[petsc-users] [SLEPc] ex5 fails, error in lapack
Dave May
dave.mayhem23 at gmail.com
Sun Oct 28 16:01:33 CDT 2018
On Sun, 28 Oct 2018 at 21:46, Santiago Andres Triana <repepo at gmail.com>
wrote:
> Hi Dave,
> Indeed, I added that last arg myself after the configure script asked for
> it (--with-batch seems to need it). I just tried with petsc-3.9.1, without
> the --with-batch and --known-64-blas-indices=1 options and everything is
> working nicely.
Great.
I believe as general rule, flags such as -known-64-bit-xxx are only
required to be specified by the user when using system provided packages
(actually any package not installed by petsc' configure). If you use
--download-yyy then petscs' configure defines how package yyy is to be
configured and built, hence it knows whether it used 64 bit ints, or not -
the user does not (and probably should not) provide a flag to indicate what
petsc configuration already knows
Dave
I will try again later with the latest version.
Ok.
> Thanks!
> Santiago
> On Sun, Oct 28, 2018 at 10:31 AM Dave May <dave.mayhem23 at gmail.com> wrote:
>> On Sun, 28 Oct 2018 at 09:37, Santiago Andres Triana <repepo at gmail.com>
>> wrote:
>>> Hi petsc-users,
>>> I am experiencing problems running ex5 and ex7 from the slepc tutorial.
>>> This is after upgrade to petsc-3.10.2 and slepc-3.10.1. Has anyone run into
>>> this problem? see the error message below. Any help or advice would be
>>> highly appreciated. Thanks in advance!
>>> Santiago
>>> trianas at hpcb-n02:/home/trianas/slepc-3.10.1/src/eps/examples/tutorials>
>>> ./ex5 -eps_nev 4
>>> Markov Model, N=120 (m=15)
>>> [0]PETSC ERROR: --------------------- Error Message
>>> [0]PETSC ERROR: Error in external library
>>> [0]PETSC ERROR: Error in LAPACK subroutine hseqr: info=0
>>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>>> for trouble shooting.
>>> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
>>> [0]PETSC ERROR: ./ex5 on a arch-linux2-c-opt named hpcb-n02 by trianas
>>> Sun Oct 28 09:30:18 2018
>>> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>>> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
>>> --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
>>> --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
>>> --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
>>> --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
>>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
>>> --known-mpi-c-double-complex=1 --known-has-attribute-aligned=1
>>> --with-scalar-type=complex --download-mumps=1 --download-parmetis
>>> --download-metis --download-scalapack=1 --download-fblaslapack=1
>>> --with-debugging=0 --download-superlu_dist=1 --download-ptscotch=1
>>> CXXOPTFLAGS="-O3 -march=native" FOPTFLAGS="-O3 -march=native"
>>> COPTFLAGS="-O3 -march=native" --with-batch --known-64-bit-blas-indices=1
>> I think this last arg is wrong if you use --download-fblaslapack.
>> Did you explicitly add this option yourself?
>> [0]PETSC ERROR: #1 DSSolve_NHEP() line 586 in
>>> /space/hpc-home/trianas/slepc-3.10.1/src/sys/classes/ds/impls/nhep/dsnhep.c
>>> [0]PETSC ERROR: #2 DSSolve() line 586 in
>>> /space/hpc-home/trianas/slepc-3.10.1/src/sys/classes/ds/interface/dsops.c
>>> [0]PETSC ERROR: #3 EPSSolve_KrylovSchur_Default() line 275 in
>>> /space/hpc-home/trianas/slepc-3.10.1/src/eps/impls/krylov/krylovschur/krylovschur.c
>>> [0]PETSC ERROR: #4 EPSSolve() line 148 in
>>> /space/hpc-home/trianas/slepc-3.10.1/src/eps/interface/epssolve.c
>>> [0]PETSC ERROR: #5 main() line 90 in
>>> /home/trianas/slepc-3.10.1/src/eps/examples/tutorials/ex5.c
>>> [0]PETSC ERROR: PETSc Option Table entries:
>>> [0]PETSC ERROR: -eps_nev 4
>>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>>> error message to petsc-maint at mcs.anl.gov----------
>>> application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
>>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=76
>>> system msg for write_line failure : Bad file descriptor
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181028/c45c97ca/attachment-0001.html>
