[petsc-users] [petsc-maint] How to impose boundary conditions using DMDA
Mon Oct 29 05:56:42 CDT 2018
On Mon, Oct 29, 2018 at 6:22 AM Lawrence Mitchell <wencel at gmail.com> wrote:
> On 29 Oct 2018, at 10:09, Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 29, 2018 at 5:39 AM Fengwen Wang <fwan at mek.dtu.dk> wrote:
> Hi Matt and Barry,
> I only have  a regular 2D  square domain of a unit cell.
> The boundary condition implies some sort of topology. For example, if you
> condition was
>   u, v (x = 0) = u, v (x = 1)
> you are on a cylinder. And if you add
>   u, v (y = 0) = u, v (y = 1)
> you are on a torus. However, you are hooking the right edge to the top edge
> and also transforming the basis. I cannot understand what is meant.
> I'm no good at drawing embedded things, I read the bc like the attached
> picture. You sort of fold the top and right edges together "inwards", which
> means that stuff that flows out of the right edge flows in through the top
> edge, and stuff that is flowing up along the right edge ends up flowing
> left along the top edge?
You can certainly map the right edge to the top edge (its topologically a
square again), but that
mapping is not smooth, and I do not know how you would make a global basis
for the approximation space.
   Matt
> Lawrence
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/5fd04a9d/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/5fd04a9d/attachment-0002.jpg>
Type: image/jpeg
Desc: not available
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181029/5fd04a9d/attachment-0003.jpg>
