[petsc-users] Use block Jacobi preconditioner with SNES
Smith, Barry F.
bsmith at mcs.anl.gov
Thu Sep 6 16:15:43 CDT 2018
I have not yet added this support, do you need it now?
Barry
> On Sep 6, 2018, at 4:12 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
> I have to apologize for making this topic so lengthy. Is vpbjacobi supposed to work in parallel mode (with MPI)?
> On 8/30/2018 1:32 AM, Smith, Barry F. wrote:
>>> On Aug 29, 2018, at 3:48 PM, Ali Reza Khaz'ali <arkhazali at cc.iut.ac.ir> wrote:
>>>> Can you confirm if your code ran successfully with vpbjacobi and if the convergence history was very similar to that achieved using
>>>> bjacobi ?
>>> They have a very very very small difference (which is probably due to round-off errors), they generally behave the same. My code run successfully with both of them with the same convergence history. However, vpbjacobi seems a little faster.
>> Great, this is exactly what to expect. I will put the branch into next for testing and then it will be in the master branch and in the next release.
>> Barry
>>> Many thanks,
>>> Ali
> Ali Reza Khaz’ali
> Assistant Professor of Petroleum Engineering,
> Department of Chemical Engineering
> Isfahan University of Technology
> Isfahan, Iran
