[petsc-users] [SLEPc] ex5 fails, error in lapack
Santiago Andres Triana repepo at gmail.com
Sun Oct 28 15:46:19 CDT 2018
Hi Dave,
Indeed, I added that last arg myself after the configure script asked for
it (--with-batch seems to need it). I just tried with petsc-3.9.1, without
the --with-batch and --known-64-blas-indices=1 options and everything is
working nicely. I will try again later with the latest version.
Thanks!
Santiago
On Sun, Oct 28, 2018 at 10:31 AM Dave May <dave.mayhem23 at gmail.com> wrote:
> On Sun, 28 Oct 2018 at 09:37, Santiago Andres Triana <repepo at gmail.com>
> wrote:
>> Hi petsc-users,
>> I am experiencing problems running ex5 and ex7 from the slepc tutorial.
>> This is after upgrade to petsc-3.10.2 and slepc-3.10.1. Has anyone run into
>> this problem? see the error message below. Any help or advice would be
>> highly appreciated. Thanks in advance!
>> Santiago
>> trianas at hpcb-n02:/home/trianas/slepc-3.10.1/src/eps/examples/tutorials>
>> ./ex5 -eps_nev 4
>> Markov Model, N=120 (m=15)
>> [0]PETSC ERROR: --------------------- Error Message
>> [0]PETSC ERROR: Error in external library
>> [0]PETSC ERROR: Error in LAPACK subroutine hseqr: info=0
>> [0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html
>> for trouble shooting.
>> [0]PETSC ERROR: Petsc Release Version 3.10.2, Oct, 09, 2018
>> [0]PETSC ERROR: ./ex5 on a arch-linux2-c-opt named hpcb-n02 by trianas
>> Sun Oct 28 09:30:18 2018
>> [0]PETSC ERROR: Configure options --known-level1-dcache-size=32768
>> --known-level1-dcache-linesize=64 --known-level1-dcache-assoc=8
>> --known-sizeof-char=1 --known-sizeof-void-p=8 --known-sizeof-short=2
>> --known-sizeof-int=4 --known-sizeof-long=8 --known-sizeof-long-long=8
>> --known-sizeof-float=4 --known-sizeof-double=8 --known-sizeof-size_t=8
>> --known-bits-per-byte=8 --known-memcmp-ok=1 --known-sizeof-MPI_Comm=4
>> --known-sizeof-MPI_Fint=4 --known-mpi-long-double=1 --known-mpi-int64_t=1
>> --known-mpi-c-double-complex=1 --known-has-attribute-aligned=1
>> --with-scalar-type=complex --download-mumps=1 --download-parmetis
>> --download-metis --download-scalapack=1 --download-fblaslapack=1
>> --with-debugging=0 --download-superlu_dist=1 --download-ptscotch=1
>> CXXOPTFLAGS="-O3 -march=native" FOPTFLAGS="-O3 -march=native"
>> COPTFLAGS="-O3 -march=native" --with-batch --known-64-bit-blas-indices=1
> I think this last arg is wrong if you use --download-fblaslapack.
> Did you explicitly add this option yourself?
> [0]PETSC ERROR: #1 DSSolve_NHEP() line 586 in
>> /space/hpc-home/trianas/slepc-3.10.1/src/sys/classes/ds/impls/nhep/dsnhep.c
>> [0]PETSC ERROR: #2 DSSolve() line 586 in
>> /space/hpc-home/trianas/slepc-3.10.1/src/sys/classes/ds/interface/dsops.c
>> [0]PETSC ERROR: #3 EPSSolve_KrylovSchur_Default() line 275 in
>> /space/hpc-home/trianas/slepc-3.10.1/src/eps/impls/krylov/krylovschur/krylovschur.c
>> [0]PETSC ERROR: #4 EPSSolve() line 148 in
>> /space/hpc-home/trianas/slepc-3.10.1/src/eps/interface/epssolve.c
>> [0]PETSC ERROR: #5 main() line 90 in
>> /home/trianas/slepc-3.10.1/src/eps/examples/tutorials/ex5.c
>> [0]PETSC ERROR: PETSc Option Table entries:
>> [0]PETSC ERROR: -eps_nev 4
>> [0]PETSC ERROR: ----------------End of Error Message -------send entire
>> error message to petsc-maint at mcs.anl.gov----------
>> application called MPI_Abort(MPI_COMM_WORLD, 76) - process 0
>> [unset]: write_line error; fd=-1 buf=:cmd=abort exitcode=76
>> system msg for write_line failure : Bad file descriptor
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181028/b8922d4b/attachment.html>
