[petsc-users] Convergence of AMG
Manav Bhatia bhatiamanav at gmail.com
Tue Oct 30 10:32:06 CDT 2018
> On Oct 29, 2018, at 4:07 PM, Mark Adams <mfadams at lbl.gov> wrote:
> * the two level results tell us that MG is not doing well on the coarse grids. So the coarse grids are the problem.
> * Do not worry about timing now. Get the math correct. The two level solve is not meant to be a solution just a diagnostic so don't try to optimize it by squaring the graph. Use -pc_gamg_square_graph 0.
> * It looks like you don't need 4 smoothing steps but lets keep it and we can dial it back later.
> * This table is interesting. First, you had about 12 iterations earlier and I think your rtol was tighter than the default (so the iteration could should go down not up). Do you know what change here?
I maintained the same tolerance using -ksp_rtol 1.e-8 (did not copy this into the parameter list in the previous email).
The 2 level iterations was a typo and should have been 12.  I have corrected the table here:
-mg_levels_ksp_max_it 4 -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-8
Case#  |  #levels   |    #KSP Iters
     1      |     2         |       12
     2      |     3         |       18
     3      |     4         |       40
     4      |     5         |       59
> Note, even though -mg_levels_ksp_max_it is not in the ksp_view it does work. It is syntactic sugar to just add it to all levels like you did manually.
> Anyway, these number look reasonable. It is interesting that 3 levels ran well but the 4th level ran poorly. This implies we want to slow down coarsening on these levels, but ...
> First can you please rerun this experiment with -pc_gamg_square_graph 0.
Following is the summary of the results with -pc_gamg_square_graph 0
-mg_levels_ksp_max_it 4 -pc_gamg_square_graph 0 -pc_gamg_threshold 0. -ksp_rtol 1.e-8
     5      |     2        |         9
     6      |     3        |       13
     7      |     4        |       31
     8      |     5        |       50
> Also, please run with -info. This is very noisy but you can grep on "GAMG" and send that output to us (about 15 lines).
I have included information about all 8 cases below.
Thanks for your help!
-Manav
> Thanks,
> Mark
Case 1)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 2
Dhcp-90-164:tmp manav$ cat t | grep "KSP\ Res"
    0 KSP Residual norm 2.980759132912e+01
    1 KSP Residual norm 1.268404746671e+00
    2 KSP Residual norm 1.420311012425e-01
    3 KSP Residual norm 3.026536678757e-02
    4 KSP Residual norm 6.511170312990e-03
    5 KSP Residual norm 1.539620841789e-03
    6 KSP Residual norm 3.655528499924e-04
    7 KSP Residual norm 8.111524453985e-05
    8 KSP Residual norm 1.995956470679e-05
    9 KSP Residual norm 4.397662980825e-06
   10 KSP Residual norm 9.636956929325e-07
   11 KSP Residual norm 3.013384202118e-07
   12 KSP Residual norm 1.867699579372e-07
Dhcp-90-164:tmp manav$ cat t | grep GAMG
[0] PCSetUp_GAMG(): level 0) N=543606, n data rows=6, n data cols=6, nnz/row (ave)=54, np=4
[0] PCGAMGFilterGraph(): 	 98.7979% nnz after filtering, with threshold 0., 8.95943 nnz ave. (N=90601)
[0] PCGAMGCoarsen_AGG(): Square Graph on level 1 of 1 to square
[0] PCGAMGProlongator_AGG(): New grid 6837 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.748254e+00 min=6.352623e-02 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 10296 with simple aggregation
[0] PCSetUp_GAMG(): 1) N=41022, n data cols=6, nnz/row (ave)=69, 1 active pes
[0] PCSetUp_GAMG(): 2 levels, grid complexity = 1.0976
Case 2)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 3
    0 KSP Residual norm 1.721859579323e+01
    1 KSP Residual norm 2.372150715400e+00
    2 KSP Residual norm 4.332444773735e-01
    3 KSP Residual norm 1.828644450393e-01
    4 KSP Residual norm 6.508336322670e-02
    5 KSP Residual norm 2.352085101499e-02
    6 KSP Residual norm 9.165114885090e-03
    7 KSP Residual norm 3.674781085969e-03
    8 KSP Residual norm 1.331249870878e-03
    9 KSP Residual norm 4.566260302483e-04
   10 KSP Residual norm 1.795556967223e-04
   11 KSP Residual norm 6.793314859559e-05
   12 KSP Residual norm 2.504121594312e-05
   13 KSP Residual norm 9.167163291488e-06
   14 KSP Residual norm 3.283556007932e-06
   15 KSP Residual norm 1.277586362108e-06
   16 KSP Residual norm 4.852580652992e-07
   17 KSP Residual norm 1.901791545937e-07
   18 KSP Residual norm 7.974015462515e-08
[0] PCSetUp_GAMG(): 1) N=41022, n data cols=6, nnz/row (ave)=69, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 11.6521 nnz ave. (N=6837)
[0] PCGAMGProlongator_AGG(): New grid 1121 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.785527e+00 min=6.042089e-02 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 1656 with simple aggregation
[0] PCSetUp_GAMG(): 2) N=6726, n data cols=6, nnz/row (ave)=140, 1 active pes
[0] PCSetUp_GAMG(): 3 levels, grid complexity = 1.12982
Case 3)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 4
    0 KSP Residual norm 5.715310219090e+00
    1 KSP Residual norm 1.702306568500e+00
    2 KSP Residual norm 1.105404714191e+00
    3 KSP Residual norm 7.521070321363e-01
    4 KSP Residual norm 5.151770148497e-01
    5 KSP Residual norm 3.407231098045e-01
    6 KSP Residual norm 2.154066019733e-01
    7 KSP Residual norm 1.320975463963e-01
    8 KSP Residual norm 8.464181469022e-02
    9 KSP Residual norm 5.404783722947e-02
   10 KSP Residual norm 3.571728349786e-02
   11 KSP Residual norm 2.363141413294e-02
   12 KSP Residual norm 1.530000070717e-02
   13 KSP Residual norm 9.398576202667e-03
   14 KSP Residual norm 5.389891497192e-03
   15 KSP Residual norm 3.308851504727e-03
   16 KSP Residual norm 2.233599324934e-03
   17 KSP Residual norm 1.471510415641e-03
   18 KSP Residual norm 9.214853138234e-04
   19 KSP Residual norm 6.090808616289e-04
   20 KSP Residual norm 4.205193238717e-04
   21 KSP Residual norm 2.728384192436e-04
   22 KSP Residual norm 1.647370935175e-04
   23 KSP Residual norm 1.007397471037e-04
   24 KSP Residual norm 6.133965622058e-05
   25 KSP Residual norm 3.650073757918e-05
   26 KSP Residual norm 2.220817401390e-05
   27 KSP Residual norm 1.423846811011e-05
   28 KSP Residual norm 9.147106610671e-06
   29 KSP Residual norm 5.622102212398e-06
   30 KSP Residual norm 3.427704849314e-06
   31 KSP Residual norm 2.562333599882e-06
   32 KSP Residual norm 1.780393486817e-06
   33 KSP Residual norm 1.175933486658e-06
   34 KSP Residual norm 7.633724873183e-07
   35 KSP Residual norm 4.635656121553e-07
   36 KSP Residual norm 2.809545347534e-07
   37 KSP Residual norm 1.736631971561e-07
   38 KSP Residual norm 1.074049251439e-07
   39 KSP Residual norm 6.374646169363e-08
   40 KSP Residual norm 4.140669801911e-08
[0] PCSetUp_GAMG(): 2) N=6726, n data cols=6, nnz/row (ave)=140, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 23.3696 nnz ave. (N=1121)
[0] PCGAMGProlongator_AGG(): New grid 107 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=3.003329e+00 min=8.421562e-02 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 144 with simple aggregation
[0] PCSetUp_GAMG(): 3) N=642, n data cols=6, nnz/row (ave)=154, 1 active pes
[0] PCSetUp_GAMG(): 4 levels, grid complexity = 1.13323
Case 4)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 1 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 5
    0 KSP Residual norm 1.796966525877e+00
    1 KSP Residual norm 1.272395001001e+00
    2 KSP Residual norm 9.587765774342e-01
    3 KSP Residual norm 7.503468727302e-01
    4 KSP Residual norm 5.929828008661e-01
    5 KSP Residual norm 4.667907393525e-01
    6 KSP Residual norm 3.582573847190e-01
    7 KSP Residual norm 2.641549535092e-01
    8 KSP Residual norm 1.897005575664e-01
    9 KSP Residual norm 1.290185919854e-01
   10 KSP Residual norm 8.674970372217e-02
   11 KSP Residual norm 5.719457030929e-02
   12 KSP Residual norm 3.670199440851e-02
   13 KSP Residual norm 2.279854011416e-02
   14 KSP Residual norm 1.413541409138e-02
   15 KSP Residual norm 9.904419724774e-03
   16 KSP Residual norm 7.479600408120e-03
   17 KSP Residual norm 5.653470278882e-03
   18 KSP Residual norm 4.357609222840e-03
   19 KSP Residual norm 3.501603455533e-03
   20 KSP Residual norm 2.740008551458e-03
   21 KSP Residual norm 2.000305455177e-03
   22 KSP Residual norm 1.465665578257e-03
   23 KSP Residual norm 1.063641050628e-03
   24 KSP Residual norm 7.320397918812e-04
   25 KSP Residual norm 4.987179366244e-04
   26 KSP Residual norm 3.531130935050e-04
   27 KSP Residual norm 2.534997938742e-04
   28 KSP Residual norm 1.815505756854e-04
   29 KSP Residual norm 1.303047003006e-04
   30 KSP Residual norm 9.159509138706e-05
   31 KSP Residual norm 7.324246273743e-05
   32 KSP Residual norm 5.465350505655e-05
   33 KSP Residual norm 3.876661576537e-05
   34 KSP Residual norm 2.792720150402e-05
   35 KSP Residual norm 2.108207616943e-05
   36 KSP Residual norm 1.611370701356e-05
   37 KSP Residual norm 1.208049584171e-05
   38 KSP Residual norm 9.075511243294e-06
   39 KSP Residual norm 7.091514153440e-06
   40 KSP Residual norm 5.623979353049e-06
   41 KSP Residual norm 4.346769151236e-06
   42 KSP Residual norm 3.197496840488e-06
   43 KSP Residual norm 2.265919711506e-06
   44 KSP Residual norm 1.600975191547e-06
   45 KSP Residual norm 1.132335469737e-06
   46 KSP Residual norm 7.710870825137e-07
   47 KSP Residual norm 5.064951347280e-07
   48 KSP Residual norm 3.448475289519e-07
   49 KSP Residual norm 2.450120965032e-07
   50 KSP Residual norm 1.826746152120e-07
   51 KSP Residual norm 1.445084170865e-07
   52 KSP Residual norm 1.200408904185e-07
   53 KSP Residual norm 9.882182031280e-08
   54 KSP Residual norm 7.914655725555e-08
   55 KSP Residual norm 6.110632924313e-08
   56 KSP Residual norm 4.632304250505e-08
   57 KSP Residual norm 3.242693236988e-08
   58 KSP Residual norm 2.195784301351e-08
   59 KSP Residual norm 1.571496587971e-08
[0] PCSetUp_GAMG(): 3) N=642, n data cols=6, nnz/row (ave)=154, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 24.5 nnz ave. (N=107)
[0] PCGAMGProlongator_AGG(): New grid 9 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.863578e+00 min=9.275407e-02 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 6 with simple aggregation
[0] PCSetUp_GAMG(): 4) N=54, n data cols=6, nnz/row (ave)=54, 1 active pes
[0] PCSetUp_GAMG(): 5 levels, grid complexity = 1.13333
Case 5)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 0 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 2
    0 KSP Residual norm 4.658748806834e+01
    1 KSP Residual norm 6.825811660437e-01
    2 KSP Residual norm 3.642264109013e-02
    3 KSP Residual norm 2.013016230540e-03
    4 KSP Residual norm 2.013432241615e-04
    5 KSP Residual norm 2.105457376227e-05
    6 KSP Residual norm 3.003346327786e-06
    7 KSP Residual norm 1.445664726245e-06
    8 KSP Residual norm 6.952678680043e-07
    9 KSP Residual norm 3.813304720986e-07
[0] PCGAMGProlongator_AGG(): New grid 16817 nodes
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 25260 with simple aggregation
[0] PCSetUp_GAMG(): 1) N=100902, n data cols=6, nnz/row (ave)=103, 1 active pes
[0] PCSetUp_GAMG(): 2 levels, grid complexity = 1.35717
Case 6)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 0 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 3
    0 KSP Residual norm 2.700027956285e+01
    1 KSP Residual norm 2.081487493276e+00
    2 KSP Residual norm 2.504352351366e-01
    3 KSP Residual norm 7.222719417818e-02
    4 KSP Residual norm 1.769085428189e-02
    5 KSP Residual norm 4.200829546873e-03
    6 KSP Residual norm 1.100496697039e-03
    7 KSP Residual norm 2.880192907717e-04
    8 KSP Residual norm 7.621296303148e-05
    9 KSP Residual norm 1.923264828609e-05
   10 KSP Residual norm 4.962521087771e-06
   11 KSP Residual norm 1.223640145242e-06
   12 KSP Residual norm 3.668999985201e-07
   13 KSP Residual norm 1.828878545694e-07
[0] PCSetUp_GAMG(): 1) N=100902, n data cols=6, nnz/row (ave)=103, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 17.2399 nnz ave. (N=16817)
[0] PCGAMGProlongator_AGG(): New grid 2021 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=1.704298e+00 min=6.370030e-02 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 3006 with simple aggregation
[0] PCSetUp_GAMG(): 2) N=12126, n data cols=6, nnz/row (ave)=172, 1 active pes
[0] PCSetUp_GAMG(): 3 levels, grid complexity = 1.42875
Case 7)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 0 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 4
    0 KSP Residual norm 9.908487889752e+00
    1 KSP Residual norm 2.252812343792e+00
    2 KSP Residual norm 1.165408110334e+00
    3 KSP Residual norm 6.434735893158e-01
    4 KSP Residual norm 3.696466541726e-01
    5 KSP Residual norm 2.135677187677e-01
    6 KSP Residual norm 1.257757438010e-01
    7 KSP Residual norm 7.128420785165e-02
    8 KSP Residual norm 3.976090525850e-02
    9 KSP Residual norm 2.279000353245e-02
   10 KSP Residual norm 1.300701287311e-02
   11 KSP Residual norm 7.498254128331e-03
   12 KSP Residual norm 4.288501173737e-03
   13 KSP Residual norm 2.316089581521e-03
   14 KSP Residual norm 1.263802234905e-03
   15 KSP Residual norm 7.296829650365e-04
   16 KSP Residual norm 4.261675876945e-04
   17 KSP Residual norm 2.440548986676e-04
   18 KSP Residual norm 1.436965272125e-04
   19 KSP Residual norm 8.010925146489e-05
   20 KSP Residual norm 4.339850994759e-05
   21 KSP Residual norm 2.411926753762e-05
   22 KSP Residual norm 1.306205068099e-05
   23 KSP Residual norm 7.542931204731e-06
   24 KSP Residual norm 4.283178968440e-06
   25 KSP Residual norm 2.483127922661e-06
   26 KSP Residual norm 1.517894242402e-06
   27 KSP Residual norm 8.801147250084e-07
   28 KSP Residual norm 5.088326120723e-07
   29 KSP Residual norm 2.732311721999e-07
   30 KSP Residual norm 1.450174505696e-07
   31 KSP Residual norm 9.861763824710e-08
[0] PCSetUp_GAMG(): 2) N=12126, n data cols=6, nnz/row (ave)=172, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 28.7325 nnz ave. (N=2021)
[0] PCGAMGProlongator_AGG(): New grid 161 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.212396e+00 min=1.149492e-01 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 204 with simple aggregation
[0] PCSetUp_GAMG(): 3) N=966, n data cols=6, nnz/row (ave)=176, 1 active pes
[0] PCSetUp_GAMG(): 4 levels, grid complexity = 1.43458
Case 8)  -mg_levels_ksp_max_it 4 -pc_gamg_square_graph 0 -pc_gamg_threshold 0. -ksp_rtol 1.e-8 -pc_mg_levels 5
    0 KSP Residual norm 2.218294876305e+00
    1 KSP Residual norm 1.632572879485e+00
    2 KSP Residual norm 1.182643328612e+00
    3 KSP Residual norm 8.718741753444e-01
    4 KSP Residual norm 6.533291909118e-01
    5 KSP Residual norm 4.866483224152e-01
    6 KSP Residual norm 3.484903886854e-01
    7 KSP Residual norm 2.348475670124e-01
    8 KSP Residual norm 1.537187403224e-01
    9 KSP Residual norm 1.026536155589e-01
   10 KSP Residual norm 6.824513463193e-02
   11 KSP Residual norm 4.627422220135e-02
   12 KSP Residual norm 3.117616798825e-02
   13 KSP Residual norm 2.081871084553e-02
   14 KSP Residual norm 1.460827781562e-02
   15 KSP Residual norm 1.037979487427e-02
   16 KSP Residual norm 6.886117836686e-03
   17 KSP Residual norm 4.634120402061e-03
   18 KSP Residual norm 2.822150912459e-03
   19 KSP Residual norm 1.699261862470e-03
   20 KSP Residual norm 1.127636890762e-03
   21 KSP Residual norm 7.233233068369e-04
   22 KSP Residual norm 4.545631018082e-04
   23 KSP Residual norm 2.995811344995e-04
   24 KSP Residual norm 1.984480794186e-04
   25 KSP Residual norm 1.339576789380e-04
   26 KSP Residual norm 8.964509794502e-05
   27 KSP Residual norm 6.063175592350e-05
   28 KSP Residual norm 4.271774591608e-05
   29 KSP Residual norm 3.026766800790e-05
   30 KSP Residual norm 2.191056439926e-05
   31 KSP Residual norm 1.813101162702e-05
   32 KSP Residual norm 1.410197450206e-05
   33 KSP Residual norm 9.889952949347e-06
   34 KSP Residual norm 6.488236898017e-06
   35 KSP Residual norm 4.232064596117e-06
   36 KSP Residual norm 2.736230796810e-06
   37 KSP Residual norm 1.829705002417e-06
   38 KSP Residual norm 1.272435477754e-06
   39 KSP Residual norm 8.374839157107e-07
   40 KSP Residual norm 5.423071251782e-07
   41 KSP Residual norm 3.638843185090e-07
   42 KSP Residual norm 2.318570275176e-07
   43 KSP Residual norm 1.494263195512e-07
   44 KSP Residual norm 1.014479883907e-07
   45 KSP Residual norm 7.010792145263e-08
   46 KSP Residual norm 5.302212871376e-08
   47 KSP Residual norm 4.129998076695e-08
   48 KSP Residual norm 3.174687615554e-08
   49 KSP Residual norm 2.425058914303e-08
   50 KSP Residual norm 1.810773091084e-08
[0] PCSetUp_GAMG(): 3) N=966, n data cols=6, nnz/row (ave)=176, 4 active pes
[0] PCGAMGFilterGraph(): 	 100.% nnz after filtering, with threshold 0., 28.2353 nnz ave. (N=161)
[0] PCGAMGProlongator_AGG(): New grid 14 nodes
[0] PCGAMGOptProlongator_AGG(): Smooth P0: max eigen=2.257007e+00 min=1.166837e-01 PC=jacobi
[0] PCGAMGCreateLevel_GAMG(): Number of equations (loc) 18 with simple aggregation
[0] PCSetUp_GAMG(): 4) N=84, n data cols=6, nnz/row (ave)=82, 1 active pes
[0] PCSetUp_GAMG(): 5 levels, grid complexity = 1.43482
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181030/f21e131b/attachment-0001.html>
