[petsc-users] DIVERGED_NANORING with PC GAMG
Thibaut Appel t.appel17 at imperial.ac.uk
Wed Oct 31 08:14:48 CDT 2018
Hi Matthew,
Which database option are you referring to?
I tried to add -fieldsplit_mg_levels_ksp_type gmres (and
-fieldsplit_mg_levels_ksp_max_it 4 for another run) to my options (cf.
below) which starts the iterations but it takes 1 hour for PETSc to do
13 of them so it must be wrong.
Reminder: my baseline database options line reads
-ksp_view_pre -ksp_monitor -ksp_converged_reason \
-ksp_rtol 1.0e-8 -ksp_gmres_restart 300 \
-ksp_type fgmres \
-pc_type fieldsplit \
-pc_fieldsplit_type multiplicative \
-pc_fieldsplit_block_size 3 \
-pc_fieldsplit_0_fields 0   \
-pc_fieldsplit_1_fields 1   \
-pc_fieldsplit_2_fields 2   \
-fieldsplit_pc_type gamg    \
-fieldsplit_ksp_type gmres  \
-fieldsplit_ksp_rtol 1.0e-8
which gives
KSP Object: 1 MPI processes
   type: fgmres
     restart=300, using Classical (unmodified) Gram-Schmidt
Orthogonalization with no iterative refinement
     happy breakdown tolerance 1e-30
   maximum iterations=10000, initial guess is zero
   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
   left preconditioning
   using DEFAULT norm type for convergence test
PC Object: 1 MPI processes
   type: fieldsplit
   PC has not been set up so information may be incomplete
     FieldSplit with MULTIPLICATIVE composition: total splits = 3,
blocksize = 3
     Solver info for each split is in the following KSP objects:
   Split number 0 Fields  0
   KSP Object: (fieldsplit_0_) 1 MPI processes
     type: preonly
     tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
   PC Object: (fieldsplit_0_) 1 MPI processes
     type not yet set
   Split number 1 Fields  1
   KSP Object: (fieldsplit_1_) 1 MPI processes
     type: preonly
   PC Object: (fieldsplit_1_) 1 MPI processes
     type not yet set
   Split number 2 Fields  2
   KSP Object: (fieldsplit_2_) 1 MPI processes
     type: preonly
   PC Object: (fieldsplit_2_) 1 MPI processes
     type not yet set
   linear system matrix = precond matrix:
   Mat Object: 1 MPI processes
     type: seqaij
     rows=52500, cols=52500
     total: nonzeros=1127079, allocated nonzeros=1128624
     total number of mallocs used during MatSetValues calls =0
       not using I-node routines
   0 KSP Residual norm 3.583290589961e+00
[0]PETSC ERROR: --------------------- Error Message
[0]PETSC ERROR: Petsc has generated inconsistent data
[0]PETSC ERROR: Eigen estimator failed: DIVERGED_NANORINF at iteration
0[0]PETSC ERROR: Petsc Release Version 3.10.2, unknown
[0]PETSC ERROR: Configure options --PETSC_ARCH=msi_cplx_debug
--with-scalar-type=complex --with-precision=double --with-debugging=1
--with-valgrind=1 --with-debugger=gdb --with-fortran-kernels=1
--download-mpich --download-hwloc --download-fblaslapack
--download-scalapack --download-metis --download-parmetis
--download-ptscotch --download-mumps --download-slepc
[0]PETSC ERROR: #1 KSPSolve_Chebyshev() line 381 in
/home/thibaut/Packages/petsc/src/ksp/ksp/impls/cheby/cheby.c
[0]PETSC ERROR: #2 KSPSolve() line 780 in
/home/thibaut/Packages/petsc/src/ksp/ksp/interface/itfunc.c
[0]PETSC ERROR: #3 PCMGMCycle_Private() line 20 in
/home/thibaut/Packages/petsc/src/ksp/pc/impls/mg/mg.c
[0]PETSC ERROR: #4 PCApply_MG() line 377 in
[0]PETSC ERROR: #5 PCApply() line 462 in
/home/thibaut/Packages/petsc/src/ksp/pc/interface/precon.c
[0]PETSC ERROR: #6 KSP_PCApply() line 281 in
/home/thibaut/Packages/petsc/include/petsc/private/kspimpl.h
[0]PETSC ERROR: #7 KSPInitialResidual() line 67 in
/home/thibaut/Packages/petsc/src/ksp/ksp/interface/itres.c
[0]PETSC ERROR: #8 KSPSolve_GMRES() line 233 in
/home/thibaut/Packages/petsc/src/ksp/ksp/impls/gmres/gmres.c
[0]PETSC ERROR: #9 KSPSolve() line 780 in
[0]PETSC ERROR: #10 PCApply_FieldSplit() line 1107 in
/home/thibaut/Packages/petsc/src/ksp/pc/impls/fieldsplit/fieldsplit.c
[0]PETSC ERROR: #11 PCApply() line 462 in
[0]PETSC ERROR: #12 KSP_PCApply() line 281 in
[0]PETSC ERROR: #13 KSPFGMRESCycle() line 166 in
/home/thibaut/Packages/petsc/src/ksp/ksp/impls/gmres/fgmres/fgmres.c
[0]PETSC ERROR: #14 KSPSolve_FGMRES() line 291 in
[0]PETSC ERROR: #15 KSPSolve() line 780 in
Thibaut
On 30/10/2018 23:12, Matthew Knepley wrote:
> On Tue, Oct 30, 2018 at 5:21 PM Appel, Thibaut via petsc-users
> <petsc-users at mcs.anl.gov <mailto:petsc-users at mcs.anl.gov>> wrote:
>     Dear users,
>     Following a suggestion from Matthew Knepley I’ve been trying to
>     apply fieldsplit/gamg for my set of PDEs but I’m still
>     encountering issues despite various tests. pc_gamg simply won’t start.
>     Note that direct solvers always yield the correct, physical result.
>     Removing the fieldsplit to focus on the gamg bit
> This is a mistake I think because you want a simpler operator to try
> GAMG on.
> Can you go back to splitting the system, and try using GMRES as the
> smoother. Its important to see
> whether the smoother makes no progress, or the coarse correction stinks.
>   Thanks,
>      Matt
>     and trying to solve the linear system on a modest size problem
>     still gives, with
>     '-ksp_monitor -ksp_rtol 1.0e-10 -ksp_gmres_restart 300 -ksp_type
>     gmres -pc_type gamg'
>     [3]PETSC ERROR: --------------------- Error Message
>     [3]PETSC ERROR: Petsc has generated inconsistent data
>     [3]PETSC ERROR: Have un-symmetric graph (apparently). Use
>     '-(null)pc_gamg_sym_graph true' to symetrize the graph or
>     '-(null)pc_gamg_threshold -1' if the matrix is structurally symmetric.
>     And since then, after adding '-pc_gamg_sym_graph true' I have been
>     getting
>     -ksp_chebyshev_esteig_noisy 0/1 does not change anything
>     Knowing that Chebyshev eigen estimator needs a positive spectrum I
>     tried ‘-mg_levels_ksp_type gmres’ but iterations would just go on
>     endlessly.
>     It seems that I have indeed eigenvalues of rather high magnitude
>     in the spectrum of my operator without being able to determine the
>     reason.
>     The eigenvectors look like small artifacts at the wall-inflow or
>     wall-outflow corners with zero anywhere else but I do not know how
>     to interpret this.
>     Equations are time-harmonic linearized Navier-Stokes to which a
>     forcing is applied, there’s no time-marching.
>     Matrix is formed with a MPIAIJ type. The formulation is
>     incompressible, in complex arithmetic and the 2D physical domain
>     is mapped to a logically rectangular, regular collocated grid with
>     a high-order finite difference method.
>     I determine the ownership of the rows/degrees of freedom of the
>     matrix with PetscSplitOwnership and I’m not using DMDA.
>     The Fortran application code is memory-leak free and has undergone
>     a strict verification/validation procedure for different
>     variations of the PDEs.
>     If there’s any problem with the matrix what could help for the
>     diagnostic? At this point I’m running out of ideas so I would
>     really appreciate additional suggestions and discussions.
>     Thanks for your continued support,
>     Thibaut
> experiments is infinitely more interesting than any results to which
> their experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181031/317e083d/attachment.html>
