[petsc-users] matrix-free SNES with preconditioner
Matthew Knepley
knepley at gmail.com
Wed Sep 5 20:37:39 CDT 2018
On Wed, Sep 5, 2018 at 9:34 PM Oleksandr Koshkarov <olk548 at mail.usask.ca>
wrote:
> Hello all,
> I got lost a little with petsc and want to clarify something.
> I want to do my nonlinear solves with matrix free method, but I want a
> real matrix preconditioner and invert it with LU.
> without preconditioner it is simple:
> Mat Jmf;
> MatCreateSNESMF(snes,&Jmf);
> SNESSetJacobian(snes,Jmf,Jmf,MatMFFDComputeJacobian,0);
> But with preconditioner, I am lost:
> Mat Jmf,J;
> DMCreateMatrix(da,&J);
> SNESSetJacobian(snes,Jmf,J,FromJacobian,0);
> //And here I have problems:
> PetscErrorCode FormJacobian(SNES snes,Vec X,Mat Jmf,Mat J,void *ptr){
> // I am constructing it only once in a while, not every nonlinear solve
> (this snes is inside time stepper).
> if (sometimes) { MatSetValuesStencil(J,...); ... }
> MatAssemblyBegin(J,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(J,MAT_FINAL_ASSEMBLY);
> // assembling Jmf
> MatAssemblyBegin(Jmf,MAT_FINAL_ASSEMBLY);
> MatAssemblyEnd(Jmf,MAT_FINAL_ASSEMBLY);
> return(0);
> Here I have two concerns:
> 1) I am changing J only once in a while, because it is expansive to do
> otherwise. Am I doing it correctly? During iteration when I am not
> changing J, will petsc know this?
Yes, every matrix has a state variable that is updated when values are
changed.
The LU looks at this state variable to decide whether to refactor.
> I do not want petsc to perform LU
> every time when I am not changing J. And when I will change J, will it
> work?
Yes, but it is easy to check in the log. Use -log_view and look at the
number of calls
to PCLUFactorNumeric.
> (My snes is inside time stepper, and I want to construct
> preconditioner only say every 100 time steps)
> 2) What about Jmf? how can I let petsc know that it should use matrix
> free finite difference? Will it work if I let it as it is? (I think so,
> but I am not sure - my information source is
> ts/examples/tutorials/ex15.c, but I do not understand it fully)
It appears you have it correct. I always use MMS to make sure my solver is
doing what I expect.
Matt
> Thank you and best regards,
> Alex.
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180905/dc1e3058/attachment.html>
