[petsc-users] Problem compiling with 64bit PETSc
Wed Sep 5 05:25:59 CDT 2018
On Wed, Sep 5, 2018 at 3:27 AM TAY wee-beng <zonexo at gmail.com> wrote:
> On 31/8/2018 10:43 AM, Smith, Barry F. wrote:
> >> On Aug 30, 2018, at 9:40 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> >> On 31/8/2018 10:38 AM, Smith, Barry F. wrote:
> >>>    PetscReal is by default real(8) you can leave those alone
> >>>     Any integer you pass to a PETSc routine needs to be declared as
> PetscInt (not integer) otherwise the 64 bit indices stuff won't work.
> >>>     Barry
> >> Hi,
> >> ok, I got it. Btw, is it advisable to change all integer in my code to
> PetscInt?
> >> Will it cause any conflict or waste a lot of memory?
> >> Or should I only change those related to PETSc?
> >      That is up to you. Since you probably pass the values between PETSc
> and non-PETSc part of the code it is probably easier just to make all the
> integer PetscInt instead. No performance difference that you can measure by
> keeping a few integer around.
> >      Barry
> Hi,
> For some small parts of the code, it is preferred to use integer
> instead. Btw, to force variable as integer, I can use int(aa). However,
> I tried to force variable as PetscInt using PetscInt(aa) but it can't work.
> Is there any way I can make it work?
I think you just define a PetscInt variable and use assignment.
   Matt
> Thanks.
> >> Thanks!
> >>>> On Aug 30, 2018, at 9:35 PM, TAY wee-beng <zonexo at gmail.com> wrote:
> >>>> On 31/8/2018 10:21 AM, Matthew Knepley wrote:
> >>>>> On Thu, Aug 30, 2018 at 10:17 PM TAY wee-beng <zonexo at gmail.com>
> wrote:
> >>>>> Hi,
> >>>>> Due to my increase grid size, I have to go 64bit. I compiled the
> 64bit
> >>>>> PETSc w/o error. However, when I tried to compile my code using the
> >>>>> 64bit PETSc, I got the error below. May I know why is this so?
> >>>>> What changes should I make?
> >>>>> Is it possible that you did not declare some inputs as PetscInt, so
> the interface check is failing?
> >>>>>     Matt
> >>>> Hi,
> >>>> I'm using the standard
> >>>> integer ::
> >>>> real(8) ::
> >>>> for some variables. For some others relating to PETSc, I use PetscInt.
> >>>> Should I change all to PetscInt and PetscReal?
> >>>> Currently, I use real(8) for all real values. If I change all to
> PetscReal, will PetscReal be real or real(8) by default?
> >>>> Thanks!
> >>>>> [tsltaywb at nus02 ibm3d_IIB_mpi]$ make -f makefile_2018
> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
> >>>>> -g -ip -ipo -O3 -c -fPIC  -save kinefunc.F90
> >>>>> -g -ip -ipo -O3 -c -fPIC  -save  -w
> -I/home/users/nus/tsltaywb/propeller/lib/petsc-3.9.3_intel_2018_64bit_rel/include
> -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
> >>>>> global.F90
> >>>>> global.F90(979): error #6285: There is no matching specific
> subroutine
> >>>>> for this generic subroutine call.   [DMDACREATE3D]
> >>>>> call
> DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&
> >>>>> global.F90(989): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> global.F90(997): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> global.F90(1005): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> global.F90(1013): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> global.F90(1021): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> global.F90(1029): error #6285: There is no matching specific
> subroutine
> >>>>>       call
> >>>>> compilation aborted for global.F90 (code 1)
> >>>>> Thank you very much.
> >>>>> Yours sincerely,
> >>>>> TAY Wee-Beng (Zheng Weiming) 郑伟明
> >>>>> Personal research webpage: http://tayweebeng.wixsite.com/website
> >>>>> Youtube research showcase:
> https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
> >>>>> linkedin: www.linkedin.com/in/tay-weebeng
> >>>>> What most experimenters take for granted before they begin their
> experiments lead.
> >>>>> -- Norbert Wiener
> >>>>> https://www.cse.buffalo.edu/~knepley/
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20180905/acc184cf/attachment.html>
