[petsc-users] Problem compiling with 64bit PETSc
TAY wee-beng
zonexo at gmail.com
Wed Sep 5 02:27:34 CDT 2018
On 31/8/2018 10:43 AM, Smith, Barry F. wrote:
>> On Aug 30, 2018, at 9:40 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>> On 31/8/2018 10:38 AM, Smith, Barry F. wrote:
>>> PetscReal is by default real(8) you can leave those alone
>>> Any integer you pass to a PETSc routine needs to be declared as PetscInt (not integer) otherwise the 64 bit indices stuff won't work.
>>> Barry
>> Hi,
>> ok, I got it. Btw, is it advisable to change all integer in my code to PetscInt?
>> Will it cause any conflict or waste a lot of memory?
>> Or should I only change those related to PETSc?
> That is up to you. Since you probably pass the values between PETSc and non-PETSc part of the code it is probably easier just to make all the integer PetscInt instead. No performance difference that you can measure by keeping a few integer around.
> Barry
For some small parts of the code, it is preferred to use integer
instead. Btw, to force variable as integer, I can use int(aa). However,
I tried to force variable as PetscInt using PetscInt(aa) but it can't work.
Is there any way I can make it work?
Thanks.
>> Thanks!
>>>> On Aug 30, 2018, at 9:35 PM, TAY wee-beng <zonexo at gmail.com> wrote:
>>>> On 31/8/2018 10:21 AM, Matthew Knepley wrote:
>>>>> On Thu, Aug 30, 2018 at 10:17 PM TAY wee-beng <zonexo at gmail.com> wrote:
>>>>> Hi,
>>>>> Due to my increase grid size, I have to go 64bit. I compiled the 64bit
>>>>> PETSc w/o error. However, when I tried to compile my code using the
>>>>> 64bit PETSc, I got the error below. May I know why is this so?
>>>>> What changes should I make?
>>>>> Is it possible that you did not declare some inputs as PetscInt, so the interface check is failing?
>>>>> Matt
>>>> Hi,
>>>> I'm using the standard
>>>> integer ::
>>>> real(8) ::
>>>> for some variables. For some others relating to PETSc, I use PetscInt.
>>>> Should I change all to PetscInt and PetscReal?
>>>> Currently, I use real(8) for all real values. If I change all to PetscReal, will PetscReal be real or real(8) by default?
>>>> Thanks!
>>>>> [tsltaywb at nus02 ibm3d_IIB_mpi]$ make -f makefile_2018
>>>>> /app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/bin/mpif90
>>>>> -g -ip -ipo -O3 -c -fPIC -save kinefunc.F90
>>>>> -g -ip -ipo -O3 -c -fPIC -save -w
>>>>> -I/home/users/nus/tsltaywb/propeller/lib/petsc-3.9.3_intel_2018_64bit_rel/include
>>>>> -I/app/intel/xe2018/compilers_and_libraries_2018.0.128/linux/mpi/intel64/include
>>>>> global.F90
>>>>> global.F90(979): error #6285: There is no matching specific subroutine
>>>>> for this generic subroutine call. [DMDACREATE3D]
>>>>> call
>>>>> DMDACreate3d(MPI_COMM_WORLD,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DM_BOUNDARY_NONE,DMDA_STENCIL_STAR,size_x,size_y,&
>>>>> global.F90(989): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> global.F90(997): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> global.F90(1005): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> global.F90(1013): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> global.F90(1021): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> global.F90(1029): error #6285: There is no matching specific subroutine
>>>>> call
>>>>> compilation aborted for global.F90 (code 1)
>>>>> Thank you very much.
>>>>> Yours sincerely,
>>>>> TAY Wee-Beng (Zheng Weiming) 郑伟明
>>>>> Personal research webpage: http://tayweebeng.wixsite.com/website
>>>>> Youtube research showcase: https://www.youtube.com/channel/UC72ZHtvQNMpNs2uRTSToiLA
>>>>> linkedin: www.linkedin.com/in/tay-weebeng
>>>>> What most experimenters take for granted before they begin their experiments is infinitely more interesting than any results to which their experiments lead.
>>>>> -- Norbert Wiener
>>>>> https://www.cse.buffalo.edu/~knepley/
