[petsc-users] Two applications with PETSc
Danyang Su danyang.su at gmail.com
Wed Oct 31 13:54:06 CDT 2018
Hi Guido,
You can try to use preprocessor flags in you code to separate sequential
code and parallel code. I am not sure if PETSc has a better way to do
this. Just a suggestion.
Danyang
On 2018-10-31 10:24 a.m., Guido Giuntoli via petsc-users wrote:
> Hi, I have two codes that use PETSc. The first one is parallel and
> uses MPI and the other doesn't uses MPI (uses sequencial Mats and Vecs
> because the problem is smaller). I need now to couple both codes and
> my question is how do I deal with the PetscInitialize in the
> sequential code ? I know that PetscInitialize calls MPI_Init so I
> think if the first code just called MPI_Init before I will get an
> error or not ? Every process in the parallel code needs to use the
> functions of the sequential code, so every process will call
> PetscInitialize of the sequential code.
> constrain : I would like to use the same compiled library of petsc to
> link both codes.
> Thank you, Guido.
