[petsc-users] [SPAM?] Re: Requesting multi-GPUs
Karl Rupp rupp at iue.tuwien.ac.at
Thu Sep 13 23:52:01 CDT 2018
Hi Manuel,
we do not handle more than one GPU per MPI process. If we did, we would
have to duplicate all the existing MPI communication pattern for the
multiple GPUs on a single process. This is a significant maintenance
burden, yet it would not provide any significant performance benefits.
Best regards,
Karli
On 09/12/2018 11:31 PM, Manuel Valera wrote:
> Ok then, how can i try getting more than one GPU with the same number of
> MPI processes?
> Thanks,
> On Wed, Sep 12, 2018 at 2:20 PM, Matthew Knepley <knepley at gmail.com
> <mailto:knepley at gmail.com>> wrote:
>     On Wed, Sep 12, 2018 at 5:13 PM Manuel Valera <mvalera-w at sdsu.edu
>     <mailto:mvalera-w at sdsu.edu>> wrote:
>         Hello guys,
>         I am working in a multi-gpu cluster and i want to request 2 or
>         more GPUs, how can i do that from PETSc? evidently mpirun -n #
>         is for requesting processors, but what if i want to use one mpi
>         processor but several GPUs instead?
>     We do not do that. You would run the same number of MPI processes as
>     GPUs. Note that
>     you can have more than 1 MPI process on a processor.
>        Matt
>         Also, i understand the GPU handles the linear system solver, but
>         what about the data management? can i do DMs for other than the
>         linear solver using the GPUs
>         Thanks once more,
>     What most experimenters take for granted before they begin their
>     experiments is infinitely more interesting than any results to which
>     their experiments lead.
>     -- Norbert Wiener
>     https://www.cse.buffalo.edu/~knepley/
>     <http://www.cse.buffalo.edu/%7Eknepley/>
