[petsc-users] "Could not find a suitable archiver. Use --with-ar to specify an archiver"
Balay, Satish balay at mcs.anl.gov
Thu Oct 25 17:23:59 CDT 2018
Its best to stick with one list - so will follow up on petsc-maint.
Satish
On Fri, 26 Oct 2018, avatar wrote:
> Hi,
> When I try to configure PETSc to connect Matlab with the following command
> ./petsc-3.8.3/configure ??with-matlab
> , it prompts
>              Configuring PETSc to compile on your system
> TESTING: checkArchiver from config.setCompilers(config/BuildSystem/config/setCompilers.py:1184)                  *******************************************************************************
>          UNABLE to CONFIGURE with GIVEN OPTIONS    (see configure.log for details):
> Could not find a suitable archiver.  Use --with-ar to specify an archiver.
> I am a newbie on Petsc. Could you please tell me how I should specify an archiver?  I am on MacOX system. I have tried many ways but it still does not work.
> Thank you very much for your help.
> Best,
> Joe
