[petsc-users] Requesting multi-GPUs
Matthew Knepley
knepley at gmail.com
Thu Sep 13 14:01:07 CDT 2018
On Thu, Sep 13, 2018 at 2:33 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
> So, from what i get here the round robin assignation to each GPU device is
> done automatically by PETSc, from mapping the system? or do i have to pass
> a command line argument to do that?
It is automatic.
Matt
> Thanks,
> On Wed, Sep 12, 2018 at 2:38 PM, Matthew Knepley <knepley at gmail.com>
> wrote:
>> On Wed, Sep 12, 2018 at 5:31 PM Manuel Valera <mvalera-w at sdsu.edu> wrote:
>>> Ok then, how can i try getting more than one GPU with the same number of
>>> MPI processes?
>> I do not believe we handle more than one GPU per MPI process. Is that
>> what you are asking?
>> Thanks,
>> Matt
>>> Thanks,
>>> On Wed, Sep 12, 2018 at 2:20 PM, Matthew Knepley <knepley at gmail.com>
>>> wrote:
>>>> On Wed, Sep 12, 2018 at 5:13 PM Manuel Valera <mvalera-w at sdsu.edu>
>>>> wrote:
>>>>> Hello guys,
>>>>> I am working in a multi-gpu cluster and i want to request 2 or more
>>>>> GPUs, how can i do that from PETSc? evidently mpirun -n # is for requesting
>>>>> processors, but what if i want to use one mpi processor but several GPUs
>>>>> instead?
>>>> We do not do that. You would run the same number of MPI processes as
>>>> GPUs. Note that
>>>> you can have more than 1 MPI process on a processor.
>>>> Matt
>>>>> Also, i understand the GPU handles the linear system solver, but what
>>>>> about the data management? can i do DMs for other than the linear solver
>>>>> using the GPUs
>>>>> Thanks once more,
>>>> What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> -- Norbert Wiener
>>>> https://www.cse.buffalo.edu/~knepley/
>>>> <http://www.cse.buffalo.edu/~knepley/>
>> experiments lead.
>> -- Norbert Wiener
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180913/7124e659/attachment.html>
