[petsc-users] Two applications with PETSc
Guido Giuntoli gagiuntoli at gmail.com
Wed Oct 31 15:23:55 CDT 2018
This is what I need ! Thank you Matt !
El El mié, 31 oct 2018 a las 19:53, Matthew Knepley <knepley at gmail.com>
escribió:
> On Wed, Oct 31, 2018 at 1:34 PM Guido Giuntoli via petsc-users <
> petsc-users at mcs.anl.gov> wrote:
>> Hi, I have two codes that use PETSc. The first one is parallel and uses
>> MPI and the other doesn't uses MPI (uses sequencial Mats and Vecs because
>> the problem is smaller). I need now to couple both codes and my question is
>> how do I deal with the PetscInitialize in the sequential code ? I know that
>> PetscInitialize calls MPI_Init so I think if the first code just called
>> MPI_Init before I will get an error or not ? Every process in the parallel
>> code needs to use the functions of the sequential code, so every process
>> will call PetscInitialize of the sequential code.
>> constrain : I would like to use the same compiled library of petsc to
>> link both codes.
> You should only call PetscInitialize() once (just like MPIInit()). You can
> check whether it has been called using PetscInitialized().
>   Thanks,
>     Matt
>> Thank you, Guido.
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181031/86e2766e/attachment.html>
