[petsc-users] Convergence of AMG
Mark Adams mfadams at lbl.gov
Mon Oct 29 08:14:07 CDT 2018
On Sun, Oct 28, 2018 at 1:17 PM Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
>    I am attempting to solve a Mindlin plate bending problem with AMG
> solver in petsc. This test case is with a mesh of 300x300 elements and
> 543,606 dofs.
>    The discretization includes 6 variables (u, v, w, tx, ty, tz), but only
> three are relevant for plate bending (w, tx, ty).
>    I am calling the solver with the following options:
> -pc_type gamg -pc_gamg_threshold 0. --node-major-dofs -mat_block_size 6
> -ksp_rtol 1.e-8 -ksp_monitor -ksp_converged_reason -ksp_view
>   And the convergence behavior is shown below, along with the ksp_view
> information. Based on notes in the manual, this seems to be subpar
> convergence rate. At the end of the solution the norm of each variable is :
> var: 0: u  : norm: 5.505909e-18
> var: 1: v  : norm: 7.639640e-18
> var: 2: w : norm: 3.901464e-03
> var: 3: tx : norm: 4.403576e-02
> var: 4: ty : norm: 4.403576e-02
> var: 5: tz : norm: 1.148409e-16
So your u,v,tz are inactive? I assume that this looks ok to you.
>   I tried different values of -ksp_rtol from 1e-1 to 1e-8 and this does
> not make a lot of difference in the norms of (w, tx, ty).
>   I do provide the solver with 6 rigid-body vectors to approximate the
> null-space of the problem. Without these the solver shows very poor
> convergence.
So the RBMs helped, that tells me that you did hook it in correctly.
Shells are hard and I don't know what your test case is, so I'm not sure
how bad this is. I can recommend using:
-mg_levels_esteig_ksp_type cg
This will give better eigen estimates for symmetric problems. You want to
coarsen slowly for plates. Start with:
-pc_gamg_square_graph 0
>   I would appreciate advice on possible strategies to improve this
> behavior.
> Thanks,
> Manav
>     0 KSP Residual norm 1.696304497261e+00
>     1 KSP Residual norm 1.120485505777e+00
>     2 KSP Residual norm 8.324222302402e-01
>     3 KSP Residual norm 6.477349534115e-01
>     4 KSP Residual norm 5.080936471292e-01
>     5 KSP Residual norm 4.051099646638e-01
>     6 KSP Residual norm 3.260432664653e-01
>     7 KSP Residual norm 2.560483838143e-01
>     8 KSP Residual norm 2.029943986124e-01
>     9 KSP Residual norm 1.560985741610e-01
>    10 KSP Residual norm 1.163720702140e-01
>    11 KSP Residual norm 8.488411085459e-02
>    12 KSP Residual norm 5.888041729034e-02
>    13 KSP Residual norm 4.027792209980e-02
>    14 KSP Residual norm 2.819048087304e-02
>    15 KSP Residual norm 1.904674196962e-02
>    16 KSP Residual norm 1.289302447822e-02
>    17 KSP Residual norm 9.162203296376e-03
>    18 KSP Residual norm 7.016781679507e-03
>    19 KSP Residual norm 5.399170865328e-03
>    20 KSP Residual norm 4.254385887482e-03
>    21 KSP Residual norm 3.530831740621e-03
>    22 KSP Residual norm 2.946780747923e-03
>    23 KSP Residual norm 2.339361361128e-03
>    24 KSP Residual norm 1.815072489282e-03
>    25 KSP Residual norm 1.408814185342e-03
>    26 KSP Residual norm 1.063795714320e-03
>    27 KSP Residual norm 7.828540233117e-04
>    28 KSP Residual norm 5.683910750067e-04
>    29 KSP Residual norm 4.131151010250e-04
>    30 KSP Residual norm 3.065608221019e-04
>    31 KSP Residual norm 2.634114273459e-04
>    32 KSP Residual norm 2.198180137626e-04
>    33 KSP Residual norm 1.748956510799e-04
>    34 KSP Residual norm 1.317539710010e-04
>    35 KSP Residual norm 9.790121566055e-05
>    36 KSP Residual norm 7.465935386094e-05
>    37 KSP Residual norm 5.689506626052e-05
>    38 KSP Residual norm 4.413136619126e-05
>    39 KSP Residual norm 3.512194236402e-05
>    40 KSP Residual norm 2.877755408287e-05
>    41 KSP Residual norm 2.340080556431e-05
>    42 KSP Residual norm 1.904544450345e-05
>    43 KSP Residual norm 1.504723478235e-05
>    44 KSP Residual norm 1.141381950576e-05
>    45 KSP Residual norm 8.206151384599e-06
>    46 KSP Residual norm 5.911426091276e-06
>    47 KSP Residual norm 4.233669089283e-06
>    48 KSP Residual norm 2.898052944223e-06
>    49 KSP Residual norm 2.023556779973e-06
>    50 KSP Residual norm 1.459108043935e-06
>    51 KSP Residual norm 1.097335545865e-06
>    52 KSP Residual norm 8.440457332262e-07
>    53 KSP Residual norm 6.705616854004e-07
>    54 KSP Residual norm 5.404888680234e-07
>    55 KSP Residual norm 4.391368084979e-07
>    56 KSP Residual norm 3.697063014621e-07
>    57 KSP Residual norm 3.021772094146e-07
>    58 KSP Residual norm 2.479354520792e-07
>    59 KSP Residual norm 2.013077841968e-07
>    60 KSP Residual norm 1.553159612793e-07
>    61 KSP Residual norm 1.400784224898e-07
>    62 KSP Residual norm 9.707453662195e-08
>    63 KSP Residual norm 7.263173080146e-08
>    64 KSP Residual norm 5.593723572132e-08
>    65 KSP Residual norm 4.448788809586e-08
>    66 KSP Residual norm 3.613992590778e-08
>    67 KSP Residual norm 2.946099051876e-08
>    68 KSP Residual norm 2.408053564170e-08
>    69 KSP Residual norm 1.945257374856e-08
>    70 KSP Residual norm 1.572494535110e-08
> KSP Object: 4 MPI processes
>   type: gmres
>     restart=30, using Classical (unmodified) Gram-Schmidt
> Orthogonalization with no iterative refinement
>     happy breakdown tolerance 1e-30
>   maximum iterations=10000, initial guess is zero
>   tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
>   left preconditioning
>   using PRECONDITIONED norm type for convergence test
> PC Object: 4 MPI processes
>   type: gamg
>     type is MULTIPLICATIVE, levels=6 cycles=v
>       Cycles per PCApply=1
>       Using externally compute Galerkin coarse grid matrices
>       GAMG specific options
>         Threshold for dropping small values in graph on each level =   0.
>   0.   0.   0.
>         Threshold scaling factor for each level not specified = 1.
>         AGG specific options
>           Symmetric graph false
>           Number of levels to square graph 1
>           Number smoothing steps 1
>   Coarse grid solver -- level -------------------------------
>     KSP Object: (mg_coarse_) 4 MPI processes
>       type: preonly
>       tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
>       using NONE norm type for convergence test
>     PC Object: (mg_coarse_) 4 MPI processes
>       type: bjacobi
>         number of blocks = 4
>         Local solve is same for all blocks, in the following KSP and PC
> objects:
>       KSP Object: (mg_coarse_sub_) 1 MPI processes
>         type: preonly
>         maximum iterations=1, initial guess is zero
>       PC Object: (mg_coarse_sub_) 1 MPI processes
>         type: lu
>           out-of-place factorization
>           tolerance for zero pivot 2.22045e-14
>           using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
>           matrix ordering: nd
>           factor fill ratio given 5., needed 1.
>             Factored matrix follows:
>               Mat Object: 1 MPI processes
>                 type: seqaij
>                 rows=6, cols=6, bs=6
>                 package used to perform factorization: petsc
>                 total: nonzeros=36, allocated nonzeros=36
>                 total number of mallocs used during MatSetValues calls =0
>                   using I-node routines: found 2 nodes, limit used is 5
>         linear system matrix = precond matrix:
>           type: seqaij
>       Mat Object: 4 MPI processes
>         type: mpiaij
>           using nonscalable MatPtAP() implementation
>           using I-node (on process 0) routines: found 2 nodes, limit used
> is 5
>   Down solver (pre-smoother) on level 1 -------------------------------
>     KSP Object: (mg_levels_1_) 4 MPI processes
>       type: chebyshev
>         eigenvalue estimates used:  min = 0.099971, max = 1.09968
>         eigenvalues estimate via gmres min 0.154032, max 0.99971
>         eigenvalues estimated using gmres with translations  [0. 0.1; 0.
> 1.1]
>         KSP Object: (mg_levels_1_esteig_) 4 MPI processes
>           type: gmres
>           maximum iterations=10, initial guess is zero
>           tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
>         estimating eigenvalues using noisy right hand side
>       maximum iterations=2, nonzero initial guess
>     PC Object: (mg_levels_1_) 4 MPI processes
>       type: sor
>         type = local_symmetric, iterations = 1, local iterations = 1,
> omega = 1.
>         type: mpiaij
>         rows=54, cols=54, bs=6
>         total: nonzeros=2916, allocated nonzeros=2916
>           using I-node (on process 0) routines: found 11 nodes, limit used
> is 5
>   Up solver (post-smoother) same as down solver (pre-smoother)
>   Down solver (pre-smoother) on level 2 -------------------------------
>     KSP Object: (mg_levels_2_) 4 MPI processes
>       type: chebyshev
>         eigenvalue estimates used:  min = 0.171388, max = 1.88526
>         eigenvalues estimate via gmres min 0.0717873, max 1.71388
> 1.1]
>         KSP Object: (mg_levels_2_esteig_) 4 MPI processes
>           type: gmres
>     PC Object: (mg_levels_2_) 4 MPI processes
>       type: sor
> omega = 1.
>         type: mpiaij
>         rows=642, cols=642, bs=6
>         total: nonzeros=99468, allocated nonzeros=99468
>           using I-node (on process 0) routines: found 47 nodes, limit used
> is 5
>   Down solver (pre-smoother) on level 3 -------------------------------
>     KSP Object: (mg_levels_3_) 4 MPI processes
>       type: chebyshev
>         eigenvalue estimates used:  min = 0.164216, max = 1.80637
>         eigenvalues estimate via gmres min 0.0376323, max 1.64216
> 1.1]
>         KSP Object: (mg_levels_3_esteig_) 4 MPI processes
>           type: gmres
>     PC Object: (mg_levels_3_) 4 MPI processes
>       type: sor
> omega = 1.
>         type: mpiaij
>         rows=6726, cols=6726, bs=6
>         total: nonzeros=941796, allocated nonzeros=941796
>           using I-node (on process 0) routines: found 552 nodes, limit
> used is 5
>   Down solver (pre-smoother) on level 4 -------------------------------
>     KSP Object: (mg_levels_4_) 4 MPI processes
>       type: chebyshev
>         eigenvalue estimates used:  min = 0.163283, max = 1.79611
>         eigenvalues estimate via gmres min 0.0350306, max 1.63283
> 1.1]
>         KSP Object: (mg_levels_4_esteig_) 4 MPI processes
>           type: gmres
>     PC Object: (mg_levels_4_) 4 MPI processes
>       type: sor
> omega = 1.
>         type: mpiaij
>         rows=41022, cols=41022, bs=6
>         total: nonzeros=2852316, allocated nonzeros=2852316
>           using I-node (on process 0) routines: found 3432 nodes, limit
> used is 5
>   Down solver (pre-smoother) on level 5 -------------------------------
>     KSP Object: (mg_levels_5_) 4 MPI processes
>       type: chebyshev
>         eigenvalue estimates used:  min = 0.157236, max = 1.7296
>         eigenvalues estimate via gmres min 0.0317897, max 1.57236
> 1.1]
>         KSP Object: (mg_levels_5_esteig_) 4 MPI processes
>           type: gmres
>     PC Object: (mg_levels_5_) 4 MPI processes
>       type: sor
> omega = 1.
>       Mat Object: () 4 MPI processes
>         type: mpiaij
>         rows=543606, cols=543606, bs=6
>         total: nonzeros=29224836, allocated nonzeros=29302596
>           has attached near null space
>           using I-node (on process 0) routines: found 45644 nodes, limit
> used is 5
>     type: mpiaij
>       using I-node (on process 0) routines: found 45644 nodes, limit used
> is 5
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/ea9d10b2/attachment-0001.html>
