[petsc-users] [petsc-maint] How to impose boundary conditions using DMDA
Mon Oct 29 12:29:01 CDT 2018
On Mon, Oct 29, 2018 at 9:37 AM Fengwen Wang <fwan at mek.dtu.dk> wrote:
> Yes.  I would like to a rotational BCs(Twist bcs).
You can do that with some work. I have implemented a Mobius strip (see
DM_BOUNDARY_TWIST). However,
I have no idea how to put a function space down on a non-orientable
manifold.
     Matt
> Such a boundary is needed to reduce the computational domain.
> Thanks lot
> Best regards
> Fengwen
> ____________________________________________________
> Senior Researcher
> Department of Mechanical Engineering, DTU
> Nils Koppels Allé
> Building 404
> 2800  Kgs. Lyngby
> fwan at mek.dtu.dk
> *From:* Lawrence Mitchell <wence at gmx.li>
> *Sent:* Monday, October 29, 2018 1:17:34 PM
> *To:* Matt Knepley
> *Cc:* Fengwen Wang; PETSc; PETSc
> *Subject:* Re: [petsc-users] [petsc-maint] How to impose boundary
> > On 29 Oct 2018, at 10:56, Matthew Knepley <knepley at gmail.com> wrote:
> > You can certainly map the right edge to the top edge (its topologically
> a square again), but that
> > mapping is not smooth, and I do not know how you would make a global
> basis for the approximation space.
> Yeah, I thought this was topologically just a cone, but that would have:
> u(x=1) = -v(y=1)
> and
> v(x=1) = u(y=1) (note matching sign).
> So if you wanted the v(x=1) = -u(y=1) there would be a twist somehow, and
> then a discontinuity in the mapping.
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/51561a7f/attachment.html>
