[petsc-users] Questions about residual function can't be reduced
Yingjie Wu
yjwu16 at gmail.com
Thu Sep 6 03:47:38 CDT 2018
Dear Petsc developer:
Thank you for your previous help.
I recently modeled on PETSc's SNES example and wrote a computer program
myself. This program is mainly for solving nonlinear equations of thermal
hydraulics.
∇·(λ∇T) - ∇_y(ρ*Cp*u) - T_source = 0
w*ρ*u = ρg - ∇_y(P)
∇·( 1/w * ∇P ) = - ∇( ρg / w )
Where P, T and u are variables, the distribution represents pressure,
temperature and velocity. The rest are nonlinear physical parameters and
constants.
Because the program is very preliminary, so I use - snes_mf so that I can
save the part of writing to calculate the Jacobian matrix.
After compiling and passing, I found that the residual function had not
dropped to a small enough level, but the program stopped, as follows:
Setting Up: -snes_mf -snes_monitor -draw_pause 10 -snes_view
0 SNES Function norm 3.724996516631e+09
1 SNES Function norm 2.194322909557e+09
2 SNES Function norm 1.352051559826e+09
3 SNES Function norm 1.522311916217e+08
SNES Object: 1 MPI processes
type: newtonls
maximum iterations=50, maximum function evaluations=10000
tolerances: relative=1e-08, absolute=1e-50, solution=1e-08
total number of linear solver iterations=1298
total number of function evaluations=11679
norm schedule ALWAYS
SNESLineSearch Object: 1 MPI processes
type: bt
interpolation: cubic
alpha=1.000000e-04
maxstep=1.000000e+08, minlambda=1.000000e-12
tolerances: relative=1.000000e-08, absolute=1.000000e-15,
lambda=1.000000e-08
maximum iterations=40
KSP Object: 1 MPI processes
type: gmres
restart=30, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
happy breakdown tolerance 1e-30
maximum iterations=10000, initial guess is zero
tolerances: relative=1e-05, absolute=1e-50, divergence=10000.
left preconditioning
using PRECONDITIONED norm type for convergence test
PC Object: 1 MPI processes
type: none
linear system matrix = precond matrix:
Mat Object: 1 MPI processes
type: mffd
rows=300, cols=300
Matrix-free approximation:
err=1.49012e-08 (relative error in function evaluation)
Using wp compute h routine
Does not compute normU
I would like to know why the residual function can not continue to decline,
and why the program will stop before convergence.
I do not know much about the convergence criteria and convergence rules of
PETSc for solving nonlinear equations. I hope I can get your help.
I'm looking forward to your reply~
Yingjie
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180906/d31d80e4/attachment.html>
