[petsc-users] Convergence of AMG
Manav Bhatia bhatiamanav at gmail.com
Sun Oct 28 12:16:19 CDT 2018
   I am attempting to solve a Mindlin plate bending problem with AMG solver in petsc. This test case is with a mesh of 300x300 elements and 543,606 dofs.
   The discretization includes 6 variables (u, v, w, tx, ty, tz), but only three are relevant for plate bending (w, tx, ty).
   I am calling the solver with the following options:
-pc_type gamg -pc_gamg_threshold 0. --node-major-dofs -mat_block_size 6 -ksp_rtol 1.e-8 -ksp_monitor -ksp_converged_reason -ksp_view
  And the convergence behavior is shown below, along with the ksp_view information. Based on notes in the manual, this seems to be subpar convergence rate. At the end of the solution the norm of each variable is :
var: 0: u  : norm: 5.505909e-18
var: 1: v  : norm: 7.639640e-18
var: 2: w : norm: 3.901464e-03
var: 3: tx : norm: 4.403576e-02
var: 4: ty : norm: 4.403576e-02
var: 5: tz : norm: 1.148409e-16
  I tried different values of -ksp_rtol from 1e-1 to 1e-8 and this does not make a lot of difference in the norms of (w, tx, ty).
  I do provide the solver with 6 rigid-body vectors to approximate the null-space of the problem. Without these the solver shows very poor convergence.
  I would appreciate advice on possible strategies to improve this behavior.
Manav
    0 KSP Residual norm 1.696304497261e+00
    1 KSP Residual norm 1.120485505777e+00
    2 KSP Residual norm 8.324222302402e-01
    3 KSP Residual norm 6.477349534115e-01
    4 KSP Residual norm 5.080936471292e-01
    5 KSP Residual norm 4.051099646638e-01
    6 KSP Residual norm 3.260432664653e-01
    7 KSP Residual norm 2.560483838143e-01
    8 KSP Residual norm 2.029943986124e-01
    9 KSP Residual norm 1.560985741610e-01
   10 KSP Residual norm 1.163720702140e-01
   11 KSP Residual norm 8.488411085459e-02
   12 KSP Residual norm 5.888041729034e-02
   13 KSP Residual norm 4.027792209980e-02
   14 KSP Residual norm 2.819048087304e-02
   15 KSP Residual norm 1.904674196962e-02
   16 KSP Residual norm 1.289302447822e-02
   17 KSP Residual norm 9.162203296376e-03
   18 KSP Residual norm 7.016781679507e-03
   19 KSP Residual norm 5.399170865328e-03
   20 KSP Residual norm 4.254385887482e-03
   21 KSP Residual norm 3.530831740621e-03
   22 KSP Residual norm 2.946780747923e-03
   23 KSP Residual norm 2.339361361128e-03
   24 KSP Residual norm 1.815072489282e-03
   25 KSP Residual norm 1.408814185342e-03
   26 KSP Residual norm 1.063795714320e-03
   27 KSP Residual norm 7.828540233117e-04
   28 KSP Residual norm 5.683910750067e-04
   29 KSP Residual norm 4.131151010250e-04
   30 KSP Residual norm 3.065608221019e-04
   31 KSP Residual norm 2.634114273459e-04
   32 KSP Residual norm 2.198180137626e-04
   33 KSP Residual norm 1.748956510799e-04
   34 KSP Residual norm 1.317539710010e-04
   35 KSP Residual norm 9.790121566055e-05
   36 KSP Residual norm 7.465935386094e-05
   37 KSP Residual norm 5.689506626052e-05
   38 KSP Residual norm 4.413136619126e-05
   39 KSP Residual norm 3.512194236402e-05
   40 KSP Residual norm 2.877755408287e-05
   41 KSP Residual norm 2.340080556431e-05
   42 KSP Residual norm 1.904544450345e-05
   43 KSP Residual norm 1.504723478235e-05
   44 KSP Residual norm 1.141381950576e-05
   45 KSP Residual norm 8.206151384599e-06
   46 KSP Residual norm 5.911426091276e-06
   47 KSP Residual norm 4.233669089283e-06
   48 KSP Residual norm 2.898052944223e-06
   49 KSP Residual norm 2.023556779973e-06
   50 KSP Residual norm 1.459108043935e-06
   51 KSP Residual norm 1.097335545865e-06
   52 KSP Residual norm 8.440457332262e-07
   53 KSP Residual norm 6.705616854004e-07
   54 KSP Residual norm 5.404888680234e-07
   55 KSP Residual norm 4.391368084979e-07
   56 KSP Residual norm 3.697063014621e-07
   57 KSP Residual norm 3.021772094146e-07
   58 KSP Residual norm 2.479354520792e-07
   59 KSP Residual norm 2.013077841968e-07
   60 KSP Residual norm 1.553159612793e-07
   61 KSP Residual norm 1.400784224898e-07
   62 KSP Residual norm 9.707453662195e-08
   63 KSP Residual norm 7.263173080146e-08
   64 KSP Residual norm 5.593723572132e-08
   65 KSP Residual norm 4.448788809586e-08
   66 KSP Residual norm 3.613992590778e-08
   67 KSP Residual norm 2.946099051876e-08
   68 KSP Residual norm 2.408053564170e-08
   69 KSP Residual norm 1.945257374856e-08
   70 KSP Residual norm 1.572494535110e-08
KSP Object: 4 MPI processes
  type: gmres
    restart=30, using Classical (unmodified) Gram-Schmidt Orthogonalization with no iterative refinement
    happy breakdown tolerance 1e-30
  maximum iterations=10000, initial guess is zero
  tolerances:  relative=1e-08, absolute=1e-50, divergence=10000.
  left preconditioning
  using PRECONDITIONED norm type for convergence test
PC Object: 4 MPI processes
  type: gamg
    type is MULTIPLICATIVE, levels=6 cycles=v
      Cycles per PCApply=1
      Using externally compute Galerkin coarse grid matrices
      GAMG specific options
        Threshold for dropping small values in graph on each level =   0.   0.   0.   0.
        Threshold scaling factor for each level not specified = 1.
        AGG specific options
          Symmetric graph false
          Number of levels to square graph 1
          Number smoothing steps 1
  Coarse grid solver -- level -------------------------------
    KSP Object: (mg_coarse_) 4 MPI processes
      type: preonly
      tolerances:  relative=1e-05, absolute=1e-50, divergence=10000.
      using NONE norm type for convergence test
    PC Object: (mg_coarse_) 4 MPI processes
      type: bjacobi
        number of blocks = 4
        Local solve is same for all blocks, in the following KSP and PC objects:
      KSP Object: (mg_coarse_sub_) 1 MPI processes
        type: preonly
        maximum iterations=1, initial guess is zero
      PC Object: (mg_coarse_sub_) 1 MPI processes
        type: lu
          out-of-place factorization
          tolerance for zero pivot 2.22045e-14
          using diagonal shift on blocks to prevent zero pivot [INBLOCKS]
          matrix ordering: nd
          factor fill ratio given 5., needed 1.
            Factored matrix follows:
              Mat Object: 1 MPI processes
                type: seqaij
                rows=6, cols=6, bs=6
                package used to perform factorization: petsc
                total: nonzeros=36, allocated nonzeros=36
                total number of mallocs used during MatSetValues calls =0
                  using I-node routines: found 2 nodes, limit used is 5
        linear system matrix = precond matrix:
          type: seqaij
      Mat Object: 4 MPI processes
        type: mpiaij
          using nonscalable MatPtAP() implementation
          using I-node (on process 0) routines: found 2 nodes, limit used is 5
  Down solver (pre-smoother) on level 1 -------------------------------
    KSP Object: (mg_levels_1_) 4 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0.099971, max = 1.09968
        eigenvalues estimate via gmres min 0.154032, max 0.99971
        eigenvalues estimated using gmres with translations  [0. 0.1; 0. 1.1]
        KSP Object: (mg_levels_1_esteig_) 4 MPI processes
          type: gmres
          maximum iterations=10, initial guess is zero
          tolerances:  relative=1e-12, absolute=1e-50, divergence=10000.
        estimating eigenvalues using noisy right hand side
      maximum iterations=2, nonzero initial guess
    PC Object: (mg_levels_1_) 4 MPI processes
      type: sor
        type = local_symmetric, iterations = 1, local iterations = 1, omega = 1.
        type: mpiaij
        rows=54, cols=54, bs=6
        total: nonzeros=2916, allocated nonzeros=2916
          using I-node (on process 0) routines: found 11 nodes, limit used is 5
  Up solver (post-smoother) same as down solver (pre-smoother)
  Down solver (pre-smoother) on level 2 -------------------------------
    KSP Object: (mg_levels_2_) 4 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0.171388, max = 1.88526
        eigenvalues estimate via gmres min 0.0717873, max 1.71388
        KSP Object: (mg_levels_2_esteig_) 4 MPI processes
          type: gmres
    PC Object: (mg_levels_2_) 4 MPI processes
      type: sor
        type: mpiaij
        rows=642, cols=642, bs=6
        total: nonzeros=99468, allocated nonzeros=99468
          using I-node (on process 0) routines: found 47 nodes, limit used is 5
  Down solver (pre-smoother) on level 3 -------------------------------
    KSP Object: (mg_levels_3_) 4 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0.164216, max = 1.80637
        eigenvalues estimate via gmres min 0.0376323, max 1.64216
        KSP Object: (mg_levels_3_esteig_) 4 MPI processes
          type: gmres
    PC Object: (mg_levels_3_) 4 MPI processes
      type: sor
        type: mpiaij
        rows=6726, cols=6726, bs=6
        total: nonzeros=941796, allocated nonzeros=941796
          using I-node (on process 0) routines: found 552 nodes, limit used is 5
  Down solver (pre-smoother) on level 4 -------------------------------
    KSP Object: (mg_levels_4_) 4 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0.163283, max = 1.79611
        eigenvalues estimate via gmres min 0.0350306, max 1.63283
        KSP Object: (mg_levels_4_esteig_) 4 MPI processes
          type: gmres
    PC Object: (mg_levels_4_) 4 MPI processes
      type: sor
        type: mpiaij
        rows=41022, cols=41022, bs=6
        total: nonzeros=2852316, allocated nonzeros=2852316
          using I-node (on process 0) routines: found 3432 nodes, limit used is 5
  Down solver (pre-smoother) on level 5 -------------------------------
    KSP Object: (mg_levels_5_) 4 MPI processes
      type: chebyshev
        eigenvalue estimates used:  min = 0.157236, max = 1.7296
        eigenvalues estimate via gmres min 0.0317897, max 1.57236
        KSP Object: (mg_levels_5_esteig_) 4 MPI processes
          type: gmres
    PC Object: (mg_levels_5_) 4 MPI processes
      type: sor
      Mat Object: () 4 MPI processes
        type: mpiaij
        rows=543606, cols=543606, bs=6
        total: nonzeros=29224836, allocated nonzeros=29302596
          has attached near null space
          using I-node (on process 0) routines: found 45644 nodes, limit used is 5
    type: mpiaij
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181028/f30fc716/attachment-0001.html>
