order to solve
>>> > > E.setOperators(DynMatrix_nn, Unity_nn)
>>> > > # Sets EPS options from the options database.
>>> > > E.setFromOptions()
>>> > > # Sets up all the internal data structures necessary for the
>>> execution of the eigensolver.
>>> > > E.setUp()
>>> > > # Solve eigenvalue problem
>>> > > startClock = time.clock()
>>> > > startTime = time.time()
>>> > > E.solve()
>>> > > Has maybe one of you any idea why this happens and where the problem
>>> is ?
>>> > > Am Mo., 17. Sep. 2018 um 10:40 Uhr schrieb Jan Grießer <
>>> > > I am aware that SLEPc is not supposed to calculate all eigenvalues
>>> and eigenvectors, my problem is simply that i want for a physical large
>>> enough system all of them before i can make the transition to go to the
>>> smallest ones.
>>> > > Competitiveness is of secondary importance at the moment.
>>> > > But ihave a problem connected with spectrum slicing. I followed the
>>> instructions in the manual of Chap. 3.4.5 Spectrum Slicing and converted
>>> them to the python package.
>>> > > But now i get the following error. It appears to me that it is not
>>> able to find the ksp object, but i actually do not know why this is the
>>> case.
>>> > > aceback (most recent call last):
>>> > > File "Eigensolver_spectrum_slicing.py", line 216, in <module>
>>> > > solve_eigensystem(DynMatrix_nn, Unity_nn, D_nn.shape,
>>> opt_dict.LowLimit, opt_dict.UpperLimit)
>>> > > File "Eigensolver_spectrum_slicing.py", line 121, in
>>> solve_eigensystem
>>> > > E.setUp()
>>> > > File "SLEPc/EPS.pyx", line 1099, in slepc4py.SLEPc.EPS.setUp
>>> > > petsc4py.PETSc.Error: error code 92
>>> > > [14] EPSSetUp() line 165 in
>>> /tmp/pip-install-golhudw7/slepc/src/eps/interface/epssetup.c
>>> > > [14] EPSSetUp_KrylovSchur() line 146 in
>>> /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/krylovschur.c
>>> > > [14] EPSSetUp_KrylovSchur_Slice() line 410 in
>>> /tmp/pip-install-golhudw7/slepc/src/eps/impls/krylov/krylovschur/ks-slice.c
>>> > > [14] EPSSliceGetEPS() line 300 in
>>> > > [14] EPSSetUp_KrylovSchur_Slice() line 461 in
>>> > > [14] EPSSliceGetInertia() line 331 in
>>> > > [14] STSetUp() line 271 in
>>> /tmp/pip-install-golhudw7/slepc/src/sys/classes/st/interface/stsolve.c
>>> > > [14] STSetUp_Sinvert() line 132 in
>>> /tmp/pip-install-golhudw7/slepc/src/sys/classes/st/impls/sinvert/sinvert.c
>>> > > [14] KSPSetUp() line 381 in
>>> /tmp/pip-install-xmiaat2t/petsc/src/ksp/ksp/interface/itfunc.c
>>> > > [14] PCSetUp() line 923 in
>>> /tmp/pip-install-xmiaat2t/petsc/src/ksp/pc/interface/precon.c
>>> > > [14] PCSetUp_Cholesky() line 86 in
>>> /tmp/pip-install-xmiaat2t/petsc/src/ksp/pc/impls/factor/cholesky/cholesky.c
>>> > > [14] MatGetFactor() line 4318 in
>>> /tmp/pip-install-xmiaat2t/petsc/src/mat/interface/matrix.c
>>> > > [14] See
>>> http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for
>>> possible LU and Cholesky solvers
>>> > > [14] Could not locate a solver package. Perhaps you must ./configure
>>> with --download-<package>
>>> > > The code i used to solve the problem is
>>> > > Am Fr., 14. Sep. 2018 um 18:34 Uhr schrieb Matthew Knepley <
>>> knepley at gmail.com>:
>>> > > On Fri, Sep 14, 2018 at 12:19 PM Jose E. Roman <jroman at dsic.upv.es>
>>> wrote:
>>> > > El 14 sept 2018, a las 17:45, Jan Grießer <
>>> > >> Hey there,
>>> > >> first i want to say thanks to Satish and Matt for helping with with
>>> my last problem with the mpi compilation. I have two questions related to
>>> solving a big, hermitian, standard eigenvalue problem using SLEPc4py.,
>>> compiled with Intel MKL and Intel MPI.
>>> > >> - I am using slepc4py with
>>> > >> mpi and run it with around -n 20 cores at the moment and how i
>>> wanted to ask if there is an easy way to retrieve the eigenvectors? When i
>>> run my code and print for i in range(nconv):
>>> > >> val = E.
>>> > >> getEigenpair(i, vr
>>> > >> , vi)
>>> > >> Print(
>>> > >> vr.getArray())
>>> > >> i get the parts of the eigenvectors according to the partition of
>>> the matrix. Is there any easy way to put them together in an array and
>>> write them to file ? (I am struggling a little bit with the building them
>>> in the correct order)
>>> > > You need VecScatterCreateToZero. There must be an equivalent in
>>> python.
>>> > > An alternative to this which you should consider, because it is
>>> simpler, is to write the vector to a file
>>> > > using some format that PETSc understands, Then you just need
>>> vr.view(viewer) for a viewer like
>>> > > the binary viewer or some ASCII format you like.
>>> > > Thanks,
>>> > > Matt
>>> > >> - I need to solve eigenvalue problems up to a dimension of 100000
>>> degrees of freedom and i need all eigenvalues and eigenvectors. I think
>>> solving all eigenvalues in one process is far too much and i thought about
>>> if it is possible to apply the spectrum slicing described in Chap. 3.4.5.
>>> Due to the nature of my problem, i am able to simulate smaller systems of
>>> 10000 DOF and extract the biggest eigenvalue, which will be the same for
>>> larger systems sizes. Is this in general possible since i have a standard
>>> HEP problem or is there a better and faster possibility to do this?
>>> > > In general, SLEPc is not intended for computing the whole spectrum.
>>> You can try with spectrum slicing but this will be competitive if computing
>>> just a percentage of eigenvalues, 50% say.
>>> > > Jose
>>> > > What most experimenters take for granted before they begin their
>>> experiments is infinitely more interesting than any results to which their
>>> experiments lead.
>>> > > -- Norbert Wiener
>>> > > https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180918/ebf7467f/attachment.html>
