[petsc-users] "Could not find a suitable archiver. Use --with-arto specify an archiver"
avatar 648934229 at qq.com
Thu Oct 25 17:27:32 CDT 2018
Hi Satish,
Thank you very much for your quick response.
The log file is as follow:
                              Pushing language C
                              Popping language C
                              Pushing language CUDA
                              Popping language CUDA
                              Pushing language Cxx
                              Popping language Cxx
                              Pushing language FC
                              Popping language FC
Starting Configure Run at Thu Oct 25 16:25:30 2018
Configure Options: --configModules=PETSc.Configure --optionsModule=config.compilerOptions --with-matlab
Working directory: /Users/zhihui/igx/deps/srcs/petsc-3.8.3
Machine platform:
('Darwin', 'Scott-Grad-MBP', '16.7.0', 'Darwin Kernel Version 16.7.0: Thu Jun 15 17:36:27 PDT 2017; root:xnu-3789.70.16~2/RELEASE_X86_64', 'x86_64', 'i386')
Python version:
2.7.10 (default, Feb  7 2017, 00:08:15)
[GCC 4.2.1 Compatible Apple LLVM 8.0.0 (clang-800.0.34)]
          Pushing language C
          Popping language C
          Pushing language FC
          Popping language FC
TEST configureExternalPackagesDir from config.framework(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py:841)
TESTING: configureExternalPackagesDir from config.framework(config/BuildSystem/config/framework.py:841)
TEST configureDebuggers from config.utilities.debuggers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/utilities/debuggers.py:22)
TESTING: configureDebuggers from config.utilities.debuggers(config/BuildSystem/config/utilities/debuggers.py:22)
  Find a default debugger and determine its arguments
Checking for program /usr/local/bin/gdb...not found
Checking for program /usr/bin/gdb...not found
Checking for program /bin/gdb...not found
Checking for program /usr/sbin/gdb...not found
Checking for program /sbin/gdb...not found
Checking for program /Applications/VMware Fusion.app/Contents/Public/gdb...not found
Checking for program /Library/TeX/texbin/gdb...not found
Checking for program /Users/zhihui/gdb...not found
Checking for program /usr/local/bin/dbx...not found
Checking for program /usr/bin/dbx...not found
Checking for program /bin/dbx...not found
Checking for program /usr/sbin/dbx...not found
Checking for program /sbin/dbx...not found
Checking for program /Applications/VMware Fusion.app/Contents/Public/dbx...not found
Checking for program /Library/TeX/texbin/dbx...not found
Checking for program /Users/zhihui/dbx...not found
Checking for program /usr/local/bin/xdb...not found
Checking for program /usr/bin/xdb...not found
Checking for program /bin/xdb...not found
Checking for program /usr/sbin/xdb...not found
Checking for program /sbin/xdb...not found
Checking for program /Applications/VMware Fusion.app/Contents/Public/xdb...not found
Checking for program /Library/TeX/texbin/xdb...not found
Checking for program /Users/zhihui/xdb...not found
Checking for program /usr/local/bin/dsymutil...not found
Checking for program /usr/bin/dsymutil...found
                Defined make macro "DSYMUTIL" to "/usr/bin/dsymutil"
TEST configureGit from config.sourceControl(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/sourceControl.py:24)
TESTING: configureGit from config.sourceControl(config/BuildSystem/config/sourceControl.py:24)
  Find the Git executable
Checking for program /usr/local/bin/git...not found
Checking for program /usr/bin/git...found
                Defined make macro "GIT" to "git"
Executing: git --version
stdout: git version 2.14.3 (Apple Git-98)
TEST configureMercurial from config.sourceControl(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/sourceControl.py:35)
TESTING: configureMercurial from config.sourceControl(config/BuildSystem/config/sourceControl.py:35)
  Find the Mercurial executable
Checking for program /usr/local/bin/hg...not found
Checking for program /usr/bin/hg...not found
Checking for program /bin/hg...not found
Checking for program /usr/sbin/hg...not found
Checking for program /sbin/hg...not found
Checking for program /Applications/VMware Fusion.app/Contents/Public/hg...not found
Checking for program /Library/TeX/texbin/hg...not found
Checking for program /Users/zhihui/hg...not found
TEST configureCLanguage from PETSc.options.languages(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/languages.py:27)
TESTING: configureCLanguage from PETSc.options.languages(config/PETSc/options/languages.py:27)
  Choose whether to compile the PETSc library using a C or C++ compiler
            C language is C
              Defined "CLANGUAGE_C" to "1"
TEST configureDirectories from PETSc.options.petscdir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/petscdir.py:23)
TESTING: configureDirectories from PETSc.options.petscdir(config/PETSc/options/petscdir.py:23)
  Checks PETSC_DIR and sets if not set
            Version Information:
            #define PETSC_VERSION_RELEASE    1
            #define PETSC_VERSION_MAJOR      3
            #define PETSC_VERSION_MINOR      8
            #define PETSC_VERSION_SUBMINOR   3
            #define PETSC_VERSION_PATCH      0
            #define PETSC_VERSION_DATE       "Dec, 09, 2017"
            #define PETSC_VERSION_GIT        "v3.8.3"
            #define PETSC_VERSION_DATE_GIT   "2017-12-09 22:33:04 -0600"
            #define PETSC_VERSION_EQ(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_ PETSC_VERSION_EQ
            #define PETSC_VERSION_LT(MAJOR,MINOR,SUBMINOR)          \
            #define PETSC_VERSION_LE(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_GT(MAJOR,MINOR,SUBMINOR) \
            #define PETSC_VERSION_GE(MAJOR,MINOR,SUBMINOR) \
              Defined make macro "DIR" to "/Users/zhihui/igx/deps/srcs/petsc-3.8.3"
TEST getDatafilespath from PETSc.options.dataFilesPath(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/dataFilesPath.py:29)
TESTING: getDatafilespath from PETSc.options.dataFilesPath(config/PETSc/options/dataFilesPath.py:29)
  Checks what DATAFILESPATH should be
TEST configureInstallationMethod from PETSc.options.petscclone(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/petscclone.py:20)
TESTING: configureInstallationMethod from PETSc.options.petscclone(config/PETSc/options/petscclone.py:20)
            This is a tarball installation
TEST configureArchitecture from PETSc.options.arch(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/arch.py:36)
TESTING: configureArchitecture from PETSc.options.arch(config/PETSc/options/arch.py:36)
  Checks PETSC_ARCH and sets if not set
              Defined "ARCH" to ""arch-darwin-c-debug""
TEST setInstallDir from PETSc.options.installDir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/installDir.py:35)
TESTING: setInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:35)
   setup installDir to either prefix or if that is not set to PETSC_DIR/PETSC_ARCH
TEST saveReconfigure from PETSc.options.installDir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/installDir.py:75)
TESTING: saveReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:75)
TEST cleanInstallDir from PETSc.options.installDir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/installDir.py:68)
TESTING: cleanInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:68)
TEST configureInstallDir from PETSc.options.installDir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/installDir.py:52)
TESTING: configureInstallDir from PETSc.options.installDir(config/PETSc/options/installDir.py:52)
  Makes  installDir subdirectories if it does not exist for both prefix install location and PETSc work install location
            Changed persistence directory to /Users/zhihui/igx/deps/srcs/petsc-3.8.3/arch-darwin-c-debug/lib/petsc/conf
TEST restoreReconfigure from PETSc.options.installDir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/installDir.py:88)
TESTING: restoreReconfigure from PETSc.options.installDir(config/PETSc/options/installDir.py:88)
TEST setExternalPackagesDir from PETSc.options.externalpackagesdir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/externalpackagesdir.py:15)
TESTING: setExternalPackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:15)
TEST cleanExternalpackagesDir from PETSc.options.externalpackagesdir(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/PETSc/options/externalpackagesdir.py:22)
TESTING: cleanExternalpackagesDir from PETSc.options.externalpackagesdir(config/PETSc/options/externalpackagesdir.py:22)
TEST printEnvVariables from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1612)
TESTING: printEnvVariables from config.setCompilers(config/BuildSystem/config/setCompilers.py:1612)
            **** printenv ****
VERSIONER_PYTHON_PREFER_32_BIT=no
TERM_PROGRAM_VERSION=3.2.4
LOGNAME=zhihui
USER=zhihui
PATH=/usr/local/bin:/usr/bin:/bin:/usr/sbin:/sbin:/Applications/VMware Fusion.app/Contents/Public:/Library/TeX/texbin
HOME=/Users/zhihui
TERM_PROGRAM=iTerm.app
LANG=en_US.UTF-8
TERM=xterm-256color
Apple_PubSub_Socket_Render=/private/tmp/com.apple.launchd.ybiDqNFoh0/Render
COLORFGBG=7;0
VERSIONER_PYTHON_VERSION=2.7
SHLVL=1
XPC_FLAGS=0x0
ITERM_SESSION_ID=w0t0p0:52215AF3-F8D7-4DDE-BC06-683584748154
_=./configure
XPC_SERVICE_NAME=0
SSH_AUTH_SOCK=/private/tmp/com.apple.launchd.XYegXE4MrG/Listeners
SHELL=/bin/bash
ITERM_PROFILE=Default
TMPDIR=tmp
OLDPWD=/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config
__CF_USER_TEXT_ENCODING=0x1F6:0x0:0x0
COLORTERM=truecolor
TEST resetEnvCompilers from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1619)
TESTING: resetEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1619)
TEST checkEnvCompilers from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1649)
TESTING: checkEnvCompilers from config.setCompilers(config/BuildSystem/config/setCompilers.py:1649)
TEST checkMPICompilerOverride from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1584)
TESTING: checkMPICompilerOverride from config.setCompilers(config/BuildSystem/config/setCompilers.py:1584)
  Check if --with-mpi-dir is used along with CC CXX or FC compiler options.
    This usually prevents mpi compilers from being used - so issue a warning
TEST requireMpiLdPath from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1603)
TESTING: requireMpiLdPath from config.setCompilers(config/BuildSystem/config/setCompilers.py:1603)
  OpenMPI wrappers require LD_LIBRARY_PATH set
TEST checkVendor from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:426)
TESTING: checkVendor from config.setCompilers(config/BuildSystem/config/setCompilers.py:426)
  Determine the compiler vendor
            Compiler vendor is ""
TEST checkInitialFlags from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:436)
TESTING: checkInitialFlags from config.setCompilers(config/BuildSystem/config/setCompilers.py:436)
  Initialize the compiler and linker flags
              Pushing language C
            Initialized CFLAGS to
            Initialized LDFLAGS to
              Popping language C
            Initialized CUDAFLAGS to
            Initialized CXXFLAGS to
            Initialized CXX_CXXFLAGS to
              Pushing language FC
            Initialized FFLAGS to
              Popping language FC
            Initialized CPPFLAGS to
            Initialized CUDAPPFLAGS to
            Initialized CXXCPPFLAGS to
            Initialized CC_LINKER_FLAGS to []
            Initialized CXX_LINKER_FLAGS to []
            Initialized FC_LINKER_FLAGS to []
            Initialized CUDAC_LINKER_FLAGS to []
            Initialized sharedLibraryFlags to []
            Initialized dynamicLibraryFlags to []
TEST checkCCompiler from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:566)
TESTING: checkCCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:566)
  Locate a functional C compiler
Executing: mpicc --help
stdout:
OVERVIEW: clang LLVM compiler
USAGE: clang-6.0 [options] <inputs>
OPTIONS:
  -###                    Print (but do not run) the commands to run for this compilation
  --analyzer-output <value>
                          Static analyzer report output format (html|plist|plist-multi-file|plist-html|text).
  --analyze               Run the static analyzer
  -arcmt-migrate-emit-errors
                          Emit ARC errors even if the migrator can fix them
  -arcmt-migrate-report-output <value>
                          Output path for the plist report
  -B <dir>                Add <dir> to search path for binaries and object files used implicitly
  -CC                     Include comments from within macros in preprocessed output
  -cl-denorms-are-zero    OpenCL only. Allow denormals to be flushed to zero.
  -cl-fast-relaxed-math   OpenCL only. Sets -cl-finite-math-only and -cl-unsafe-math-optimizations, and defines __FAST_RELAXED_MATH__.
  -cl-finite-math-only    OpenCL only. Allow floating-point optimizations that assume arguments and results are not NaNs or +-Inf.
  -cl-fp32-correctly-rounded-divide-sqrt
                          OpenCL only. Specify that single precision floating-point divide and sqrt used in the program source are correctly rounded.
  -cl-kernel-arg-info     OpenCL only. Generate kernel argument metadata.
  -cl-mad-enable          OpenCL only. Allow use of less precise MAD computations in the generated binary.
  -cl-no-signed-zeros     OpenCL only. Allow use of less precise no signed zeros computations in the generated binary.
  -cl-opt-disable         OpenCL only. This option disables all optimizations. By default optimizations are enabled.
  -cl-single-precision-constant
                          OpenCL only. Treat double precision floating-point constant as single precision constant.
  -cl-std=<value>         OpenCL language standard to compile for.
  -cl-strict-aliasing     OpenCL only. This option is added for compatibility with OpenCL 1.0.
                          OpenCL only. Allow unsafe floating-point optimizations.  Also implies -cl-no-signed-zeros and -cl-mad-enable.
  --config <value>        Specifies configuration file
  --cuda-compile-host-device
                          Compile CUDA code for both host and device (default).  Has no effect on non-CUDA compilations.
  --cuda-device-only      Compile CUDA code for device only
  --cuda-gpu-arch=<value> CUDA GPU architecture (e.g. sm_35).  May be specified more than once.
  --cuda-host-only        Compile CUDA code for host only.  Has no effect on non-CUDA compilations.
  --cuda-noopt-device-debug
                          Enable device-side debug info generation. Disables ptxas optimizations.
  --cuda-path=<value>     CUDA installation path
  -cxx-isystem <directory>
                          Add directory to the C++ SYSTEM include search path
  -C                      Include comments in preprocessed output
  -c                      Only run preprocess, compile, and assemble steps
  -dD                     Print macro definitions in -E mode in addition to normal output
  -dependency-dot <value> Filename to write DOT-formatted header dependencies to
  -dependency-file <value>
                          Filename (or -) to write dependency output to
  -dI                     Print include directives in -E mode in addition to normal output
  -dM                     Print macro definitions in -E mode instead of normal output
  -D <macro>=<value>      Define <macro> to <value> (or 1 if <value> omitted)
  -emit-ast               Emit Clang AST files for source inputs
  -emit-llvm              Use the LLVM representation for assembler and object files
  -E                      Only run the preprocessor
  -faligned-allocation    Enable C++17 aligned allocation functions
  -fallow-editor-placeholders
                          Treat editor placeholders as valid source code
  -fansi-escape-codes     Use ANSI escape codes for diagnostics
  -fapple-kext            Use Apple's kernel extensions ABI
  -fapple-pragma-pack     Enable Apple gcc-compatible #pragma pack handling
  -fapplication-extension Restrict code to those available for App Extensions
  -fblocks                Enable the 'blocks' language feature
  -fborland-extensions    Accept non-standard constructs supported by the Borland compiler
  -fbuild-session-file=<file>
                          Use the last modification time of <file> as the build session timestamp
  -fbuild-session-timestamp=<time since Epoch in seconds>
                          Time when the current build session started
  -fbuiltin-module-map    Load the clang builtins module map file.
  -fclang-abi-compat=<version>
                          Attempt to match the ABI of Clang <version>
  -fcolor-diagnostics     Use colors in diagnostics
  -fcomment-block-commands=<arg>
                          Treat each comma separated argument in <arg> as a documentation comment block command
  -fcoroutines-ts         Enable support for the C++ Coroutines TS
  -fcoverage-mapping      Generate coverage mapping to enable code coverage analysis
  -fcuda-approx-transcendentals
                          Use approximate transcendental functions
  -fcuda-flush-denormals-to-zero
                          Flush denormal floating point values to zero in CUDA device mode.
  -fcxx-exceptions        Enable C++ exceptions
  -fdata-sections         Place each data in its own section (ELF Only)
  -fdebug-info-for-profiling
                          Emit extra debug info to make sample profile more accurate.
  -fdebug-macro           Emit macro debug information
  -fdebug-prefix-map=<value>
                          remap file source paths in debug info
  -fdebug-types-section   Place debug types in their own section (ELF Only)
  -fdeclspec              Allow __declspec as a keyword
  -fdelayed-template-parsing
                          Parse templated function definitions at the end of the translation unit
  -fdiagnostics-absolute-paths
                          Print absolute paths in diagnostics
  -fdiagnostics-hotness-threshold=<number>
                          Prevent optimization remarks from being output if they do not have at least this profile count
  -fdiagnostics-parseable-fixits
                          Print fix-its in machine parseable form
  -fdiagnostics-print-source-range-info
                          Print source range spans in numeric form
  -fdiagnostics-show-hotness
                          Enable profile hotness information in diagnostic line
  -fdiagnostics-show-note-include-stack
                          Display include stacks for diagnostic notes
  -fdiagnostics-show-option
                          Print option name with mappable diagnostics
  -fdiagnostics-show-template-tree
                          Print a template comparison tree for differing templates
  -fdollars-in-identifiers
                          Allow '$' in identifiers
  -fdouble-square-bracket-attributes
                          Enable '[[]]' attributes in all C and C++ language modes
  -fdwarf-exceptions      Use DWARF style exceptions
  -fembed-bitcode-marker  Embed placeholder LLVM IR data as a marker
  -fembed-bitcode=<option>
                          Embed LLVM bitcode (option: off, all, bitcode, marker)
  -fembed-bitcode         Embed LLVM IR bitcode as data
  -femit-all-decls        Emit all declarations, even if unused
  -femulated-tls          Use emutls functions to access thread_local variables
  -fexceptions            Enable support for exception handling
  -fexperimental-isel     Enables the experimental global instruction selector
  -fexperimental-new-pass-manager
                          Enables an experimental new pass manager in LLVM.
  -ffast-math             Allow aggressive, lossy floating-point optimizations
  -ffine-grained-bitfield-accesses
                          Use separate accesses for bitfields with legal widths and alignments.
  -ffixed-r9              Reserve the r9 register (ARM only)
  -ffixed-x18             Reserve the x18 register (AArch64 only)
  -ffp-contract=<value>   Form fused FP ops (e.g. FMAs): fast (everywhere) | on (according to FP_CONTRACT pragma, default) | off (never fuse)
  -ffreestanding          Assert that the compilation takes place in a freestanding environment
  -ffunction-sections     Place each function in its own section (ELF Only)
  -fgnu-keywords          Allow GNU-extension keywords regardless of language standard
  -fgnu-runtime           Generate output compatible with the standard GNU Objective-C runtime
  -fgnu89-inline          Use the gnu89 inline semantics
  -fimplicit-module-maps  Implicitly search the file system for module map files.
  -finline-functions      Inline suitable functions
  -finline-hint-functions Inline functions which are (explicitly or implicitly) marked inline
  -finstrument-function-entry-bare
                          Instrument function entry only, after inlining, without arguments to the instrumentation call
  -finstrument-functions-after-inlining
                          Like -finstrument-functions, but insert the calls after inlining
  -finstrument-functions  Generate calls to instrument function entry and exit
  -fintegrated-as         Enable the integrated assembler
  -flto-jobs=<value>      Controls the backend parallelism of -flto=thin (default of 0 means the number of threads will be derived from the number of CPUs detected)
  -flto=<value>           Set LTO mode to either 'full' or 'thin'
  -flto                   Enable LTO in 'full' mode
  -fmath-errno            Require math functions to indicate errors by setting errno
  -fmax-type-align=<value>
                          Specify the maximum alignment to enforce on pointers lacking an explicit alignment
  -fmodule-file=[<name>=]<file>
                          Specify the mapping of module name to precompiled module file, or load a module file if name is omitted.
  -fmodule-map-file=<file>
                          Load this module map file
  -fmodule-name=<name>    Specify the name of the module to build
  -fmodules-cache-path=<directory>
                          Specify the module cache path
  -fmodules-decluse       Require declaration of modules used within a module
  -fmodules-disable-diagnostic-validation
                          Disable validation of the diagnostic options when loading the module
  -fmodules-ignore-macro=<value>
                          Ignore the definition of the given macro when building and loading modules
  -fmodules-prune-after=<seconds>
                          Specify the interval (in seconds) after which a module file will be considered unused
  -fmodules-prune-interval=<seconds>
                          Specify the interval (in seconds) between attempts to prune the module cache
  -fmodules-search-all    Search even non-imported modules to resolve references
  -fmodules-strict-decluse
                          Like -fmodules-decluse but requires all headers to be in modules
  -fmodules-ts            Enable support for the C++ Modules TS
  -fmodules-user-build-path <directory>
                          Specify the module user build path
  -fmodules-validate-once-per-build-session
                          Don't verify input files for the modules if the module has been successfully validated or loaded during this build session
  -fmodules-validate-system-headers
                          Validate the system headers that a module depends on when loading the module
  -fmodules               Enable the 'modules' language feature
  -fms-compatibility-version=<value>
                          Dot-separated value representing the Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fms-compatibility      Enable full Microsoft Visual C++ compatibility
  -fms-extensions         Accept some non-standard constructs supported by the Microsoft compiler
  -fmsc-version=<value>   Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fnew-alignment=<align> Specifies the largest alignment guaranteed by '::operator new(size_t)'
  -fno-access-control     Disable C++ access control
  -fno-assume-sane-operator-new
                          Don't assume that C++'s global operator new can't alias any pointer
  -fno-autolink           Disable generation of linker directives for automatic library linking
  -fno-builtin-<value>    Disable implicit builtin knowledge of a specific function
  -fno-builtin            Disable implicit builtin knowledge of functions
  -fno-common             Compile common globals like normal definitions
  -fno-constant-cfstrings Disable creation of CodeFoundation-type constant strings
  -fno-coverage-mapping   Disable code coverage analysis
  -fno-crash-diagnostics  Disable auto-generation of preprocessed source files and a script for reproduction during a clang crash
  -fno-debug-info-for-profiling
                          Do not emit extra debug info for sample profiler.
  -fno-debug-macro        Do not emit macro debug information
  -fno-declspec           Disallow __declspec as a keyword
  -fno-delayed-template-parsing
                          Disable delayed template parsing
  -fno-diagnostics-fixit-info
                          Do not include fixit information in diagnostics
  -fno-dollars-in-identifiers
                          Disallow '$' in identifiers
  -fno-double-square-bracket-attributes
                          Disable '[[]]' attributes in all C and C++ language modes
  -fno-elide-constructors Disable C++ copy constructor elision
  -fno-elide-type         Do not elide types when printing diagnostics
  -fno-experimental-isel  Disables the experimental global instruction selector
  -fno-experimental-new-pass-manager
                          Disables an experimental new pass manager in LLVM.
  -fno-fine-grained-bitfield-accesses
                          Use large-integer access for consecutive bitfield runs.
  -fno-gnu-inline-asm     Disable GNU style inline asm
  -fno-integrated-as      Disable the integrated assembler
  -fno-jump-tables        Do not use jump tables for lowering switches
  -fno-lax-vector-conversions
                          Disallow implicit conversions between vectors with a different number of elements or different element types
  -fno-lto                Disable LTO mode (default)
  -fno-merge-all-constants
                          Disallow merging of constants
  -fno-objc-infer-related-result-type
                          do not infer Objective-C related result type based on method family
  -fno-openmp-simd        Disable OpenMP code for SIMD-based constructs.
  -fno-operator-names     Do not treat C++ operator name keywords as synonyms for operators
  -fno-plt                Do not use the PLT to make function calls
  -fno-preserve-as-comments
                          Do not preserve comments in inline assembly
  -fno-profile-generate   Disable generation of profile instrumentation.
  -fno-profile-instr-generate
  -fno-profile-instr-use  Disable using instrumentation data for profile-guided optimization
  -fno-reroll-loops       Turn off loop reroller
  -fno-rtlib-add-rpath    Do not add -rpath with architecture-specific resource directory to the linker flags
  -fno-rtti               Disable generation of rtti information
  -fno-sanitize-address-use-after-scope
                          Disable use-after-scope detection in AddressSanitizer
  -fno-sanitize-blacklist Don't use blacklist file for sanitizers
  -fno-sanitize-cfi-cross-dso
                          Disable control flow integrity (CFI) checks for cross-DSO calls.
  -fno-sanitize-coverage=<value>
                          Disable specified features of coverage instrumentation for Sanitizers
  -fno-sanitize-memory-track-origins
                          Disable origins tracking in MemorySanitizer
  -fno-sanitize-memory-use-after-dtor
                          Disable use-after-destroy detection in MemorySanitizer
  -fno-sanitize-recover=<value>
                          Disable recovery for specified sanitizers
  -fno-sanitize-stats     Disable sanitizer statistics gathering.
  -fno-sanitize-thread-atomics
                          Disable atomic operations instrumentation in ThreadSanitizer
  -fno-sanitize-thread-func-entry-exit
                          Disable function entry/exit instrumentation in ThreadSanitizer
  -fno-sanitize-thread-memory-access
                          Disable memory access instrumentation in ThreadSanitizer
  -fno-sanitize-trap=<value>
                          Disable trapping for specified sanitizers
  -fno-short-wchar        Force wchar_t to be an unsigned int
  -fno-show-column        Do not include column number on diagnostics
  -fno-show-source-location
                          Do not include source location information with diagnostics
  -fno-signed-char        Char is unsigned
  -fno-signed-zeros       Allow optimizations that ignore the sign of floating point zeros
  -fno-spell-checking     Disable spell-checking
  -fno-stack-protector    Disable the use of stack protectors
  -fno-standalone-debug   Limit debug information produced to reduce size of debug binary
  -fno-threadsafe-statics Do not emit code to make initialization of local statics thread safe
  -fno-trigraphs          Do not process trigraph sequences
  -fno-unroll-loops       Turn off loop unroller
  -fno-use-cxa-atexit     Don't use __cxa_atexit for calling destructors
  -fno-use-init-array     Don't use .init_array instead of .ctors
  -fnoopenmp-relocatable-target
                          Do not compile OpenMP target code as relocatable.
  -fobjc-arc-exceptions   Use EH-safe code when synthesizing retains and releases in -fobjc-arc
  -fobjc-arc              Synthesize retain and release calls for Objective-C pointers
  -fobjc-exceptions       Enable Objective-C exceptions
  -fobjc-runtime=<value>  Specify the target Objective-C runtime kind and version
  -fobjc-weak             Enable ARC-style weak references in Objective-C
  -fopenmp-relocatable-target
                          OpenMP target code is compiled as relocatable using the -c flag. For OpenMP targets the code is relocatable by default.
  -fopenmp-simd           Emit OpenMP code only for SIMD-based constructs.
  -fopenmp-targets=<value>
                          Specify comma-separated list of triples OpenMP offloading targets to be supported
  -foptimization-record-file=<value>
                          Specify the file name of any generated YAML optimization record
  -fpack-struct=<value>   Specify the default maximum struct packing alignment
  -fpascal-strings        Recognize and construct Pascal-style string literals
  -fpcc-struct-return     Override the default ABI to return all structs on the stack
  -fplt                   Use the PLT to make function calls
  -fplugin=<dsopath>      Load the named plugin (dynamic shared object)
  -fprebuilt-module-path=<directory>
                          Specify the prebuilt module path
  -fprofile-generate=<directory>
                          Generate instrumented code to collect execution counts into <directory>/default.profraw (overridden by LLVM_PROFILE_FILE env var)
  -fprofile-generate      Generate instrumented code to collect execution counts into default.profraw (overridden by LLVM_PROFILE_FILE env var)
  -fprofile-instr-generate=<file>
                          Generate instrumented code to collect execution counts into <file> (overridden by LLVM_PROFILE_FILE env var)
                          Generate instrumented code to collect execution counts into default.profraw file (overridden by '=' form of option or LLVM_PROFILE_FILE env var)
  -fprofile-instr-use=<value>
                          Use instrumentation data for profile-guided optimization
  -fprofile-sample-accurate
                          Specifies that the sample profile is accurate
  -fprofile-sample-use=<value>
                          Enable sample-based profile guided optimizations
  -fprofile-use=<pathname>
                          Use instrumentation data for profile-guided optimization. If pathname is a directory, it reads from <pathname>/default.profdata. Otherwise, it reads from file <pathname>.
  -freciprocal-math       Allow division operations to be reassociated
  -freg-struct-return     Override the default ABI to return small structs in registers
  -frelaxed-template-template-args
                          Enable C++17 relaxed template template argument matching
  -freroll-loops          Turn on loop reroller
  -frtlib-add-rpath       Add -rpath with architecture-specific resource directory to the linker flags
  -fsanitize-address-field-padding=<value>
                          Level of field padding for AddressSanitizer
  -fsanitize-address-globals-dead-stripping
                          Enable linker dead stripping of globals in AddressSanitizer
  -fsanitize-address-use-after-scope
                          Enable use-after-scope detection in AddressSanitizer
  -fsanitize-blacklist=<value>
                          Path to blacklist file for sanitizers
  -fsanitize-cfi-cross-dso
                          Enable control flow integrity (CFI) checks for cross-DSO calls.
  -fsanitize-cfi-icall-generalize-pointers
                          Generalize pointers in CFI indirect call type signature checks
  -fsanitize-coverage=<value>
                          Specify the type of coverage instrumentation for Sanitizers
  -fsanitize-memory-track-origins=<value>
                          Enable origins tracking in MemorySanitizer
  -fsanitize-memory-use-after-dtor
                          Enable use-after-destroy detection in MemorySanitizer
  -fsanitize-recover=<value>
                          Enable recovery for specified sanitizers
  -fsanitize-stats        Enable sanitizer statistics gathering.
  -fsanitize-thread-atomics
                          Enable atomic operations instrumentation in ThreadSanitizer (default)
  -fsanitize-thread-func-entry-exit
                          Enable function entry/exit instrumentation in ThreadSanitizer (default)
  -fsanitize-thread-memory-access
                          Enable memory access instrumentation in ThreadSanitizer (default)
  -fsanitize-trap=<value> Enable trapping for specified sanitizers
  -fsanitize-undefined-strip-path-components=<number>
                          Strip (or keep only, if negative) a given number of path components when emitting check metadata.
  -fsanitize=<check>      Turn on runtime checks for various forms of undefined or suspicious behavior. See user manual for available checks
  -fsave-optimization-record
                          Generate a YAML optimization record file
  -fseh-exceptions        Use SEH style exceptions
  -fshort-enums           Allocate to an enum type only as many bytes as it needs for the declared range of possible values
  -fshort-wchar           Force wchar_t to be a short unsigned int
  -fshow-overloads=<value>
                          Which overload candidates to show when overload resolution fails: best|all; defaults to all
  -fsized-deallocation    Enable C++14 sized global deallocation functions
  -fsjlj-exceptions       Use SjLj style exceptions
  -fslp-vectorize         Enable the superword-level parallelism vectorization passes
  -fsplit-dwarf-inlining  Place debug types in their own section (ELF Only)
  -fstack-protector-all   Force the usage of stack protectors for all functions
  -fstack-protector-strong
                          Use a strong heuristic to apply stack protectors to functions
  -fstack-protector       Enable stack protectors for functions potentially vulnerable to stack smashing
  -fstandalone-debug      Emit full debug info for all types used by the program
  -fstrict-enums          Enable optimizations based on the strict definition of an enum's value range
  -fstrict-return         Always treat control flow paths that fall off the end of a non-void function as unreachable
  -fstrict-vtable-pointers
                          Enable optimizations based on the strict rules for overwriting polymorphic C++ objects
  -fthinlto-index=<value> Perform ThinLTO importing using provided function summary index
  -ftrap-function=<value> Issue call to specified function rather than a trap instruction
  -ftrapv-handler=<function name>
                          Specify the function to be called on overflow
  -ftrapv                 Trap on integer overflow
  -ftrigraphs             Process trigraph sequences
  -funique-section-names  Use unique names for text and data sections (ELF Only)
  -funroll-loops          Turn on loop unroller
  -fuse-init-array        Use .init_array instead of .ctors
  -fveclib=<value>        Use the given vector functions library
  -fvectorize             Enable the loop vectorization passes
  -fvisibility-inlines-hidden
                          Give inline C++ member functions default visibility by default
  -fvisibility-ms-compat  Give global types 'default' visibility and global functions and variables 'hidden' visibility by default
  -fvisibility=<value>    Set the default symbol visibility for all global declarations
  -fwhole-program-vtables Enables whole-program vtable optimization. Requires -flto
  -fwrapv                 Treat signed integer overflow as two's complement
  -fwritable-strings      Store string literals as writable data
  -fxray-always-emit-customevents
                          Determine whether to always emit __xray_customevent(...) calls even if the function it appears in is not always instrumented.
  -fxray-always-instrument= <value>
                          Filename defining the whitelist for imbuing the 'always instrument' XRay attribute.
  -fxray-instruction-threshold= <value>
                          Sets the minimum function size to instrument with XRay
  -fxray-instrument       Generate XRay instrumentation sleds on function entry and exit
  -fxray-never-instrument= <value>
                          Filename defining the whitelist for imbuing the 'never instrument' XRay attribute.
  -fzvector               Enable System z vector language extension
  -F <value>              Add directory to framework include search path
  --gcc-toolchain=<value> Use the gcc toolchain at the given directory
  -gcodeview              Generate CodeView debug information
  -gdwarf-2               Generate source-level debug information with dwarf version 2
  -gdwarf-3               Generate source-level debug information with dwarf version 3
  -gdwarf-4               Generate source-level debug information with dwarf version 4
  -gdwarf-5               Generate source-level debug information with dwarf version 5
  -gline-tables-only      Emit debug line number tables only
  -gmodules               Generate debug info with external references to clang modules or precompiled headers
  -gz=<value>             DWARF debug sections compression type
  -gz                     DWARF debug sections compression type
  -G <size>               Put objects of at most <size> bytes into small data section (MIPS / Hexagon)
  -g                      Generate source-level debug information
  -help                   Display available options
  -H                      Show header includes and nesting depth
  -I-                     Restrict all prior -I flags to double-quoted inclusion and remove current directory from include path
  -idirafter <value>      Add directory to AFTER include search path
  -iframeworkwithsysroot <directory>
                          Add directory to SYSTEM framework search path, absolute paths are relative to -isysroot
  -iframework <value>     Add directory to SYSTEM framework search path
  -imacros <file>         Include macros from file before parsing
  -include-pch <file>     Include precompiled header file
  -include <file>         Include file before parsing
  -index-header-map       Make the next included directory (-I or -F) an indexer header map
  -iprefix <dir>          Set the -iwithprefix/-iwithprefixbefore prefix
  -iquote <directory>     Add directory to QUOTE include search path
  -isysroot <dir>         Set the system root directory (usually /)
  -isystem-after <directory>
                          Add directory to end of the SYSTEM include search path
  -isystem <directory>    Add directory to SYSTEM include search path
  -ivfsoverlay <value>    Overlay the virtual filesystem described by file over the real file system
  -iwithprefixbefore <dir>
                          Set directory to include search path with prefix
  -iwithprefix <dir>      Set directory to SYSTEM include search path with prefix
  -iwithsysroot <directory>
                          Add directory to SYSTEM include search path, absolute paths are relative to -isysroot
  -I <dir>                Add directory to include search path
  -L <dir>                Add directory to library search path
  -mabicalls              Enable SVR4-style position-independent code (Mips only)
  -malign-double          Align doubles to two words in structs (x86 only)
  -mbackchain             Link stack frames through backchain on System Z
  -mcrc                   Allow use of CRC instructions (ARM only)
  -MD                     Write a depfile containing user and system headers
  -meabi <value>          Set EABI type, e.g. 4, 5 or gnu (default depends on triple)
  -membedded-data         Place constants in the .rodata section instead of the .sdata section even if they meet the -G <size> threshold (MIPS)
  -mexecute-only          Disallow generation of data access to code sections (ARM only)
  -mextern-sdata          Assume that externally defined data is in the small data if it meets the -G <size> threshold (MIPS)
  -mfentry                Insert calls to fentry at function entry (x86 only)
  -mfix-cortex-a53-835769 Workaround Cortex-A53 erratum 835769 (AArch64 only)
  -mfp32                  Use 32-bit floating point registers (MIPS only)
  -mfp64                  Use 64-bit floating point registers (MIPS only)
  -MF <file>              Write depfile output from -MMD, -MD, -MM, or -M to <file>
  -mgeneral-regs-only     Generate code which only uses the general purpose registers (AArch64 only)
  -mglobal-merge          Enable merging of globals
  -mgpopt                 Use GP relative accesses for symbols known to be in a small data section (MIPS)
  -MG                     Add missing headers to depfile
  -mhvx-double            Enable Hexagon Double Vector eXtensions
  -mhvx-length=<value>    Set Hexagon Vector Length
  -mhvx=<value>           Enable Hexagon Vector eXtensions
  -mhvx                   Enable Hexagon Vector eXtensions
  -miamcu                 Use Intel MCU ABI
  --migrate               Run the migrator
  -mincremental-linker-compatible
                          (integrated-as) Emit an object file which can be used with an incremental linker
  -mios-version-min=<value>
                          Set iOS deployment target
  -MJ <value>             Write a compilation database entry per input
  -mllvm <value>          Additional arguments to forward to LLVM's option processing
  -mlocal-sdata           Extend the -G behaviour to object local data (MIPS)
  -mlong-calls            Generate branches with extended addressability, usually via indirect jumps.
  -mmacosx-version-min=<value>
                          Set Mac OS X deployment target
  -mmadd4                 Enable the generation of 4-operand madd.s, madd.d and related instructions.
  -MMD                    Write a depfile containing user headers
  -mms-bitfields          Set the default structure layout to be compatible with the Microsoft compiler standard
  -mmsa                   Enable MSA ASE (MIPS only)
  -mmt                    Enable MT ASE (MIPS only)
  -MM                     Like -MMD, but also implies -E and writes to stdout by default
  -mno-abicalls           Disable SVR4-style position-independent code (Mips only)
  -mno-embedded-data      Do not place constants in the .rodata section instead of the .sdata if they meet the -G <size> threshold (MIPS)
  -mno-execute-only       Allow generation of data access to code sections (ARM only)
  -mno-extern-sdata       Do not assume that externally defined data is in the small data if it meets the -G <size> threshold (MIPS)
  -mno-fix-cortex-a53-835769
                          Don't workaround Cortex-A53 erratum 835769 (AArch64 only)
  -mno-global-merge       Disable merging of globals
  -mno-gpopt              Do not use GP relative accesses for symbols known to be in a small data section (MIPS)
  -mno-hvx-double         Disable Hexagon Double Vector eXtensions
  -mno-hvx                Disable Hexagon Vector eXtensions
  -mno-implicit-float     Don't generate implicit floating point instructions
  -mno-incremental-linker-compatible
                          (integrated-as) Emit an object file which cannot be used with an incremental linker
  -mno-local-sdata        Do not extend the -G behaviour to object local data (MIPS)
  -mno-long-calls         Restore the default behaviour of not generating long calls
  -mno-madd4              Disable the generation of 4-operand madd.s, madd.d and related instructions.
  -mno-movt               Disallow use of movt/movw pairs (ARM only)
  -mno-ms-bitfields       Do not set the default structure layout to be compatible with the Microsoft compiler standard
  -mno-msa                Disable MSA ASE (MIPS only)
  -mno-mt                 Disable MT ASE (MIPS only)
  -mno-neg-immediates     Disallow converting instructions with negative immediates to their negation or inversion.
  -mno-restrict-it        Allow generation of deprecated IT blocks for ARMv8. It is off by default for ARMv8 Thumb mode
  -mno-unaligned-access   Force all memory accesses to be aligned (AArch32/AArch64 only)
  -mno-xnack              Disable XNACK (AMDGPU only)
  -mnocrc                 Disallow use of CRC instructions (ARM only)
  -module-dependency-dir <value>
                          Directory to dump module dependencies to
  -module-file-info       Provide information about a particular module file
  -momit-leaf-frame-pointer
                          Omit frame pointer setup for leaf functions
  -mpie-copy-relocations  Use copy relocations support for PIE builds
  -mprefer-vector-width=<value>
                          Specifies preferred vector width for auto-vectorization. Defaults to 'none' which allows target specific decisions.
  -MP                     Create phony target for each dependency (other than main file)
  -mqdsp6-compat          Enable hexagon-qdsp6 backward compatibility
  -MQ <value>             Specify name of main file output to quote in depfile
  -mrelax-all             (integrated-as) Relax all machine instructions
  -mrestrict-it           Disallow generation of deprecated IT blocks for ARMv8. It is on by default for ARMv8 Thumb mode.
  -mrtd                   Make StdCall calling convention the default
  -msoft-float            Use software floating point
  -mstack-alignment=<value>
                          Set the stack alignment
  -mstack-probe-size=<value>
                          Set the stack probe size
  -mstackrealign          Force realign the stack at entry to every function
  -mthread-model <value>  The thread model to use, e.g. posix, single (posix by default)
  -mtp=<value>            Read thread pointer from coprocessor register (ARM only)
  -MT <value>             Specify name of main file output in depfile
  -munaligned-access      Allow memory accesses to be unaligned (AArch32/AArch64 only)
  -MV                     Use NMake/Jom format for the depfile
  -mxnack                 Enable XNACK (AMDGPU only)
  -M                      Like -MD, but also implies -E and writes to stdout by default
  --no-cuda-gpu-arch=<value>
                          Remove GPU architecture (e.g. sm_35) from the list of GPUs to compile for. 'all' resets the list to its default value.
  --no-cuda-version-check Don't error out if the detected version of the CUDA install is too low for the requested CUDA gpu architecture.
  --no-system-header-prefix=<prefix>
                          Treat all #include paths starting with <prefix> as not including a system header.
  -nobuiltininc           Disable builtin #include directories
  -nostdinc++             Disable standard #include directories for the C++ standard library
  -ObjC++                 Treat source input files as Objective-C++ inputs
  -objcmt-atomic-property Make migration to 'atomic' properties
  -objcmt-migrate-all     Enable migration to modern ObjC
  -objcmt-migrate-annotation
                          Enable migration to property and method annotations
  -objcmt-migrate-designated-init
                          Enable migration to infer NS_DESIGNATED_INITIALIZER for initializer methods
  -objcmt-migrate-instancetype
                          Enable migration to infer instancetype for method result type
  -objcmt-migrate-literals
                          Enable migration to modern ObjC literals
  -objcmt-migrate-ns-macros
                          Enable migration to NS_ENUM/NS_OPTIONS macros
  -objcmt-migrate-property-dot-syntax
                          Enable migration of setter/getter messages to property-dot syntax
                          Enable migration to modern ObjC property
  -objcmt-migrate-protocol-conformance
                          Enable migration to add protocol conformance on classes
  -objcmt-migrate-readonly-property
                          Enable migration to modern ObjC readonly property
  -objcmt-migrate-readwrite-property
                          Enable migration to modern ObjC readwrite property
  -objcmt-migrate-subscripting
                          Enable migration to modern ObjC subscripting
  -objcmt-ns-nonatomic-iosonly
                          Enable migration to use NS_NONATOMIC_IOSONLY macro for setting property's 'atomic' attribute
  -objcmt-returns-innerpointer-property
                          Enable migration to annotate property with NS_RETURNS_INNER_POINTER
  -objcmt-whitelist-dir-path=<value>
                          Only modify files with a filename contained in the provided directory path
  -ObjC                   Treat source input files as Objective-C inputs
  -o <file>               Write output to <file>
  -pg                     Enable mcount instrumentation
  -pipe                   Use pipes between commands, when possible
  --precompile            Only precompile the input
  -print-file-name=<file> Print the full library path of <file>
  -print-ivar-layout      Enable Objective-C Ivar layout bitmap print trace
  -print-libgcc-file-name Print the library path for the currently used compiler runtime library ("libgcc.a" or "libclang_rt.builtins.*.a")
  -print-prog-name=<name> Print the full program path of <name>
  -print-resource-dir     Print the resource directory pathname
  -print-search-dirs      Print the paths used for finding libraries and programs
  -pthread                Support POSIX threads in generated code
  --ptxas-path=<value>    Path to ptxas (used for compiling CUDA code)
  -P                      Disable linemarker output in -E mode
  -Qunused-arguments      Don't emit warning for unused driver arguments
  -relocatable-pch        Whether to build a relocatable precompiled header
  -rewrite-legacy-objc    Rewrite Legacy Objective-C source to C++
  -rewrite-objc           Rewrite Objective-C source to C++
  -Rpass-analysis=<value> Report transformation analysis from optimization passes whose name matches the given POSIX regular expression
  -Rpass-missed=<value>   Report missed transformations by optimization passes whose name matches the given POSIX regular expression
  -Rpass=<value>          Report transformations performed by optimization passes whose name matches the given POSIX regular expression
  -rtlib=<value>          Compiler runtime library to use
  -R<remark>              Enable the specified remark
  -save-stats=<value>     Save llvm statistics.
  -save-stats             Save llvm statistics.
  -save-temps=<value>     Save intermediate compilation results.
  -save-temps             Save intermediate compilation results
  -serialize-diagnostics <value>
                          Serialize compiler diagnostics to a file
  -std=<value>            Language standard to compile for
  -stdlib=<value>         C++ standard library to use
  --system-header-prefix=<prefix>
                          Treat all #include paths starting with <prefix> as including a system header.
  -S                      Only run preprocess and compilation steps
  --target=<value>        Generate code for the given target
  -Tbss <addr>            Set starting address of BSS to <addr>
  -Tdata <addr>           Set starting address of BSS to <addr>
  -time                   Time individual commands
  -traditional-cpp        Enable some traditional CPP emulation
  -trigraphs              Process trigraph sequences
  -Ttext <addr>           Set starting address of BSS to <addr>
  -T <script>             Specify <script> as linker script
  -undef                  undef all system defines
  -U <macro>              Undefine macro <macro>
  --verify-debug-info     Verify the binary representation of debug output
  -verify-pch             Load and verify that a pre-compiled header file is not stale
  --version               Print version information
  -v                      Show commands to run and use verbose output
  -Wa,<arg>               Pass the comma separated arguments in <arg> to the assembler
  -Wdeprecated            Enable warnings for deprecated constructs and define __DEPRECATED
  -Wl,<arg>               Pass the comma separated arguments in <arg> to the linker
  -working-directory <value>
                          Resolve file paths relative to the specified directory
  -Wp,<arg>               Pass the comma separated arguments in <arg> to the preprocessor
  -W<warning>             Enable the specified warning
  -w                      Suppress all warnings
  -Xanalyzer <arg>        Pass <arg> to the static analyzer
  -Xassembler <arg>       Pass <arg> to the assembler
  -Xclang <arg>           Pass <arg> to the clang compiler
  -Xcuda-fatbinary <arg>  Pass <arg> to fatbinary invocation
  -Xcuda-ptxas <arg>      Pass <arg> to the ptxas assembler
  -Xlinker <arg>          Pass <arg> to the linker
  -Xopenmp-target=<arg>   Pass <arg> to the specified target offloading toolchain. The triple that identifies the toolchain must be provided after the equals sign.
  -Xopenmp-target <arg>   Pass <arg> to the target offloading toolchain.
  -Xpreprocessor <arg>    Pass <arg> to the preprocessor
  -x <language>           Treat subsequent input files as having type <language>
  -z <arg>                Pass -z <arg> to the linker
Checking for program /usr/local/bin/mpicc...found
                Defined make macro "CC" to "mpicc"
                Pushing language C
                            All intermediate test results are stored in /tmp/petsc-mjVUVK
                          All intermediate test results are stored in /tmp/petsc-mjVUVK/config.setCompilers
Executing: mpicc -c -o /tmp/petsc-mjVUVK/config.setCompilers/conftest.o -I/tmp/petsc-mjVUVK/config.setCompilers   /tmp/petsc-mjVUVK/config.setCompilers/conftest.c
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                                Pushing language C
                                                Popping language C
                                                Pushing language FC
                                                Popping language FC
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
                        Pushing language C
                        Popping language C
Executing: mpicc  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
clang-6.0: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
                            Pushing language C
                            Popping language C
Testing executable /tmp/petsc-mjVUVK/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-mjVUVK/config.setCompilers/conftest
                Popping language C
TEST checkCPreprocessor from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:599)
TESTING: checkCPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:599)
  Locate a functional C preprocessor
                Defined make macro "CPP" to "mpicc -E"
              Pushing language C
Executing: mpicc -E  -I/tmp/petsc-mjVUVK/config.setCompilers  /tmp/petsc-mjVUVK/config.setCompilers/conftest.c
stdout:
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.c"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 360 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.c" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conffix.h" 1
# 3 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.c" 2
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 190 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 191 "/usr/include/Availability.h" 2 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 587 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 588 "/usr/include/sys/cdefs.h" 2 3 4
# 653 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 654 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 55 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 1 "/usr/include/sys/_pthread/_pthread_types.h" 1 3 4
# 57 "/usr/include/sys/_pthread/_pthread_types.h" 3 4
struct __darwin_pthread_handler_rec {
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t {
 long __sig;
 char __opaque[56];
struct _opaque_pthread_cond_t {
 long __sig;
 char __opaque[40];
struct _opaque_pthread_condattr_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_mutex_t {
 long __sig;
 char __opaque[56];
struct _opaque_pthread_mutexattr_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_once_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_rwlock_t {
 long __sig;
 char __opaque[192];
struct _opaque_pthread_rwlockattr_t {
 long __sig;
 char __opaque[16];
struct _opaque_pthread_t {
 long __sig;
 struct __darwin_pthread_handler_rec *__cleanup_stack;
 char __opaque[8176];
typedef struct _opaque_pthread_attr_t __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t *__darwin_pthread_t;
# 81 "/usr/include/sys/_types.h" 2 3 4
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 83 "/usr/include/sys/signal.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_pthread/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_pthread/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 149 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 155 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 156 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 157 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 269 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 331 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 348 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 367 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 390 "/usr/include/sys/signal.h" 3 4
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 1 3 4
# 63 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 64 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 2 3 4
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 152 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 163 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 192 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
struct rusage_info_v3 {
 uint64_t ri_cpu_time_qos_default;
 uint64_t ri_cpu_time_qos_maintenance;
 uint64_t ri_cpu_time_qos_background;
 uint64_t ri_cpu_time_qos_utility;
 uint64_t ri_cpu_time_qos_legacy;
 uint64_t ri_cpu_time_qos_user_initiated;
 uint64_t ri_cpu_time_qos_user_interactive;
 uint64_t ri_billed_system_time;
 uint64_t ri_serviced_system_time;
typedef struct rusage_info_v3 rusage_info_current;
# 325 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 353 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 385 "/usr/include/sys/resource.h" 3 4
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit" );
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit" );
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 130 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 131 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 248 "/usr/include/sys/wait.h" 3 4
pid_t wait(int *) __asm("_" "wait" );
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid" );
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid" );
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 32 "/usr/include/alloca.h" 3 4
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 33 "/usr/include/sys/_types/_wchar_t.h" 3 4
typedef __darwin_wchar_t wchar_t;
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 128 "/usr/include/stdlib.h" 3 4
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (* _Nonnull)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *__key, const void *__base, size_t __nel,
     size_t __width, int (* _Nonnull __compar)(const void *, const void *));
void *calloc(size_t __count, size_t __size) __attribute__((__warn_unused_result__));
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t __size) __attribute__((__warn_unused_result__));
int mblen(const char *__s, size_t __n);
size_t mbstowcs(wchar_t * restrict , const char * restrict, size_t);
int mbtowc(wchar_t * restrict, const char * restrict, size_t);
int posix_memalign(void **__memptr, size_t __alignment, size_t __size) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *__base, size_t __nel, size_t __width,
int rand(void) ;
void *realloc(void *__ptr, size_t __size) __attribute__((__warn_unused_result__));
void srand(unsigned) ;
double strtod(const char *, char **) __asm("_" "strtod" );
float strtof(const char *, char **) __asm("_" "strtof" );
long strtol(const char *__str, char **__endptr, int __base);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *__str, char **__endptr, int __base);
unsigned long
  strtoul(const char *__str, char **__endptr, int __base);
unsigned long long
  strtoull(const char *__str, char **__endptr, int __base);
# 185 "/usr/include/stdlib.h" 3 4
__attribute__((availability(macosx,introduced=10.0)))
__attribute__((availability(watchos,unavailable))) __attribute__((availability(tvos,unavailable)))
int system(const char *) __asm("_" "system" );
size_t wcstombs(char * restrict, const wchar_t * restrict, size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *restrict, int *restrict);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *restrict, int *restrict);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]) ;
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void) ;
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void) ;
long nrand48(unsigned short[3]) ;
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv" );
long random(void) ;
int rand_r(unsigned *) ;
char *realpath(const char * restrict, char * restrict) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char * __name, const char * __value, int __overwrite) __asm("_" "setenv" );
void setkey(const char *) __asm("_" "setkey" );
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv" );
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
# 1 "/usr/include/sys/_types/_u_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int8_t.h" 3 4
typedef unsigned char u_int8_t;
# 82 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int16_t.h" 3 4
typedef unsigned short u_int16_t;
# 83 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int32_t.h" 3 4
typedef unsigned int u_int32_t;
# 84 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int64_t.h" 3 4
typedef unsigned long long u_int64_t;
# 85 "/usr/include/i386/types.h" 2 3 4
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 36 "/usr/include/machine/types.h" 2 3 4
# 252 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 254 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 255 "/usr/include/stdlib.h" 2 3 4
uint32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int )
    __attribute__((availability(macosx,introduced=10.0))) __attribute__((availability(macosx,deprecated=10.12,message="use arc4random_stir")))
    __attribute__((availability(ios,introduced=2.0))) __attribute__((availability(ios,deprecated=10.0,message="use arc4random_stir")))
    __attribute__((availability(tvos,introduced=2.0))) __attribute__((availability(tvos,deprecated=10.0,message="use arc4random_stir")))
    __attribute__((availability(watchos,introduced=1.0))) __attribute__((availability(watchos,deprecated=3.0,message="use arc4random_stir")));
void arc4random_buf(void * __buf, size_t __nbytes) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
uint32_t
  arc4random_uniform(uint32_t __upper_bound) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^ _Nonnull)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *__key, const void *__base, size_t __nel,
     size_t __width, int (^ _Nonnull __compar)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5,message="Use posix_spawn APIs instead."))) __attribute__((availability(watchos,unavailable))) __attribute__((availability(tvos,unavailable)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *__base, size_t __nel, size_t __width,
int heapsort_b(void *__base, size_t __nel, size_t __width,
int mergesort(void *__base, size_t __nel, size_t __width,
int mergesort_b(void *__base, size_t __nel, size_t __width,
void psort(void *__base, size_t __nel, size_t __width,
     int (* _Nonnull __compar)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *__base, size_t __nel, size_t __width,
void psort_r(void *__base, size_t __nel, size_t __width, void *,
     int (* _Nonnull __compar)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *__base, size_t __nel, size_t __width,
void qsort_r(void *__base, size_t __nel, size_t __width, void *,
     int (* _Nonnull __compar)(void *, const void *, const void *));
int radixsort(const unsigned char **__base, int __nel, const unsigned char *__table,
     unsigned __endbyte);
void setprogname(const char *);
int sradixsort(const unsigned char **__base, int __nel, const unsigned char *__table,
void sranddev(void);
void srandomdev(void);
void *reallocf(void *__ptr, size_t __size);
long long
  strtoq(const char *__str, char **__endptr, int __base);
unsigned long long
  strtouq(const char *__str, char **__endptr, int __base);
extern char *suboptarg;
void *valloc(size_t);
# 4 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.c" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
              Popping language C
TEST checkCUDACompiler from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:640)
TESTING: checkCUDACompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:640)
  Locate a functional CUDA compiler
TEST checkCUDAPreprocessor from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:680)
TESTING: checkCUDAPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:680)
  Locate a functional CUDA preprocessor
TEST checkCxxCompiler from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:792)
TESTING: checkCxxCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:792)
  Locate a functional Cxx compiler
Executing: mpicxx --help
stdout:
OVERVIEW: clang LLVM compiler
USAGE: clang-6.0 [options] <inputs>
OPTIONS:
  -###                    Print (but do not run) the commands to run for this compilation
  --analyzer-output <value>
                          Static analyzer report output format (html|plist|plist-multi-file|plist-html|text).
  --analyze               Run the static analyzer
  -arcmt-migrate-emit-errors
                          Emit ARC errors even if the migrator can fix them
  -arcmt-migrate-report-output <value>
                          Output path for the plist report
  -B <dir>                Add <dir> to search path for binaries and object files used implicitly
  -CC                     Include comments from within macros in preprocessed output
  -cl-denorms-are-zero    OpenCL only. Allow denormals to be flushed to zero.
  -cl-fast-relaxed-math   OpenCL only. Sets -cl-finite-math-only and -cl-unsafe-math-optimizations, and defines __FAST_RELAXED_MATH__.
  -cl-finite-math-only    OpenCL only. Allow floating-point optimizations that assume arguments and results are not NaNs or +-Inf.
  -cl-fp32-correctly-rounded-divide-sqrt
                          OpenCL only. Specify that single precision floating-point divide and sqrt used in the program source are correctly rounded.
  -cl-kernel-arg-info     OpenCL only. Generate kernel argument metadata.
  -cl-mad-enable          OpenCL only. Allow use of less precise MAD computations in the generated binary.
  -cl-no-signed-zeros     OpenCL only. Allow use of less precise no signed zeros computations in the generated binary.
  -cl-opt-disable         OpenCL only. This option disables all optimizations. By default optimizations are enabled.
  -cl-single-precision-constant
                          OpenCL only. Treat double precision floating-point constant as single precision constant.
  -cl-std=<value>         OpenCL language standard to compile for.
  -cl-strict-aliasing     OpenCL only. This option is added for compatibility with OpenCL 1.0.
                          OpenCL only. Allow unsafe floating-point optimizations.  Also implies -cl-no-signed-zeros and -cl-mad-enable.
  --config <value>        Specifies configuration file
  --cuda-compile-host-device
                          Compile CUDA code for both host and device (default).  Has no effect on non-CUDA compilations.
  --cuda-device-only      Compile CUDA code for device only
  --cuda-gpu-arch=<value> CUDA GPU architecture (e.g. sm_35).  May be specified more than once.
  --cuda-host-only        Compile CUDA code for host only.  Has no effect on non-CUDA compilations.
  --cuda-noopt-device-debug
                          Enable device-side debug info generation. Disables ptxas optimizations.
  --cuda-path=<value>     CUDA installation path
  -cxx-isystem <directory>
                          Add directory to the C++ SYSTEM include search path
  -C                      Include comments in preprocessed output
  -c                      Only run preprocess, compile, and assemble steps
  -dD                     Print macro definitions in -E mode in addition to normal output
  -dependency-dot <value> Filename to write DOT-formatted header dependencies to
  -dependency-file <value>
                          Filename (or -) to write dependency output to
  -dI                     Print include directives in -E mode in addition to normal output
  -dM                     Print macro definitions in -E mode instead of normal output
  -D <macro>=<value>      Define <macro> to <value> (or 1 if <value> omitted)
  -emit-ast               Emit Clang AST files for source inputs
  -emit-llvm              Use the LLVM representation for assembler and object files
  -E                      Only run the preprocessor
  -faligned-allocation    Enable C++17 aligned allocation functions
  -fallow-editor-placeholders
                          Treat editor placeholders as valid source code
  -fansi-escape-codes     Use ANSI escape codes for diagnostics
  -fapple-kext            Use Apple's kernel extensions ABI
  -fapple-pragma-pack     Enable Apple gcc-compatible #pragma pack handling
  -fapplication-extension Restrict code to those available for App Extensions
  -fblocks                Enable the 'blocks' language feature
  -fborland-extensions    Accept non-standard constructs supported by the Borland compiler
  -fbuild-session-file=<file>
                          Use the last modification time of <file> as the build session timestamp
  -fbuild-session-timestamp=<time since Epoch in seconds>
                          Time when the current build session started
  -fbuiltin-module-map    Load the clang builtins module map file.
  -fclang-abi-compat=<version>
                          Attempt to match the ABI of Clang <version>
  -fcolor-diagnostics     Use colors in diagnostics
  -fcomment-block-commands=<arg>
                          Treat each comma separated argument in <arg> as a documentation comment block command
  -fcoroutines-ts         Enable support for the C++ Coroutines TS
  -fcoverage-mapping      Generate coverage mapping to enable code coverage analysis
  -fcuda-approx-transcendentals
                          Use approximate transcendental functions
  -fcuda-flush-denormals-to-zero
                          Flush denormal floating point values to zero in CUDA device mode.
  -fcxx-exceptions        Enable C++ exceptions
  -fdata-sections         Place each data in its own section (ELF Only)
  -fdebug-info-for-profiling
                          Emit extra debug info to make sample profile more accurate.
  -fdebug-macro           Emit macro debug information
  -fdebug-prefix-map=<value>
                          remap file source paths in debug info
  -fdebug-types-section   Place debug types in their own section (ELF Only)
  -fdeclspec              Allow __declspec as a keyword
  -fdelayed-template-parsing
                          Parse templated function definitions at the end of the translation unit
  -fdiagnostics-absolute-paths
                          Print absolute paths in diagnostics
  -fdiagnostics-hotness-threshold=<number>
                          Prevent optimization remarks from being output if they do not have at least this profile count
  -fdiagnostics-parseable-fixits
                          Print fix-its in machine parseable form
  -fdiagnostics-print-source-range-info
                          Print source range spans in numeric form
  -fdiagnostics-show-hotness
                          Enable profile hotness information in diagnostic line
  -fdiagnostics-show-note-include-stack
                          Display include stacks for diagnostic notes
  -fdiagnostics-show-option
                          Print option name with mappable diagnostics
  -fdiagnostics-show-template-tree
                          Print a template comparison tree for differing templates
  -fdollars-in-identifiers
                          Allow '$' in identifiers
  -fdouble-square-bracket-attributes
                          Enable '[[]]' attributes in all C and C++ language modes
  -fdwarf-exceptions      Use DWARF style exceptions
  -fembed-bitcode-marker  Embed placeholder LLVM IR data as a marker
  -fembed-bitcode=<option>
                          Embed LLVM bitcode (option: off, all, bitcode, marker)
  -fembed-bitcode         Embed LLVM IR bitcode as data
  -femit-all-decls        Emit all declarations, even if unused
  -femulated-tls          Use emutls functions to access thread_local variables
  -fexceptions            Enable support for exception handling
  -fexperimental-isel     Enables the experimental global instruction selector
  -fexperimental-new-pass-manager
                          Enables an experimental new pass manager in LLVM.
  -ffast-math             Allow aggressive, lossy floating-point optimizations
  -ffine-grained-bitfield-accesses
                          Use separate accesses for bitfields with legal widths and alignments.
  -ffixed-r9              Reserve the r9 register (ARM only)
  -ffixed-x18             Reserve the x18 register (AArch64 only)
  -ffp-contract=<value>   Form fused FP ops (e.g. FMAs): fast (everywhere) | on (according to FP_CONTRACT pragma, default) | off (never fuse)
  -ffreestanding          Assert that the compilation takes place in a freestanding environment
  -ffunction-sections     Place each function in its own section (ELF Only)
  -fgnu-keywords          Allow GNU-extension keywords regardless of language standard
  -fgnu-runtime           Generate output compatible with the standard GNU Objective-C runtime
  -fgnu89-inline          Use the gnu89 inline semantics
  -fimplicit-module-maps  Implicitly search the file system for module map files.
  -finline-functions      Inline suitable functions
  -finline-hint-functions Inline functions which are (explicitly or implicitly) marked inline
  -finstrument-function-entry-bare
                          Instrument function entry only, after inlining, without arguments to the instrumentation call
  -finstrument-functions-after-inlining
                          Like -finstrument-functions, but insert the calls after inlining
  -finstrument-functions  Generate calls to instrument function entry and exit
  -fintegrated-as         Enable the integrated assembler
  -flto-jobs=<value>      Controls the backend parallelism of -flto=thin (default of 0 means the number of threads will be derived from the number of CPUs detected)
  -flto=<value>           Set LTO mode to either 'full' or 'thin'
  -flto                   Enable LTO in 'full' mode
  -fmath-errno            Require math functions to indicate errors by setting errno
  -fmax-type-align=<value>
                          Specify the maximum alignment to enforce on pointers lacking an explicit alignment
  -fmodule-file=[<name>=]<file>
                          Specify the mapping of module name to precompiled module file, or load a module file if name is omitted.
  -fmodule-map-file=<file>
                          Load this module map file
  -fmodule-name=<name>    Specify the name of the module to build
  -fmodules-cache-path=<directory>
                          Specify the module cache path
  -fmodules-decluse       Require declaration of modules used within a module
  -fmodules-disable-diagnostic-validation
                          Disable validation of the diagnostic options when loading the module
  -fmodules-ignore-macro=<value>
                          Ignore the definition of the given macro when building and loading modules
  -fmodules-prune-after=<seconds>
                          Specify the interval (in seconds) after which a module file will be considered unused
  -fmodules-prune-interval=<seconds>
                          Specify the interval (in seconds) between attempts to prune the module cache
  -fmodules-search-all    Search even non-imported modules to resolve references
  -fmodules-strict-decluse
                          Like -fmodules-decluse but requires all headers to be in modules
  -fmodules-ts            Enable support for the C++ Modules TS
  -fmodules-user-build-path <directory>
                          Specify the module user build path
  -fmodules-validate-once-per-build-session
                          Don't verify input files for the modules if the module has been successfully validated or loaded during this build session
  -fmodules-validate-system-headers
                          Validate the system headers that a module depends on when loading the module
  -fmodules               Enable the 'modules' language feature
  -fms-compatibility-version=<value>
                          Dot-separated value representing the Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fms-compatibility      Enable full Microsoft Visual C++ compatibility
  -fms-extensions         Accept some non-standard constructs supported by the Microsoft compiler
  -fmsc-version=<value>   Microsoft compiler version number to report in _MSC_VER (0 = don't define it (default))
  -fnew-alignment=<align> Specifies the largest alignment guaranteed by '::operator new(size_t)'
  -fno-access-control     Disable C++ access control
  -fno-assume-sane-operator-new
                          Don't assume that C++'s global operator new can't alias any pointer
  -fno-autolink           Disable generation of linker directives for automatic library linking
  -fno-builtin-<value>    Disable implicit builtin knowledge of a specific function
  -fno-builtin            Disable implicit builtin knowledge of functions
  -fno-common             Compile common globals like normal definitions
  -fno-constant-cfstrings Disable creation of CodeFoundation-type constant strings
  -fno-coverage-mapping   Disable code coverage analysis
  -fno-crash-diagnostics  Disable auto-generation of preprocessed source files and a script for reproduction during a clang crash
  -fno-debug-info-for-profiling
                          Do not emit extra debug info for sample profiler.
  -fno-debug-macro        Do not emit macro debug information
  -fno-declspec           Disallow __declspec as a keyword
  -fno-delayed-template-parsing
                          Disable delayed template parsing
  -fno-diagnostics-fixit-info
                          Do not include fixit information in diagnostics
  -fno-dollars-in-identifiers
                          Disallow '$' in identifiers
  -fno-double-square-bracket-attributes
                          Disable '[[]]' attributes in all C and C++ language modes
  -fno-elide-constructors Disable C++ copy constructor elision
  -fno-elide-type         Do not elide types when printing diagnostics
  -fno-experimental-isel  Disables the experimental global instruction selector
  -fno-experimental-new-pass-manager
                          Disables an experimental new pass manager in LLVM.
  -fno-fine-grained-bitfield-accesses
                          Use large-integer access for consecutive bitfield runs.
  -fno-gnu-inline-asm     Disable GNU style inline asm
  -fno-integrated-as      Disable the integrated assembler
  -fno-jump-tables        Do not use jump tables for lowering switches
  -fno-lax-vector-conversions
                          Disallow implicit conversions between vectors with a different number of elements or different element types
  -fno-lto                Disable LTO mode (default)
  -fno-merge-all-constants
                          Disallow merging of constants
  -fno-objc-infer-related-result-type
                          do not infer Objective-C related result type based on method family
  -fno-openmp-simd        Disable OpenMP code for SIMD-based constructs.
  -fno-operator-names     Do not treat C++ operator name keywords as synonyms for operators
  -fno-plt                Do not use the PLT to make function calls
  -fno-preserve-as-comments
                          Do not preserve comments in inline assembly
  -fno-profile-generate   Disable generation of profile instrumentation.
  -fno-profile-instr-generate
  -fno-profile-instr-use  Disable using instrumentation data for profile-guided optimization
  -fno-reroll-loops       Turn off loop reroller
  -fno-rtlib-add-rpath    Do not add -rpath with architecture-specific resource directory to the linker flags
  -fno-rtti               Disable generation of rtti information
  -fno-sanitize-address-use-after-scope
                          Disable use-after-scope detection in AddressSanitizer
  -fno-sanitize-blacklist Don't use blacklist file for sanitizers
  -fno-sanitize-cfi-cross-dso
                          Disable control flow integrity (CFI) checks for cross-DSO calls.
  -fno-sanitize-coverage=<value>
                          Disable specified features of coverage instrumentation for Sanitizers
  -fno-sanitize-memory-track-origins
                          Disable origins tracking in MemorySanitizer
  -fno-sanitize-memory-use-after-dtor
                          Disable use-after-destroy detection in MemorySanitizer
  -fno-sanitize-recover=<value>
                          Disable recovery for specified sanitizers
  -fno-sanitize-stats     Disable sanitizer statistics gathering.
  -fno-sanitize-thread-atomics
                          Disable atomic operations instrumentation in ThreadSanitizer
  -fno-sanitize-thread-func-entry-exit
                          Disable function entry/exit instrumentation in ThreadSanitizer
  -fno-sanitize-thread-memory-access
                          Disable memory access instrumentation in ThreadSanitizer
  -fno-sanitize-trap=<value>
                          Disable trapping for specified sanitizers
  -fno-short-wchar        Force wchar_t to be an unsigned int
  -fno-show-column        Do not include column number on diagnostics
  -fno-show-source-location
                          Do not include source location information with diagnostics
  -fno-signed-char        Char is unsigned
  -fno-signed-zeros       Allow optimizations that ignore the sign of floating point zeros
  -fno-spell-checking     Disable spell-checking
  -fno-stack-protector    Disable the use of stack protectors
  -fno-standalone-debug   Limit debug information produced to reduce size of debug binary
  -fno-threadsafe-statics Do not emit code to make initialization of local statics thread safe
  -fno-trigraphs          Do not process trigraph sequences
  -fno-unroll-loops       Turn off loop unroller
  -fno-use-cxa-atexit     Don't use __cxa_atexit for calling destructors
  -fno-use-init-array     Don't use .init_array instead of .ctors
  -fnoopenmp-relocatable-target
                          Do not compile OpenMP target code as relocatable.
  -fobjc-arc-exceptions   Use EH-safe code when synthesizing retains and releases in -fobjc-arc
  -fobjc-arc              Synthesize retain and release calls for Objective-C pointers
  -fobjc-exceptions       Enable Objective-C exceptions
  -fobjc-runtime=<value>  Specify the target Objective-C runtime kind and version
  -fobjc-weak             Enable ARC-style weak references in Objective-C
  -fopenmp-relocatable-target
                          OpenMP target code is compiled as relocatable using the -c flag. For OpenMP targets the code is relocatable by default.
  -fopenmp-simd           Emit OpenMP code only for SIMD-based constructs.
  -fopenmp-targets=<value>
                          Specify comma-separated list of triples OpenMP offloading targets to be supported
  -foptimization-record-file=<value>
                          Specify the file name of any generated YAML optimization record
  -fpack-struct=<value>   Specify the default maximum struct packing alignment
  -fpascal-strings        Recognize and construct Pascal-style string literals
  -fpcc-struct-return     Override the default ABI to return all structs on the stack
  -fplt                   Use the PLT to make function calls
  -fplugin=<dsopath>      Load the named plugin (dynamic shared object)
  -fprebuilt-module-path=<directory>
                          Specify the prebuilt module path
  -fprofile-generate=<directory>
                          Generate instrumented code to collect execution counts into <directory>/default.profraw (overridden by LLVM_PROFILE_FILE env var)
  -fprofile-generate      Generate instrumented code to collect execution counts into default.profraw (overridden by LLVM_PROFILE_FILE env var)
  -fprofile-instr-generate=<file>
                          Generate instrumented code to collect execution counts into <file> (overridden by LLVM_PROFILE_FILE env var)
                          Generate instrumented code to collect execution counts into default.profraw file (overridden by '=' form of option or LLVM_PROFILE_FILE env var)
  -fprofile-instr-use=<value>
                          Use instrumentation data for profile-guided optimization
  -fprofile-sample-accurate
                          Specifies that the sample profile is accurate
  -fprofile-sample-use=<value>
                          Enable sample-based profile guided optimizations
  -fprofile-use=<pathname>
                          Use instrumentation data for profile-guided optimization. If pathname is a directory, it reads from <pathname>/default.profdata. Otherwise, it reads from file <pathname>.
  -freciprocal-math       Allow division operations to be reassociated
  -freg-struct-return     Override the default ABI to return small structs in registers
  -frelaxed-template-template-args
                          Enable C++17 relaxed template template argument matching
  -freroll-loops          Turn on loop reroller
  -frtlib-add-rpath       Add -rpath with architecture-specific resource directory to the linker flags
  -fsanitize-address-field-padding=<value>
                          Level of field padding for AddressSanitizer
  -fsanitize-address-globals-dead-stripping
                          Enable linker dead stripping of globals in AddressSanitizer
  -fsanitize-address-use-after-scope
                          Enable use-after-scope detection in AddressSanitizer
  -fsanitize-blacklist=<value>
                          Path to blacklist file for sanitizers
  -fsanitize-cfi-cross-dso
                          Enable control flow integrity (CFI) checks for cross-DSO calls.
  -fsanitize-cfi-icall-generalize-pointers
                          Generalize pointers in CFI indirect call type signature checks
  -fsanitize-coverage=<value>
                          Specify the type of coverage instrumentation for Sanitizers
  -fsanitize-memory-track-origins=<value>
                          Enable origins tracking in MemorySanitizer
  -fsanitize-memory-use-after-dtor
                          Enable use-after-destroy detection in MemorySanitizer
  -fsanitize-recover=<value>
                          Enable recovery for specified sanitizers
  -fsanitize-stats        Enable sanitizer statistics gathering.
  -fsanitize-thread-atomics
                          Enable atomic operations instrumentation in ThreadSanitizer (default)
  -fsanitize-thread-func-entry-exit
                          Enable function entry/exit instrumentation in ThreadSanitizer (default)
  -fsanitize-thread-memory-access
                          Enable memory access instrumentation in ThreadSanitizer (default)
  -fsanitize-trap=<value> Enable trapping for specified sanitizers
  -fsanitize-undefined-strip-path-components=<number>
                          Strip (or keep only, if negative) a given number of path components when emitting check metadata.
  -fsanitize=<check>      Turn on runtime checks for various forms of undefined or suspicious behavior. See user manual for available checks
  -fsave-optimization-record
                          Generate a YAML optimization record file
  -fseh-exceptions        Use SEH style exceptions
  -fshort-enums           Allocate to an enum type only as many bytes as it needs for the declared range of possible values
  -fshort-wchar           Force wchar_t to be a short unsigned int
  -fshow-overloads=<value>
                          Which overload candidates to show when overload resolution fails: best|all; defaults to all
  -fsized-deallocation    Enable C++14 sized global deallocation functions
  -fsjlj-exceptions       Use SjLj style exceptions
  -fslp-vectorize         Enable the superword-level parallelism vectorization passes
  -fsplit-dwarf-inlining  Place debug types in their own section (ELF Only)
  -fstack-protector-all   Force the usage of stack protectors for all functions
  -fstack-protector-strong
                          Use a strong heuristic to apply stack protectors to functions
  -fstack-protector       Enable stack protectors for functions potentially vulnerable to stack smashing
  -fstandalone-debug      Emit full debug info for all types used by the program
  -fstrict-enums          Enable optimizations based on the strict definition of an enum's value range
  -fstrict-return         Always treat control flow paths that fall off the end of a non-void function as unreachable
  -fstrict-vtable-pointers
                          Enable optimizations based on the strict rules for overwriting polymorphic C++ objects
  -fthinlto-index=<value> Perform ThinLTO importing using provided function summary index
  -ftrap-function=<value> Issue call to specified function rather than a trap instruction
  -ftrapv-handler=<function name>
                          Specify the function to be called on overflow
  -ftrapv                 Trap on integer overflow
  -ftrigraphs             Process trigraph sequences
  -funique-section-names  Use unique names for text and data sections (ELF Only)
  -funroll-loops          Turn on loop unroller
  -fuse-init-array        Use .init_array instead of .ctors
  -fveclib=<value>        Use the given vector functions library
  -fvectorize             Enable the loop vectorization passes
  -fvisibility-inlines-hidden
                          Give inline C++ member functions default visibility by default
  -fvisibility-ms-compat  Give global types 'default' visibility and global functions and variables 'hidden' visibility by default
  -fvisibility=<value>    Set the default symbol visibility for all global declarations
  -fwhole-program-vtables Enables whole-program vtable optimization. Requires -flto
  -fwrapv                 Treat signed integer overflow as two's complement
  -fwritable-strings      Store string literals as writable data
  -fxray-always-emit-customevents
                          Determine whether to always emit __xray_customevent(...) calls even if the function it appears in is not always instrumented.
  -fxray-always-instrument= <value>
                          Filename defining the whitelist for imbuing the 'always instrument' XRay attribute.
  -fxray-instruction-threshold= <value>
                          Sets the minimum function size to instrument with XRay
  -fxray-instrument       Generate XRay instrumentation sleds on function entry and exit
  -fxray-never-instrument= <value>
                          Filename defining the whitelist for imbuing the 'never instrument' XRay attribute.
  -fzvector               Enable System z vector language extension
  -F <value>              Add directory to framework include search path
  --gcc-toolchain=<value> Use the gcc toolchain at the given directory
  -gcodeview              Generate CodeView debug information
  -gdwarf-2               Generate source-level debug information with dwarf version 2
  -gdwarf-3               Generate source-level debug information with dwarf version 3
  -gdwarf-4               Generate source-level debug information with dwarf version 4
  -gdwarf-5               Generate source-level debug information with dwarf version 5
  -gline-tables-only      Emit debug line number tables only
  -gmodules               Generate debug info with external references to clang modules or precompiled headers
  -gz=<value>             DWARF debug sections compression type
  -gz                     DWARF debug sections compression type
  -G <size>               Put objects of at most <size> bytes into small data section (MIPS / Hexagon)
  -g                      Generate source-level debug information
  -help                   Display available options
  -H                      Show header includes and nesting depth
  -I-                     Restrict all prior -I flags to double-quoted inclusion and remove current directory from include path
  -idirafter <value>      Add directory to AFTER include search path
  -iframeworkwithsysroot <directory>
                          Add directory to SYSTEM framework search path, absolute paths are relative to -isysroot
  -iframework <value>     Add directory to SYSTEM framework search path
  -imacros <file>         Include macros from file before parsing
  -include-pch <file>     Include precompiled header file
  -include <file>         Include file before parsing
  -index-header-map       Make the next included directory (-I or -F) an indexer header map
  -iprefix <dir>          Set the -iwithprefix/-iwithprefixbefore prefix
  -iquote <directory>     Add directory to QUOTE include search path
  -isysroot <dir>         Set the system root directory (usually /)
  -isystem-after <directory>
                          Add directory to end of the SYSTEM include search path
  -isystem <directory>    Add directory to SYSTEM include search path
  -ivfsoverlay <value>    Overlay the virtual filesystem described by file over the real file system
  -iwithprefixbefore <dir>
                          Set directory to include search path with prefix
  -iwithprefix <dir>      Set directory to SYSTEM include search path with prefix
  -iwithsysroot <directory>
                          Add directory to SYSTEM include search path, absolute paths are relative to -isysroot
  -I <dir>                Add directory to include search path
  -L <dir>                Add directory to library search path
  -mabicalls              Enable SVR4-style position-independent code (Mips only)
  -malign-double          Align doubles to two words in structs (x86 only)
  -mbackchain             Link stack frames through backchain on System Z
  -mcrc                   Allow use of CRC instructions (ARM only)
  -MD                     Write a depfile containing user and system headers
  -meabi <value>          Set EABI type, e.g. 4, 5 or gnu (default depends on triple)
  -membedded-data         Place constants in the .rodata section instead of the .sdata section even if they meet the -G <size> threshold (MIPS)
  -mexecute-only          Disallow generation of data access to code sections (ARM only)
  -mextern-sdata          Assume that externally defined data is in the small data if it meets the -G <size> threshold (MIPS)
  -mfentry                Insert calls to fentry at function entry (x86 only)
  -mfix-cortex-a53-835769 Workaround Cortex-A53 erratum 835769 (AArch64 only)
  -mfp32                  Use 32-bit floating point registers (MIPS only)
  -mfp64                  Use 64-bit floating point registers (MIPS only)
  -MF <file>              Write depfile output from -MMD, -MD, -MM, or -M to <file>
  -mgeneral-regs-only     Generate code which only uses the general purpose registers (AArch64 only)
  -mglobal-merge          Enable merging of globals
  -mgpopt                 Use GP relative accesses for symbols known to be in a small data section (MIPS)
  -MG                     Add missing headers to depfile
  -mhvx-double            Enable Hexagon Double Vector eXtensions
  -mhvx-length=<value>    Set Hexagon Vector Length
  -mhvx=<value>           Enable Hexagon Vector eXtensions
  -mhvx                   Enable Hexagon Vector eXtensions
  -miamcu                 Use Intel MCU ABI
  --migrate               Run the migrator
  -mincremental-linker-compatible
                          (integrated-as) Emit an object file which can be used with an incremental linker
  -mios-version-min=<value>
                          Set iOS deployment target
  -MJ <value>             Write a compilation database entry per input
  -mllvm <value>          Additional arguments to forward to LLVM's option processing
  -mlocal-sdata           Extend the -G behaviour to object local data (MIPS)
  -mlong-calls            Generate branches with extended addressability, usually via indirect jumps.
  -mmacosx-version-min=<value>
                          Set Mac OS X deployment target
  -mmadd4                 Enable the generation of 4-operand madd.s, madd.d and related instructions.
  -MMD                    Write a depfile containing user headers
  -mms-bitfields          Set the default structure layout to be compatible with the Microsoft compiler standard
  -mmsa                   Enable MSA ASE (MIPS only)
  -mmt                    Enable MT ASE (MIPS only)
  -MM                     Like -MMD, but also implies -E and writes to stdout by default
  -mno-abicalls           Disable SVR4-style position-independent code (Mips only)
  -mno-embedded-data      Do not place constants in the .rodata section instead of the .sdata if they meet the -G <size> threshold (MIPS)
  -mno-execute-only       Allow generation of data access to code sections (ARM only)
  -mno-extern-sdata       Do not assume that externally defined data is in the small data if it meets the -G <size> threshold (MIPS)
  -mno-fix-cortex-a53-835769
                          Don't workaround Cortex-A53 erratum 835769 (AArch64 only)
  -mno-global-merge       Disable merging of globals
  -mno-gpopt              Do not use GP relative accesses for symbols known to be in a small data section (MIPS)
  -mno-hvx-double         Disable Hexagon Double Vector eXtensions
  -mno-hvx                Disable Hexagon Vector eXtensions
  -mno-implicit-float     Don't generate implicit floating point instructions
  -mno-incremental-linker-compatible
                          (integrated-as) Emit an object file which cannot be used with an incremental linker
  -mno-local-sdata        Do not extend the -G behaviour to object local data (MIPS)
  -mno-long-calls         Restore the default behaviour of not generating long calls
  -mno-madd4              Disable the generation of 4-operand madd.s, madd.d and related instructions.
  -mno-movt               Disallow use of movt/movw pairs (ARM only)
  -mno-ms-bitfields       Do not set the default structure layout to be compatible with the Microsoft compiler standard
  -mno-msa                Disable MSA ASE (MIPS only)
  -mno-mt                 Disable MT ASE (MIPS only)
  -mno-neg-immediates     Disallow converting instructions with negative immediates to their negation or inversion.
  -mno-restrict-it        Allow generation of deprecated IT blocks for ARMv8. It is off by default for ARMv8 Thumb mode
  -mno-unaligned-access   Force all memory accesses to be aligned (AArch32/AArch64 only)
  -mno-xnack              Disable XNACK (AMDGPU only)
  -mnocrc                 Disallow use of CRC instructions (ARM only)
  -module-dependency-dir <value>
                          Directory to dump module dependencies to
  -module-file-info       Provide information about a particular module file
  -momit-leaf-frame-pointer
                          Omit frame pointer setup for leaf functions
  -mpie-copy-relocations  Use copy relocations support for PIE builds
  -mprefer-vector-width=<value>
                          Specifies preferred vector width for auto-vectorization. Defaults to 'none' which allows target specific decisions.
  -MP                     Create phony target for each dependency (other than main file)
  -mqdsp6-compat          Enable hexagon-qdsp6 backward compatibility
  -MQ <value>             Specify name of main file output to quote in depfile
  -mrelax-all             (integrated-as) Relax all machine instructions
  -mrestrict-it           Disallow generation of deprecated IT blocks for ARMv8. It is on by default for ARMv8 Thumb mode.
  -mrtd                   Make StdCall calling convention the default
  -msoft-float            Use software floating point
  -mstack-alignment=<value>
                          Set the stack alignment
  -mstack-probe-size=<value>
                          Set the stack probe size
  -mstackrealign          Force realign the stack at entry to every function
  -mthread-model <value>  The thread model to use, e.g. posix, single (posix by default)
  -mtp=<value>            Read thread pointer from coprocessor register (ARM only)
  -MT <value>             Specify name of main file output in depfile
  -munaligned-access      Allow memory accesses to be unaligned (AArch32/AArch64 only)
  -MV                     Use NMake/Jom format for the depfile
  -mxnack                 Enable XNACK (AMDGPU only)
  -M                      Like -MD, but also implies -E and writes to stdout by default
  --no-cuda-gpu-arch=<value>
                          Remove GPU architecture (e.g. sm_35) from the list of GPUs to compile for. 'all' resets the list to its default value.
  --no-cuda-version-check Don't error out if the detected version of the CUDA install is too low for the requested CUDA gpu architecture.
  --no-system-header-prefix=<prefix>
                          Treat all #include paths starting with <prefix> as not including a system header.
  -nobuiltininc           Disable builtin #include directories
  -nostdinc++             Disable standard #include directories for the C++ standard library
  -ObjC++                 Treat source input files as Objective-C++ inputs
  -objcmt-atomic-property Make migration to 'atomic' properties
  -objcmt-migrate-all     Enable migration to modern ObjC
  -objcmt-migrate-annotation
                          Enable migration to property and method annotations
  -objcmt-migrate-designated-init
                          Enable migration to infer NS_DESIGNATED_INITIALIZER for initializer methods
  -objcmt-migrate-instancetype
                          Enable migration to infer instancetype for method result type
  -objcmt-migrate-literals
                          Enable migration to modern ObjC literals
  -objcmt-migrate-ns-macros
                          Enable migration to NS_ENUM/NS_OPTIONS macros
  -objcmt-migrate-property-dot-syntax
                          Enable migration of setter/getter messages to property-dot syntax
                          Enable migration to modern ObjC property
  -objcmt-migrate-protocol-conformance
                          Enable migration to add protocol conformance on classes
  -objcmt-migrate-readonly-property
                          Enable migration to modern ObjC readonly property
  -objcmt-migrate-readwrite-property
                          Enable migration to modern ObjC readwrite property
  -objcmt-migrate-subscripting
                          Enable migration to modern ObjC subscripting
  -objcmt-ns-nonatomic-iosonly
                          Enable migration to use NS_NONATOMIC_IOSONLY macro for setting property's 'atomic' attribute
  -objcmt-returns-innerpointer-property
                          Enable migration to annotate property with NS_RETURNS_INNER_POINTER
  -objcmt-whitelist-dir-path=<value>
                          Only modify files with a filename contained in the provided directory path
  -ObjC                   Treat source input files as Objective-C inputs
  -o <file>               Write output to <file>
  -pg                     Enable mcount instrumentation
  -pipe                   Use pipes between commands, when possible
  --precompile            Only precompile the input
  -print-file-name=<file> Print the full library path of <file>
  -print-ivar-layout      Enable Objective-C Ivar layout bitmap print trace
  -print-libgcc-file-name Print the library path for the currently used compiler runtime library ("libgcc.a" or "libclang_rt.builtins.*.a")
  -print-prog-name=<name> Print the full program path of <name>
  -print-resource-dir     Print the resource directory pathname
  -print-search-dirs      Print the paths used for finding libraries and programs
  -pthread                Support POSIX threads in generated code
  --ptxas-path=<value>    Path to ptxas (used for compiling CUDA code)
  -P                      Disable linemarker output in -E mode
  -Qunused-arguments      Don't emit warning for unused driver arguments
  -relocatable-pch        Whether to build a relocatable precompiled header
  -rewrite-legacy-objc    Rewrite Legacy Objective-C source to C++
  -rewrite-objc           Rewrite Objective-C source to C++
  -Rpass-analysis=<value> Report transformation analysis from optimization passes whose name matches the given POSIX regular expression
  -Rpass-missed=<value>   Report missed transformations by optimization passes whose name matches the given POSIX regular expression
  -Rpass=<value>          Report transformations performed by optimization passes whose name matches the given POSIX regular expression
  -rtlib=<value>          Compiler runtime library to use
  -R<remark>              Enable the specified remark
  -save-stats=<value>     Save llvm statistics.
  -save-stats             Save llvm statistics.
  -save-temps=<value>     Save intermediate compilation results.
  -save-temps             Save intermediate compilation results
  -serialize-diagnostics <value>
                          Serialize compiler diagnostics to a file
  -std=<value>            Language standard to compile for
  -stdlib=<value>         C++ standard library to use
  --system-header-prefix=<prefix>
                          Treat all #include paths starting with <prefix> as including a system header.
  -S                      Only run preprocess and compilation steps
  --target=<value>        Generate code for the given target
  -Tbss <addr>            Set starting address of BSS to <addr>
  -Tdata <addr>           Set starting address of BSS to <addr>
  -time                   Time individual commands
  -traditional-cpp        Enable some traditional CPP emulation
  -trigraphs              Process trigraph sequences
  -Ttext <addr>           Set starting address of BSS to <addr>
  -T <script>             Specify <script> as linker script
  -undef                  undef all system defines
  -U <macro>              Undefine macro <macro>
  --verify-debug-info     Verify the binary representation of debug output
  -verify-pch             Load and verify that a pre-compiled header file is not stale
  --version               Print version information
  -v                      Show commands to run and use verbose output
  -Wa,<arg>               Pass the comma separated arguments in <arg> to the assembler
  -Wdeprecated            Enable warnings for deprecated constructs and define __DEPRECATED
  -Wl,<arg>               Pass the comma separated arguments in <arg> to the linker
  -working-directory <value>
                          Resolve file paths relative to the specified directory
  -Wp,<arg>               Pass the comma separated arguments in <arg> to the preprocessor
  -W<warning>             Enable the specified warning
  -w                      Suppress all warnings
  -Xanalyzer <arg>        Pass <arg> to the static analyzer
  -Xassembler <arg>       Pass <arg> to the assembler
  -Xclang <arg>           Pass <arg> to the clang compiler
  -Xcuda-fatbinary <arg>  Pass <arg> to fatbinary invocation
  -Xcuda-ptxas <arg>      Pass <arg> to the ptxas assembler
  -Xlinker <arg>          Pass <arg> to the linker
  -Xopenmp-target=<arg>   Pass <arg> to the specified target offloading toolchain. The triple that identifies the toolchain must be provided after the equals sign.
  -Xopenmp-target <arg>   Pass <arg> to the target offloading toolchain.
  -Xpreprocessor <arg>    Pass <arg> to the preprocessor
  -x <language>           Treat subsequent input files as having type <language>
  -z <arg>                Pass -z <arg> to the linker
Checking for program /usr/local/bin/mpicxx...found
                Defined make macro "CXX" to "mpicxx"
                Pushing language Cxx
Executing: mpicxx -c -o /tmp/petsc-mjVUVK/config.setCompilers/conftest.o -I/tmp/petsc-mjVUVK/config.setCompilers     /tmp/petsc-mjVUVK/config.setCompilers/conftest.cc
Successful compile:
Source:
#include "confdefs.h"
#include "conffix.h"
int main() {
  return 0;
Successful compile:
Source:
int main() {
  return 0;
                                                Pushing language C
                                                Popping language C
                                                Pushing language CUDA
                                                Popping language CUDA
                                                Popping language Cxx
                                                Pushing language FC
                                                Popping language FC
                        Pushing language CXX
                        Popping language CXX
Executing: mpicxx  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o
Successful compile:
Source:
int main() {
  return 0;
Executing: mpicxx  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
Possible ERROR while running linker: exit code 256
stderr:
ld: library not found for -lpetsc-ufod4vtr9mqHvKIQiVAm
clang-6.0: error: linker command failed with exit code 1 (use -v to see invocation)
Successful compile:
Source:
int main() {
  return 0;
Testing executable /tmp/petsc-mjVUVK/config.setCompilers/conftest to see if it can be run
Executing: /tmp/petsc-mjVUVK/config.setCompilers/conftest
TEST checkCxxPreprocessor from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:830)
TESTING: checkCxxPreprocessor from config.setCompilers(config/BuildSystem/config/setCompilers.py:830)
  Locate a functional Cxx preprocessor
                Defined make macro "CXXCPP" to "mpicxx -E"
Executing: mpicxx -E  -I/tmp/petsc-mjVUVK/config.setCompilers   /tmp/petsc-mjVUVK/config.setCompilers/conftest.cc
stdout:
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.cc"
# 1 "<built-in>" 1
# 1 "<built-in>" 3
# 399 "<built-in>" 3
# 1 "<command line>" 1
# 1 "<built-in>" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.cc" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/confdefs.h" 1
# 2 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.cc" 2
# 1 "/tmp/petsc-mjVUVK/config.setCompilers/conffix.h" 1
extern "C" {
# 3 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.cc" 2
# 1 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 1 3
# 85 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 3
# 1 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/__config" 1 3
# 22 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/__config" 3
# 449 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/__config" 3
namespace std {
  inline namespace __1 {
# 86 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 2 3
# 1 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdlib.h" 1 3
# 92 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdlib.h" 3
# 1 "/usr/include/stdlib.h" 1 3 4
# 61 "/usr/include/stdlib.h" 3 4
# 1 "/usr/include/Availability.h" 1 3 4
# 190 "/usr/include/Availability.h" 3 4
# 1 "/usr/include/AvailabilityInternal.h" 1 3 4
# 191 "/usr/include/Availability.h" 2 3 4
# 62 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/_types.h" 1 3 4
# 27 "/usr/include/_types.h" 3 4
# 1 "/usr/include/sys/_types.h" 1 3 4
# 32 "/usr/include/sys/_types.h" 3 4
# 1 "/usr/include/sys/cdefs.h" 1 3 4
# 587 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_symbol_aliasing.h" 1 3 4
# 588 "/usr/include/sys/cdefs.h" 2 3 4
# 653 "/usr/include/sys/cdefs.h" 3 4
# 1 "/usr/include/sys/_posix_availability.h" 1 3 4
# 654 "/usr/include/sys/cdefs.h" 2 3 4
# 33 "/usr/include/sys/_types.h" 2 3 4
# 1 "/usr/include/machine/_types.h" 1 3 4
# 32 "/usr/include/machine/_types.h" 3 4
# 1 "/usr/include/i386/_types.h" 1 3 4
# 37 "/usr/include/i386/_types.h" 3 4
typedef signed char __int8_t;
typedef unsigned char __uint8_t;
typedef short __int16_t;
typedef unsigned short __uint16_t;
typedef int __int32_t;
typedef unsigned int __uint32_t;
typedef long long __int64_t;
typedef unsigned long long __uint64_t;
typedef long __darwin_intptr_t;
typedef unsigned int __darwin_natural_t;
# 70 "/usr/include/i386/_types.h" 3 4
typedef int __darwin_ct_rune_t;
typedef union {
 char __mbstate8[128];
 long long _mbstateL;
} __mbstate_t;
typedef __mbstate_t __darwin_mbstate_t;
typedef long int __darwin_ptrdiff_t;
typedef long unsigned int __darwin_size_t;
typedef __builtin_va_list __darwin_va_list;
typedef int __darwin_wchar_t;
typedef __darwin_wchar_t __darwin_rune_t;
typedef int __darwin_wint_t;
typedef unsigned long __darwin_clock_t;
typedef __uint32_t __darwin_socklen_t;
typedef long __darwin_ssize_t;
typedef long __darwin_time_t;
# 33 "/usr/include/machine/_types.h" 2 3 4
# 34 "/usr/include/sys/_types.h" 2 3 4
# 55 "/usr/include/sys/_types.h" 3 4
typedef __int64_t __darwin_blkcnt_t;
typedef __int32_t __darwin_blksize_t;
typedef __int32_t __darwin_dev_t;
typedef unsigned int __darwin_fsblkcnt_t;
typedef unsigned int __darwin_fsfilcnt_t;
typedef __uint32_t __darwin_gid_t;
typedef __uint32_t __darwin_id_t;
typedef __uint64_t __darwin_ino64_t;
typedef __darwin_ino64_t __darwin_ino_t;
typedef __darwin_natural_t __darwin_mach_port_name_t;
typedef __darwin_mach_port_name_t __darwin_mach_port_t;
typedef __uint16_t __darwin_mode_t;
typedef __int64_t __darwin_off_t;
typedef __int32_t __darwin_pid_t;
typedef __uint32_t __darwin_sigset_t;
typedef __int32_t __darwin_suseconds_t;
typedef __uint32_t __darwin_uid_t;
typedef __uint32_t __darwin_useconds_t;
typedef unsigned char __darwin_uuid_t[16];
typedef char __darwin_uuid_string_t[37];
# 1 "/usr/include/sys/_pthread/_pthread_types.h" 1 3 4
# 57 "/usr/include/sys/_pthread/_pthread_types.h" 3 4
struct __darwin_pthread_handler_rec {
 void (*__routine)(void *);
 void *__arg;
 struct __darwin_pthread_handler_rec *__next;
struct _opaque_pthread_attr_t {
 long __sig;
 char __opaque[56];
struct _opaque_pthread_cond_t {
 long __sig;
 char __opaque[40];
struct _opaque_pthread_condattr_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_mutex_t {
 long __sig;
 char __opaque[56];
struct _opaque_pthread_mutexattr_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_once_t {
 long __sig;
 char __opaque[8];
struct _opaque_pthread_rwlock_t {
 long __sig;
 char __opaque[192];
struct _opaque_pthread_rwlockattr_t {
 long __sig;
 char __opaque[16];
struct _opaque_pthread_t {
 long __sig;
 struct __darwin_pthread_handler_rec *__cleanup_stack;
 char __opaque[8176];
typedef struct _opaque_pthread_attr_t __darwin_pthread_attr_t;
typedef struct _opaque_pthread_cond_t __darwin_pthread_cond_t;
typedef struct _opaque_pthread_condattr_t __darwin_pthread_condattr_t;
typedef unsigned long __darwin_pthread_key_t;
typedef struct _opaque_pthread_mutex_t __darwin_pthread_mutex_t;
typedef struct _opaque_pthread_mutexattr_t __darwin_pthread_mutexattr_t;
typedef struct _opaque_pthread_once_t __darwin_pthread_once_t;
typedef struct _opaque_pthread_rwlock_t __darwin_pthread_rwlock_t;
typedef struct _opaque_pthread_rwlockattr_t __darwin_pthread_rwlockattr_t;
typedef struct _opaque_pthread_t *__darwin_pthread_t;
# 81 "/usr/include/sys/_types.h" 2 3 4
# 28 "/usr/include/_types.h" 2 3 4
# 39 "/usr/include/_types.h" 3 4
typedef int __darwin_nl_item;
typedef int __darwin_wctrans_t;
typedef __uint32_t __darwin_wctype_t;
# 64 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/wait.h" 1 3 4
# 79 "/usr/include/sys/wait.h" 3 4
typedef enum {
 P_ALL,
 P_PID,
 P_PGID
} idtype_t;
# 1 "/usr/include/sys/_types/_pid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_pid_t.h" 3 4
typedef __darwin_pid_t pid_t;
# 90 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/_types/_id_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_id_t.h" 3 4
typedef __darwin_id_t id_t;
# 91 "/usr/include/sys/wait.h" 2 3 4
# 109 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/sys/signal.h" 1 3 4
# 73 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/sys/appleapiopts.h" 1 3 4
# 74 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/machine/signal.h" 1 3 4
# 32 "/usr/include/machine/signal.h" 3 4
# 1 "/usr/include/i386/signal.h" 1 3 4
# 39 "/usr/include/i386/signal.h" 3 4
typedef int sig_atomic_t;
# 33 "/usr/include/machine/signal.h" 2 3 4
# 83 "/usr/include/sys/signal.h" 2 3 4
# 146 "/usr/include/sys/signal.h" 3 4
# 1 "/usr/include/machine/_mcontext.h" 1 3 4
# 29 "/usr/include/machine/_mcontext.h" 3 4
# 1 "/usr/include/i386/_mcontext.h" 1 3 4
# 33 "/usr/include/i386/_mcontext.h" 3 4
# 1 "/usr/include/mach/i386/_structs.h" 1 3 4
# 43 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_thread_state
    unsigned int __eax;
    unsigned int __ebx;
    unsigned int __ecx;
    unsigned int __edx;
    unsigned int __edi;
    unsigned int __esi;
    unsigned int __ebp;
    unsigned int __esp;
    unsigned int __ss;
    unsigned int __eflags;
    unsigned int __eip;
    unsigned int __cs;
    unsigned int __ds;
    unsigned int __es;
    unsigned int __fs;
    unsigned int __gs;
# 89 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_control
    unsigned short __invalid :1,
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
      :2,
    __pc :2,
    __rc :2,
             :1,
      :3;
typedef struct __darwin_fp_control __darwin_fp_control_t;
# 147 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_fp_status
        __denorm :1,
    __zdiv :1,
    __ovrfl :1,
    __undfl :1,
    __precis :1,
    __stkflt :1,
    __errsumm :1,
    __c0 :1,
    __c1 :1,
    __c2 :1,
    __tos :3,
    __c3 :1,
    __busy :1;
typedef struct __darwin_fp_status __darwin_fp_status_t;
# 191 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_mmst_reg
 char __mmst_reg[10];
 char __mmst_rsrv[6];
# 210 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_xmm_reg
 char __xmm_reg[16];
# 232 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_float_state
 int __fpu_reserved[2];
 struct __darwin_fp_control __fpu_fcw;
 struct __darwin_fp_status __fpu_fsw;
 __uint8_t __fpu_ftw;
 __uint8_t __fpu_rsrv1;
 __uint16_t __fpu_fop;
 __uint32_t __fpu_ip;
 __uint16_t __fpu_cs;
 __uint16_t __fpu_rsrv2;
 __uint32_t __fpu_dp;
 __uint16_t __fpu_ds;
 __uint16_t __fpu_rsrv3;
 __uint32_t __fpu_mxcsr;
 __uint32_t __fpu_mxcsrmask;
 struct __darwin_mmst_reg __fpu_stmm0;
 struct __darwin_mmst_reg __fpu_stmm1;
 struct __darwin_mmst_reg __fpu_stmm2;
 struct __darwin_mmst_reg __fpu_stmm3;
 struct __darwin_mmst_reg __fpu_stmm4;
 struct __darwin_mmst_reg __fpu_stmm5;
 struct __darwin_mmst_reg __fpu_stmm6;
 struct __darwin_mmst_reg __fpu_stmm7;
 struct __darwin_xmm_reg __fpu_xmm0;
 struct __darwin_xmm_reg __fpu_xmm1;
 struct __darwin_xmm_reg __fpu_xmm2;
 struct __darwin_xmm_reg __fpu_xmm3;
 struct __darwin_xmm_reg __fpu_xmm4;
 struct __darwin_xmm_reg __fpu_xmm5;
 struct __darwin_xmm_reg __fpu_xmm6;
 struct __darwin_xmm_reg __fpu_xmm7;
 char __fpu_rsrv4[14*16];
 int __fpu_reserved1;
struct __darwin_i386_avx_state
 char __avx_reserved1[64];
 struct __darwin_xmm_reg __fpu_ymmh0;
 struct __darwin_xmm_reg __fpu_ymmh1;
 struct __darwin_xmm_reg __fpu_ymmh2;
 struct __darwin_xmm_reg __fpu_ymmh3;
 struct __darwin_xmm_reg __fpu_ymmh4;
 struct __darwin_xmm_reg __fpu_ymmh5;
 struct __darwin_xmm_reg __fpu_ymmh6;
 struct __darwin_xmm_reg __fpu_ymmh7;
# 402 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_i386_exception_state
 __uint16_t __trapno;
 __uint16_t __cpu;
 __uint32_t __err;
 __uint32_t __faultvaddr;
# 422 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state32
 unsigned int __dr0;
 unsigned int __dr1;
 unsigned int __dr2;
 unsigned int __dr3;
 unsigned int __dr4;
 unsigned int __dr5;
 unsigned int __dr6;
 unsigned int __dr7;
# 454 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_thread_state64
 __uint64_t __rax;
 __uint64_t __rbx;
 __uint64_t __rcx;
 __uint64_t __rdx;
 __uint64_t __rdi;
 __uint64_t __rsi;
 __uint64_t __rbp;
 __uint64_t __rsp;
 __uint64_t __r8;
 __uint64_t __r9;
 __uint64_t __r10;
 __uint64_t __r11;
 __uint64_t __r12;
 __uint64_t __r13;
 __uint64_t __r14;
 __uint64_t __r15;
 __uint64_t __rip;
 __uint64_t __rflags;
 __uint64_t __cs;
 __uint64_t __fs;
 __uint64_t __gs;
# 509 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_float_state64
 struct __darwin_xmm_reg __fpu_xmm8;
 struct __darwin_xmm_reg __fpu_xmm9;
 struct __darwin_xmm_reg __fpu_xmm10;
 struct __darwin_xmm_reg __fpu_xmm11;
 struct __darwin_xmm_reg __fpu_xmm12;
 struct __darwin_xmm_reg __fpu_xmm13;
 struct __darwin_xmm_reg __fpu_xmm14;
 struct __darwin_xmm_reg __fpu_xmm15;
 char __fpu_rsrv4[6*16];
struct __darwin_x86_avx_state64
 struct __darwin_xmm_reg __fpu_ymmh8;
 struct __darwin_xmm_reg __fpu_ymmh9;
 struct __darwin_xmm_reg __fpu_ymmh10;
 struct __darwin_xmm_reg __fpu_ymmh11;
 struct __darwin_xmm_reg __fpu_ymmh12;
 struct __darwin_xmm_reg __fpu_ymmh13;
 struct __darwin_xmm_reg __fpu_ymmh14;
 struct __darwin_xmm_reg __fpu_ymmh15;
# 751 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_exception_state64
    __uint16_t __cpu;
    __uint32_t __err;
    __uint64_t __faultvaddr;
# 771 "/usr/include/mach/i386/_structs.h" 3 4
struct __darwin_x86_debug_state64
 __uint64_t __dr0;
 __uint64_t __dr1;
 __uint64_t __dr2;
 __uint64_t __dr3;
 __uint64_t __dr4;
 __uint64_t __dr5;
 __uint64_t __dr6;
 __uint64_t __dr7;
# 34 "/usr/include/i386/_mcontext.h" 2 3 4
struct __darwin_mcontext32
 struct __darwin_i386_exception_state __es;
 struct __darwin_i386_thread_state __ss;
 struct __darwin_i386_float_state __fs;
struct __darwin_mcontext_avx32
 struct __darwin_i386_avx_state __fs;
# 76 "/usr/include/i386/_mcontext.h" 3 4
struct __darwin_mcontext64
 struct __darwin_x86_exception_state64 __es;
 struct __darwin_x86_thread_state64 __ss;
 struct __darwin_x86_float_state64 __fs;
struct __darwin_mcontext_avx64
 struct __darwin_x86_avx_state64 __fs;
# 115 "/usr/include/i386/_mcontext.h" 3 4
typedef struct __darwin_mcontext64 *mcontext_t;
# 30 "/usr/include/machine/_mcontext.h" 2 3 4
# 147 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_pthread/_pthread_attr_t.h" 1 3 4
# 30 "/usr/include/sys/_pthread/_pthread_attr_t.h" 3 4
typedef __darwin_pthread_attr_t pthread_attr_t;
# 149 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigaltstack.h" 1 3 4
# 36 "/usr/include/sys/_types/_sigaltstack.h" 3 4
struct __darwin_sigaltstack
 void *ss_sp;
 __darwin_size_t ss_size;
 int ss_flags;
typedef struct __darwin_sigaltstack stack_t;
# 151 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_ucontext.h" 1 3 4
# 34 "/usr/include/sys/_types/_ucontext.h" 3 4
struct __darwin_ucontext
 int uc_onstack;
 __darwin_sigset_t uc_sigmask;
 struct __darwin_sigaltstack uc_stack;
 struct __darwin_ucontext *uc_link;
 __darwin_size_t uc_mcsize;
 struct __darwin_mcontext64 *uc_mcontext;
typedef struct __darwin_ucontext ucontext_t;
# 152 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_sigset_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_sigset_t.h" 3 4
typedef __darwin_sigset_t sigset_t;
# 155 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_size_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_size_t.h" 3 4
typedef __darwin_size_t size_t;
# 156 "/usr/include/sys/signal.h" 2 3 4
# 1 "/usr/include/sys/_types/_uid_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uid_t.h" 3 4
typedef __darwin_uid_t uid_t;
# 157 "/usr/include/sys/signal.h" 2 3 4
union sigval {
 int sival_int;
 void *sival_ptr;
struct sigevent {
 int sigev_notify;
 int sigev_signo;
 union sigval sigev_value;
 void (*sigev_notify_function)(union sigval);
 pthread_attr_t *sigev_notify_attributes;
typedef struct __siginfo {
 int si_signo;
 int si_errno;
 int si_code;
 pid_t si_pid;
 uid_t si_uid;
 int si_status;
 void *si_addr;
 union sigval si_value;
 long si_band;
 unsigned long __pad[7];
} siginfo_t;
# 269 "/usr/include/sys/signal.h" 3 4
union __sigaction_u {
 void (*__sa_handler)(int);
 void (*__sa_sigaction)(int, struct __siginfo *,
         void *);
struct __sigaction {
 union __sigaction_u __sigaction_u;
 void (*sa_tramp)(void *, int, int, siginfo_t *, void *);
 sigset_t sa_mask;
 int sa_flags;
struct sigaction {
 sigset_t sa_mask;
 int sa_flags;
# 331 "/usr/include/sys/signal.h" 3 4
typedef void (*sig_t)(int);
# 348 "/usr/include/sys/signal.h" 3 4
struct sigvec {
 void (*sv_handler)(int);
 int sv_mask;
 int sv_flags;
# 367 "/usr/include/sys/signal.h" 3 4
struct sigstack {
 char *ss_sp;
 int ss_onstack;
# 389 "/usr/include/sys/signal.h" 3 4
extern "C" {
void (*signal(int, void (*)(int)))(int);
# 110 "/usr/include/sys/wait.h" 2 3 4
# 1 "/usr/include/sys/resource.h" 1 3 4
# 72 "/usr/include/sys/resource.h" 3 4
# 1 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdint.h" 1 3 4
# 106 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdint.h" 3
# 119 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdint.h" 3
# 1 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 1 3 4
# 63 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 3 4
# 1 "/usr/include/stdint.h" 1 3 4
# 18 "/usr/include/stdint.h" 3 4
# 1 "/usr/include/sys/_types/_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int8_t.h" 3 4
typedef signed char int8_t;
# 19 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int16_t.h" 3 4
typedef short int16_t;
# 20 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int32_t.h" 3 4
typedef int int32_t;
# 21 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_int64_t.h" 3 4
typedef long long int64_t;
# 22 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint8_t.h" 1 3 4
# 31 "/usr/include/_types/_uint8_t.h" 3 4
typedef unsigned char uint8_t;
# 24 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint16_t.h" 1 3 4
# 31 "/usr/include/_types/_uint16_t.h" 3 4
typedef unsigned short uint16_t;
# 25 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint32_t.h" 1 3 4
# 31 "/usr/include/_types/_uint32_t.h" 3 4
typedef unsigned int uint32_t;
# 26 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uint64_t.h" 1 3 4
# 31 "/usr/include/_types/_uint64_t.h" 3 4
typedef unsigned long long uint64_t;
# 27 "/usr/include/stdint.h" 2 3 4
typedef int8_t int_least8_t;
typedef int16_t int_least16_t;
typedef int32_t int_least32_t;
typedef int64_t int_least64_t;
typedef uint8_t uint_least8_t;
typedef uint16_t uint_least16_t;
typedef uint32_t uint_least32_t;
typedef uint64_t uint_least64_t;
typedef int8_t int_fast8_t;
typedef int16_t int_fast16_t;
typedef int32_t int_fast32_t;
typedef int64_t int_fast64_t;
typedef uint8_t uint_fast8_t;
typedef uint16_t uint_fast16_t;
typedef uint32_t uint_fast32_t;
typedef uint64_t uint_fast64_t;
# 1 "/usr/include/sys/_types/_intptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_intptr_t.h" 3 4
typedef __darwin_intptr_t intptr_t;
# 54 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/sys/_types/_uintptr_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_uintptr_t.h" 3 4
typedef unsigned long uintptr_t;
# 55 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_intmax_t.h" 1 3 4
# 32 "/usr/include/_types/_intmax_t.h" 3 4
typedef long int intmax_t;
# 59 "/usr/include/stdint.h" 2 3 4
# 1 "/usr/include/_types/_uintmax_t.h" 1 3 4
# 32 "/usr/include/_types/_uintmax_t.h" 3 4
typedef long unsigned int uintmax_t;
# 60 "/usr/include/stdint.h" 2 3 4
# 64 "/usr/local/Cellar/llvm/6.0.0/lib/clang/6.0.0/include/stdint.h" 2 3 4
# 120 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdint.h" 2 3
# 73 "/usr/include/sys/resource.h" 2 3 4
# 1 "/usr/include/sys/_types/_timeval.h" 1 3 4
# 30 "/usr/include/sys/_types/_timeval.h" 3 4
struct timeval
 __darwin_time_t tv_sec;
 __darwin_suseconds_t tv_usec;
# 81 "/usr/include/sys/resource.h" 2 3 4
typedef __uint64_t rlim_t;
# 152 "/usr/include/sys/resource.h" 3 4
struct rusage {
 struct timeval ru_utime;
 struct timeval ru_stime;
# 163 "/usr/include/sys/resource.h" 3 4
 long ru_maxrss;
 long ru_ixrss;
 long ru_idrss;
 long ru_isrss;
 long ru_minflt;
 long ru_majflt;
 long ru_nswap;
 long ru_inblock;
 long ru_oublock;
 long ru_msgsnd;
 long ru_msgrcv;
 long ru_nsignals;
 long ru_nvcsw;
 long ru_nivcsw;
# 192 "/usr/include/sys/resource.h" 3 4
typedef void *rusage_info_t;
struct rusage_info_v0 {
 uint8_t ri_uuid[16];
 uint64_t ri_user_time;
 uint64_t ri_system_time;
 uint64_t ri_pkg_idle_wkups;
 uint64_t ri_interrupt_wkups;
 uint64_t ri_pageins;
 uint64_t ri_wired_size;
 uint64_t ri_resident_size;
 uint64_t ri_phys_footprint;
 uint64_t ri_proc_start_abstime;
 uint64_t ri_proc_exit_abstime;
struct rusage_info_v1 {
 uint64_t ri_child_user_time;
 uint64_t ri_child_system_time;
 uint64_t ri_child_pkg_idle_wkups;
 uint64_t ri_child_interrupt_wkups;
 uint64_t ri_child_pageins;
 uint64_t ri_child_elapsed_abstime;
struct rusage_info_v2 {
 uint64_t ri_diskio_bytesread;
 uint64_t ri_diskio_byteswritten;
struct rusage_info_v3 {
 uint64_t ri_cpu_time_qos_default;
 uint64_t ri_cpu_time_qos_maintenance;
 uint64_t ri_cpu_time_qos_background;
 uint64_t ri_cpu_time_qos_utility;
 uint64_t ri_cpu_time_qos_legacy;
 uint64_t ri_cpu_time_qos_user_initiated;
 uint64_t ri_cpu_time_qos_user_interactive;
 uint64_t ri_billed_system_time;
 uint64_t ri_serviced_system_time;
typedef struct rusage_info_v3 rusage_info_current;
# 325 "/usr/include/sys/resource.h" 3 4
struct rlimit {
 rlim_t rlim_cur;
 rlim_t rlim_max;
# 353 "/usr/include/sys/resource.h" 3 4
struct proc_rlimit_control_wakeupmon {
 uint32_t wm_flags;
 int32_t wm_rate;
# 384 "/usr/include/sys/resource.h" 3 4
extern "C" {
int getpriority(int, id_t);
int getiopolicy_np(int, int) __attribute__((availability(macosx,introduced=10.5)));
int getrlimit(int, struct rlimit *) __asm("_" "getrlimit" );
int getrusage(int, struct rusage *);
int setpriority(int, id_t, int);
int setiopolicy_np(int, int, int) __attribute__((availability(macosx,introduced=10.5)));
int setrlimit(int, const struct rlimit *) __asm("_" "setrlimit" );
# 111 "/usr/include/sys/wait.h" 2 3 4
# 186 "/usr/include/sys/wait.h" 3 4
# 1 "/usr/include/machine/endian.h" 1 3 4
# 35 "/usr/include/machine/endian.h" 3 4
# 1 "/usr/include/i386/endian.h" 1 3 4
# 99 "/usr/include/i386/endian.h" 3 4
# 1 "/usr/include/sys/_endian.h" 1 3 4
# 130 "/usr/include/sys/_endian.h" 3 4
# 1 "/usr/include/libkern/_OSByteOrder.h" 1 3 4
# 66 "/usr/include/libkern/_OSByteOrder.h" 3 4
# 1 "/usr/include/libkern/i386/_OSByteOrder.h" 1 3 4
# 44 "/usr/include/libkern/i386/_OSByteOrder.h" 3 4
static inline
__uint16_t
_OSSwapInt16(
    __uint16_t _data
    return ((__uint16_t)((_data << 8) | (_data >> 8)));
static inline
__uint32_t
_OSSwapInt32(
    __uint32_t _data
    return __builtin_bswap32(_data);
static inline
__uint64_t
_OSSwapInt64(
    __uint64_t _data
    return __builtin_bswap64(_data);
# 67 "/usr/include/libkern/_OSByteOrder.h" 2 3 4
# 131 "/usr/include/sys/_endian.h" 2 3 4
# 100 "/usr/include/i386/endian.h" 2 3 4
# 36 "/usr/include/machine/endian.h" 2 3 4
# 187 "/usr/include/sys/wait.h" 2 3 4
union wait {
 int w_status;
 struct {
  unsigned int w_Termsig:7,
    w_Coredump:1,
    w_Retcode:8,
    w_Filler:16;
 } w_T;
 struct {
  unsigned int w_Stopval:8,
    w_Stopsig:8,
    w_Filler:16;
 } w_S;
# 247 "/usr/include/sys/wait.h" 3 4
extern "C" {
pid_t wait(int *) __asm("_" "wait" );
pid_t waitpid(pid_t, int *, int) __asm("_" "waitpid" );
int waitid(idtype_t, id_t, siginfo_t *, int) __asm("_" "waitid" );
pid_t wait3(int *, int, struct rusage *);
pid_t wait4(pid_t, int *, int, struct rusage *);
# 66 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/alloca.h" 1 3 4
# 31 "/usr/include/alloca.h" 3 4
extern "C" {
void *alloca(size_t);
# 68 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_ct_rune_t.h" 1 3 4
# 31 "/usr/include/sys/_types/_ct_rune_t.h" 3 4
typedef __darwin_ct_rune_t ct_rune_t;
# 77 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_rune_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_rune_t.h" 3 4
typedef __darwin_rune_t rune_t;
# 78 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_wchar_t.h" 1 3 4
# 81 "/usr/include/stdlib.h" 2 3 4
typedef struct {
 int quot;
 int rem;
} div_t;
typedef struct {
 long quot;
 long rem;
} ldiv_t;
typedef struct {
 long long quot;
 long long rem;
} lldiv_t;
# 1 "/usr/include/sys/_types/_null.h" 1 3 4
# 100 "/usr/include/stdlib.h" 2 3 4
# 117 "/usr/include/stdlib.h" 3 4
extern int __mb_cur_max;
# 127 "/usr/include/stdlib.h" 3 4
extern "C" {
void abort(void) __attribute__((noreturn));
int abs(int) __attribute__((const));
int atexit(void (* _Nonnull)(void));
double atof(const char *);
int atoi(const char *);
long atol(const char *);
long long
  atoll(const char *);
void *bsearch(const void *__key, const void *__base, size_t __nel,
     size_t __width, int (* _Nonnull __compar)(const void *, const void *));
void *calloc(size_t __count, size_t __size) __attribute__((__warn_unused_result__));
div_t div(int, int) __attribute__((const));
void exit(int) __attribute__((noreturn));
void free(void *);
char *getenv(const char *);
long labs(long) __attribute__((const));
ldiv_t ldiv(long, long) __attribute__((const));
long long
  llabs(long long);
lldiv_t lldiv(long long, long long);
void *malloc(size_t __size) __attribute__((__warn_unused_result__));
int mblen(const char *__s, size_t __n);
size_t mbstowcs(wchar_t * , const char * , size_t);
int mbtowc(wchar_t * , const char * , size_t);
int posix_memalign(void **__memptr, size_t __alignment, size_t __size) __attribute__((availability(macosx,introduced=10.6)));
void qsort(void *__base, size_t __nel, size_t __width,
int rand(void) ;
void *realloc(void *__ptr, size_t __size) __attribute__((__warn_unused_result__));
void srand(unsigned) ;
double strtod(const char *, char **) __asm("_" "strtod" );
float strtof(const char *, char **) __asm("_" "strtof" );
long strtol(const char *__str, char **__endptr, int __base);
long double
  strtold(const char *, char **);
long long
  strtoll(const char *__str, char **__endptr, int __base);
unsigned long
  strtoul(const char *__str, char **__endptr, int __base);
unsigned long long
  strtoull(const char *__str, char **__endptr, int __base);
# 185 "/usr/include/stdlib.h" 3 4
__attribute__((availability(macosx,introduced=10.0)))
__attribute__((availability(watchos,unavailable))) __attribute__((availability(tvos,unavailable)))
int system(const char *) __asm("_" "system" );
size_t wcstombs(char * , const wchar_t * , size_t);
int wctomb(char *, wchar_t);
void _Exit(int) __attribute__((noreturn));
long a64l(const char *);
double drand48(void);
char *ecvt(double, int, int *, int *);
double erand48(unsigned short[3]);
char *fcvt(double, int, int *, int *);
char *gcvt(double, int, char *);
int getsubopt(char **, char * const *, char **);
int grantpt(int);
char *initstate(unsigned, char *, size_t);
long jrand48(unsigned short[3]) ;
char *l64a(long);
void lcong48(unsigned short[7]);
long lrand48(void) ;
char *mktemp(char *);
int mkstemp(char *);
long mrand48(void) ;
long nrand48(unsigned short[3]) ;
int posix_openpt(int);
char *ptsname(int);
int putenv(char *) __asm("_" "putenv" );
long random(void) ;
int rand_r(unsigned *) ;
char *realpath(const char * , char * ) __asm("_" "realpath" "$DARWIN_EXTSN");
unsigned short
 *seed48(unsigned short[3]);
int setenv(const char * __name, const char * __value, int __overwrite) __asm("_" "setenv" );
void setkey(const char *) __asm("_" "setkey" );
char *setstate(const char *);
void srand48(long);
void srandom(unsigned);
int unlockpt(int);
int unsetenv(const char *) __asm("_" "unsetenv" );
# 1 "/usr/include/machine/types.h" 1 3 4
# 35 "/usr/include/machine/types.h" 3 4
# 1 "/usr/include/i386/types.h" 1 3 4
# 81 "/usr/include/i386/types.h" 3 4
# 1 "/usr/include/sys/_types/_u_int8_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int8_t.h" 3 4
typedef unsigned char u_int8_t;
# 82 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int16_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int16_t.h" 3 4
typedef unsigned short u_int16_t;
# 83 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int32_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int32_t.h" 3 4
typedef unsigned int u_int32_t;
# 84 "/usr/include/i386/types.h" 2 3 4
# 1 "/usr/include/sys/_types/_u_int64_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_u_int64_t.h" 3 4
typedef unsigned long long u_int64_t;
# 85 "/usr/include/i386/types.h" 2 3 4
typedef int64_t register_t;
# 97 "/usr/include/i386/types.h" 3 4
typedef u_int64_t user_addr_t;
typedef u_int64_t user_size_t;
typedef int64_t user_ssize_t;
typedef int64_t user_long_t;
typedef u_int64_t user_ulong_t;
typedef int64_t user_time_t;
typedef int64_t user_off_t;
typedef u_int64_t syscall_arg_t;
# 36 "/usr/include/machine/types.h" 2 3 4
# 252 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_dev_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_dev_t.h" 3 4
typedef __darwin_dev_t dev_t;
# 254 "/usr/include/stdlib.h" 2 3 4
# 1 "/usr/include/sys/_types/_mode_t.h" 1 3 4
# 30 "/usr/include/sys/_types/_mode_t.h" 3 4
typedef __darwin_mode_t mode_t;
# 255 "/usr/include/stdlib.h" 2 3 4
uint32_t arc4random(void);
void arc4random_addrandom(unsigned char * , int )
    __attribute__((availability(macosx,introduced=10.0))) __attribute__((availability(macosx,deprecated=10.12,message="use arc4random_stir")))
    __attribute__((availability(ios,introduced=2.0))) __attribute__((availability(ios,deprecated=10.0,message="use arc4random_stir")))
    __attribute__((availability(tvos,introduced=2.0))) __attribute__((availability(tvos,deprecated=10.0,message="use arc4random_stir")))
    __attribute__((availability(watchos,introduced=1.0))) __attribute__((availability(watchos,deprecated=3.0,message="use arc4random_stir")));
void arc4random_buf(void * __buf, size_t __nbytes) __attribute__((availability(macosx,introduced=10.7)));
void arc4random_stir(void);
uint32_t
  arc4random_uniform(uint32_t __upper_bound) __attribute__((availability(macosx,introduced=10.7)));
int atexit_b(void (^ _Nonnull)(void)) __attribute__((availability(macosx,introduced=10.6)));
void *bsearch_b(const void *__key, const void *__base, size_t __nel,
     size_t __width, int (^ _Nonnull __compar)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
char *cgetcap(char *, const char *, int);
int cgetclose(void);
int cgetent(char **, char **, const char *);
int cgetfirst(char **, char **);
int cgetmatch(const char *, const char *);
int cgetnext(char **, char **);
int cgetnum(char *, const char *, long *);
int cgetset(const char *);
int cgetstr(char *, const char *, char **);
int cgetustr(char *, const char *, char **);
int daemon(int, int) __asm("_" "daemon" "$1050") __attribute__((availability(macosx,introduced=10.0,deprecated=10.5,message="Use posix_spawn APIs instead."))) __attribute__((availability(watchos,unavailable))) __attribute__((availability(tvos,unavailable)));
char *devname(dev_t, mode_t);
char *devname_r(dev_t, mode_t, char *buf, int len);
char *getbsize(int *, long *);
int getloadavg(double [], int);
const char
 *getprogname(void);
int heapsort(void *__base, size_t __nel, size_t __width,
int heapsort_b(void *__base, size_t __nel, size_t __width,
int mergesort(void *__base, size_t __nel, size_t __width,
int mergesort_b(void *__base, size_t __nel, size_t __width,
void psort(void *__base, size_t __nel, size_t __width,
     int (* _Nonnull __compar)(const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void psort_b(void *__base, size_t __nel, size_t __width,
void psort_r(void *__base, size_t __nel, size_t __width, void *,
     int (* _Nonnull __compar)(void *, const void *, const void *)) __attribute__((availability(macosx,introduced=10.6)));
void qsort_b(void *__base, size_t __nel, size_t __width,
void qsort_r(void *__base, size_t __nel, size_t __width, void *,
     int (* _Nonnull __compar)(void *, const void *, const void *));
int radixsort(const unsigned char **__base, int __nel, const unsigned char *__table,
     unsigned __endbyte);
void setprogname(const char *);
int sradixsort(const unsigned char **__base, int __nel, const unsigned char *__table,
void sranddev(void);
void srandomdev(void);
void *reallocf(void *__ptr, size_t __size);
long long
  strtoq(const char *__str, char **__endptr, int __base);
unsigned long long
  strtouq(const char *__str, char **__endptr, int __base);
extern char *suboptarg;
void *valloc(size_t);
# 95 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdlib.h" 2 3
extern "C++" {
# 111 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/stdlib.h" 3
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long abs( long __x) noexcept {return labs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) long long abs(long long __x) noexcept {return llabs(__x);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) ldiv_t div( long __x, long __y) noexcept {return ldiv(__x, __y);}
inline __attribute__ ((__visibility__("hidden"), __always_inline__)) lldiv_t div(long long __x, long long __y) noexcept {return lldiv(__x, __y);}
# 87 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 2 3
# 90 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 3
namespace std {inline namespace __1 {
using ::size_t;
using ::div_t;
using ::ldiv_t;
using ::lldiv_t;
using ::atof;
using ::atoi;
using ::atol;
using ::atoll;
using ::strtod;
using ::strtof;
using ::strtold;
using ::strtol;
using ::strtoll;
using ::strtoul;
using ::strtoull;
using ::rand;
using ::srand;
using ::calloc;
using ::free;
using ::malloc;
using ::realloc;
using ::abort;
using ::atexit;
using ::exit;
using ::_Exit;
using ::getenv;
using ::system;
using ::bsearch;
using ::qsort;
using ::abs;
using ::labs;
using ::llabs;
using ::div;
using ::ldiv;
using ::lldiv;
using ::mblen;
using ::mbtowc;
using ::wctomb;
using ::mbstowcs;
using ::wcstombs;
# 162 "/usr/local/Cellar/llvm/6.0.0/include/c++/v1/cstdlib" 3
# 4 "/tmp/petsc-mjVUVK/config.setCompilers/conftest.cc" 2
Preprocess stderr before filtering::
Preprocess stderr after filtering::
TEST checkFortranCompiler from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:947)
TESTING: checkFortranCompiler from config.setCompilers(config/BuildSystem/config/setCompilers.py:947)
  Locate a functional Fortran compiler
Executing: mpif90 --help
stdout:
Usage: gfortran [options] file...
Options:
  -pass-exit-codes         Exit with highest error code from a phase.
  --help                   Display this information.
  --target-help            Display target specific command line options.
  --help={common|optimizers|params|target|warnings|[^]{joined|separate|undocumented}}[,...].
                           Display specific types of command line options.
  (Use '-v --help' to display command line options of sub-processes).
  --version                Display compiler version information.
  -dumpspecs               Display all of the built in spec strings.
  -dumpversion             Display the version of the compiler.
  -dumpmachine             Display the compiler's target processor.
  -print-search-dirs       Display the directories in the compiler's search path.
  -print-libgcc-file-name  Display the name of the compiler's companion library.
  -print-file-name=<lib>   Display the full path to library <lib>.
  -print-prog-name=<prog>  Display the full path to compiler component <prog>.
  -print-multiarch         Display the target's normalized GNU triplet, used as
                           a component in the library path.
  -print-multi-directory   Display the root directory for versions of libgcc.
  -print-multi-lib         Display the mapping between command line options and
                           multiple library search directories.
  -print-multi-os-directory Display the relative path to OS libraries.
  -print-sysroot           Display the target libraries directory.
  -print-sysroot-headers-suffix Display the sysroot suffix used to find headers.
  -Wa,<options>            Pass comma-separated <options> on to the assembler.
  -Wp,<options>            Pass comma-separated <options> on to the preprocessor.
  -Wl,<options>            Pass comma-separated <options> on to the linker.
  -Xassembler <arg>        Pass <arg> on to the assembler.
  -Xpreprocessor <arg>     Pass <arg> on to the preprocessor.
  -Xlinker <arg>           Pass <arg> on to the linker.
  -save-temps              Do not delete intermediate files.
  -save-temps=<arg>        Do not delete intermediate files.
  -no-canonical-prefixes   Do not canonicalize paths when building relative
                           prefixes to other gcc components.
  -pipe                    Use pipes rather than intermediate files.
  -time                    Time the execution of each subprocess.
  -specs=<file>            Override built-in specs with the contents of <file>.
  -std=<standard>          Assume that the input sources are for <standard>.
  --sysroot=<directory>    Use <directory> as the root directory for headers
                           and libraries.
  -B <directory>           Add <directory> to the compiler's search paths.
  -v                       Display the programs invoked by the compiler.
  -###                     Like -v but options quoted and commands not executed.
  -E                       Preprocess only; do not compile, assemble or link.
  -S                       Compile only; do not assemble or link.
  -c                       Compile and assemble, but do not link.
  -o <file>                Place the output into <file>.
  -pie                     Create a position independent executable.
  -shared                  Create a shared library.
  -x <language>            Specify the language of the following input files.
                           Permissible languages include: c c++ assembler none
                           'none' means revert to the default behavior of
                           guessing the language based on the file's extension.
Options starting with -g, -f, -m, -O, -W, or --param are automatically
 passed on to the various sub-processes invoked by gfortran.  In order to pass
 other options on to these processes the -W<letter> options must be used.
For bug reporting instructions, please see:
<https://github.com/Homebrew/homebrew-core/issues>.
Checking for program /usr/local/bin/mpif90...found
                Defined make macro "FC" to "mpif90"
                Pushing language FC
Executing: mpif90 -c -o /tmp/petsc-mjVUVK/config.setCompilers/conftest.o -I/tmp/petsc-mjVUVK/config.setCompilers   /tmp/petsc-mjVUVK/config.setCompilers/conftest.F90
Successful compile:
Source:
      program main
      end
Successful compile:
Source:
      program main
      end
                                                Pushing language C
                                                Popping language C
                                                Pushing language FC
                                                Popping language FC
                        Pushing language FC
                        Popping language FC
Executing: mpif90  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o
Successful compile:
Source:
      program main
      end
                        Pushing language FC
                        Popping language FC
Executing: mpif90  -o /tmp/petsc-mjVUVK/config.setCompilers/conftest    /tmp/petsc-mjVUVK/config.setCompilers/conftest.o  -lpetsc-ufod4vtr9mqHvKIQiVAm
stderr:
collect2: error: ld returned 1 exit status
Successful compile:
Source:
      program main
      end
                            Pushing language FC
                            Popping language FC
                Popping language FC
TEST checkFortranComments from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:968)
TESTING: checkFortranComments from config.setCompilers(config/BuildSystem/config/setCompilers.py:968)
  Make sure fortran comment "!" works
              Pushing language FC
Successful compile:
Source:
! comment
      program main
      end
            Fortran comments can use ! in column 1
              Popping language FC
TEST checkLargeFileIO from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1085)
TESTING: checkLargeFileIO from config.setCompilers(config/BuildSystem/config/setCompilers.py:1085)
TEST checkArchiver from config.setCompilers(/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py:1184)
TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1184)
  Check that the archiver exists and can make a library usable by the compiler
              Pushing language C
Executing: ar -V
Executing: ar -V
                  Defined make macro "FAST_AR_FLAGS" to "Scq"
Executing: mpicc -c -o /tmp/petsc-mjVUVK/config.setCompilers/conftest.o -I/tmp/petsc-mjVUVK/config.setCompilers   /tmp/petsc-mjVUVK/config.setCompilers/conftest.c
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/local/bin/ar...not found
Checking for program /usr/bin/ar...found
                Defined make macro "AR" to "/usr/bin/ar"
Checking for program /usr/local/bin/ranlib...not found
Checking for program /usr/bin/ranlib...found
                Defined make macro "RANLIB" to "/usr/bin/ranlib -c"
Executing: /usr/bin/ar cr /tmp/petsc-mjVUVK/config.setCompilers/libconf1.a /tmp/petsc-mjVUVK/config.setCompilers/conf1.o
Possible ERROR while running archiver: exit code 256
stderr:
ar: temporary file: No such file or directory
            Archiver is not functional
Executing: ar -V
Executing: ar -V
Successful compile:
Source:
int foo(int a) {
  return a+1;
                Defined make macro "RANLIB" to "/usr/bin/ranlib"
stderr:
Executing: ar -V
Executing: ar -V
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/local/bin/true...not found
Checking for program /usr/bin/true...found
                Defined make macro "RANLIB" to "/usr/bin/true"
stderr:
Executing: ar -V
Executing: ar -V
Successful compile:
Source:
int foo(int a) {
  return a+1;
Executing: /usr/bin/ar -X64 cr /tmp/petsc-mjVUVK/config.setCompilers/libconf1.a /tmp/petsc-mjVUVK/config.setCompilers/conf1.o
stderr:
/Applications/Xcode.app/Contents/Developer/Toolchains/XcodeDefault.xctoolchain/usr/bin/ar: illegal option -- X
usage:  ar -d [-TLsv] archive file ...
	ar -m [-TLsv] archive file ...
	ar -m [-abiTLsv] position archive file ...
	ar -p [-TLsv] archive [file ...]
	ar -q [-cTLsv] archive file ...
	ar -r [-cuTLsv] archive file ...
	ar -r [-abciuTLsv] position archive file ...
	ar -t [-TLsv] archive [file ...]
	ar -x [-ouTLsv] archive [file ...]
Executing: ar -V
Executing: ar -V
Successful compile:
Source:
int foo(int a) {
  return a+1;
stderr:
Executing: ar -V
Executing: ar -V
Successful compile:
Source:
int foo(int a) {
  return a+1;
stderr:
                  Defined make macro "FAST_AR_FLAGS" to "-a -P512"
Successful compile:
Source:
int foo(int a) {
  return a+1;
Checking for program /usr/local/bin/win32fe...not found
Checking for program /usr/bin/win32fe...not found
Checking for program /bin/win32fe...not found
Checking for program /usr/sbin/win32fe...not found
Checking for program /sbin/win32fe...not found
Checking for program /Applications/VMware Fusion.app/Contents/Public/win32fe...not found
Checking for program /Library/TeX/texbin/win32fe...not found
Checking for program /Users/zhihui/win32fe...not found
Checking for program /Users/zhihui/igx/deps/srcs/petsc-3.8.3/bin/win32fe/win32fe...not found
                  Defined make macro "FAST_AR_FLAGS" to "-a"
Successful compile:
Source:
int foo(int a) {
  return a+1;
              Popping language C
         UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
Could not find a suitable archiver.  Use --with-ar to specify an archiver.
  File "./config/configure.py", line 393, in petsc_configure
    framework.configure(out = sys.stdout)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1097, in configure
    self.processChildren()
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1086, in processChildren
    self.serialEvaluation(self.childGraph)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/framework.py", line 1067, in serialEvaluation
    child.configure()
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py", line 1692, in configure
    self.executeTest(self.checkArchiver)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/base.py", line 126, in executeTest
    ret = test(*args,**kargs)
  File "/Users/zhihui/igx/deps/srcs/petsc-3.8.3/config/BuildSystem/config/setCompilers.py", line 1237, in checkArchiver
    raise RuntimeError('Could not find a suitable archiver.  Use --with-ar to specify an archiver.')
Finishing Configure Run at Thu Oct 25 16:25:32 2018
------------------ Original ------------------
Send time: Friday, Oct 26, 2018 6:23 AM
To: "avatar"<648934229 at qq.com>;
Cc: "petsc-users"<petsc-users at mcs.anl.gov>;
Subject:  Re: [petsc-users] "Could not find a suitable archiver. Use --with-arto  specify an archiver"
Its best to stick with one list - so will follow up on petsc-maint.
Satish
On Fri, 26 Oct 2018, avatar wrote:
> Hi,
> When I try to configure PETSc to connect Matlab with the following command
> ./petsc-3.8.3/configure ??with-matlab
> , it prompts
>              Configuring PETSc to compile on your system
> TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1184)                  *******************************************************************************
> I am a newbie on Petsc. Could you please tell me how I should specify an archiver?  I am on MacOX system. I have tried many ways but it still does not work.
> Thank you very much for your help.
> Best,
> Joe
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181026/956c06c3/attachment-0001.html>
