[petsc-users] PetscInt overflow
Jan Grießer griesser.jan at googlemail.com
Wed Oct 24 11:07:49 CDT 2018
For some reason i get only this error message, also when is use the
-eps_view_pre. I started the program with nev=1, there the output is  (with
-bv_type vecs -bv_type mat -eps_view_pre)
EPS Object: 20 MPI processes
  type: krylovschur
    50% of basis vectors kept after restart
    using the locking variant
  problem type: symmetric eigenvalue problem
  selected portion of the spectrum: smallest real parts
  number of eigenvalues (nev): 1
  number of column vectors (ncv): 3
  maximum dimension of projected problem (mpd): 2
  maximum number of iterations: 1000
  tolerance: 1e-08
  convergence test: relative to the eigenvalue
BV Object: 20 MPI processes
  type: mat
  4 columns of global length 1500000
  vector orthogonalization method: classical Gram-Schmidt
  orthogonalization refinement: if needed (eta: 0.7071)
  block orthogonalization method: GS
  doing matmult as a single matrix-matrix product
DS Object: 20 MPI processes
  type: hep
  parallel operation mode: REDUNDANT
  solving the problem with: Implicit QR method (_steqr)
ST Object: 20 MPI processes
  type: shift
  shift: 0.
  number of matrices: 1
Am Mi., 24. Okt. 2018 um 16:14 Uhr schrieb Matthew Knepley <
knepley at gmail.com>:
> On Wed, Oct 24, 2018 at 10:03 AM Jan Grießer <griesser.jan at googlemail.com>
> wrote:
>> This is the error message i get from my program:
>> Shape of the dynamical matrix:  (1500000, 1500000)
> Petsc installs a signal handler, so there should be a PETSc-specific
> message before this one. Is something eating
> your output?
>   Thanks,
>      Matt
>> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
>> =   PID 122676 RUNNING AT n3512.nemo.privat
>> =   EXIT CODE: 9
>> =   CLEANING UP REMAINING PROCESSES
>> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>>    Intel(R) MPI Library troubleshooting guide:
>>       https://software.intel.com/node/561764
>> Am Mi., 24. Okt. 2018 um 16:01 Uhr schrieb Matthew Knepley <
>>> On Wed, Oct 24, 2018 at 9:38 AM Jan Grießer <griesser.jan at googlemail.com>
>>> wrote:
>>>> Hey,
>>>> i tried to run my program as you said with -bv_type vecs and/or
>>>> -bv_type mat, but instead of the PETScInt overflow i now get an MPI Error 9
>>> Send the actual error.
>>>   Thanks,
>>>     Matt
>>>> message, which i assume (after googling a little bit around) should be
>>>> a memory problem. I tried to run it also on slightly bigger compute nodes
>>>> on our cluster with 20 cores with each 12 GB and 24 GB but the problem
>>>> still remains. The actual limit appears to be a 1.5 Million x 1.5 Million
>>>> where i  searched for NEV = 1500 and MPD = 500/ 200 eigenvalues.
>>>> Do you have maybe an idea what the error could be? I appended also the
>>>> python method i used to solve the problem. I also tried to solve the
>>>> problem with spectrum solving but the error message remains the same.
>>>> def solve_eigensystem(DynMatrix_nn, NEV, MPD, Dimension):
>>>> # Create the solver
>>>> # E is used as an acronym for the EPS solver (EPS = Eigenvalue problem
>>>> solver)
>>>> E = SLEPc.EPS().create()
>>>> # Set the preconditioner
>>>> pc = PETSc.PC().create()
>>>> pc.setType(pc.Type.BJACOBI)
>>>> # Set the linear solver
>>>> # Create the KSP object
>>>> ksp = PETSc.KSP().create()
>>>> # Create the solver, in this case GMRES
>>>> ksp.setType(ksp.Type.GMRES)
>>>> # Set the tolerances of the GMRES solver
>>>>         # Link it to the PC
>>>> ksp.setPC(pc)
>>>> # Set up the spectral transformations
>>>> st = SLEPc.ST().create()
>>>> st.setType("shift")
>>>> st.setKSP(ksp)
>>>> # MPD stands for "maximum projected dimension". It has to due with
>>>> computational cost, please read Chap. 2.6.5 of SLEPc docu for
>>>> # an explanation. At the moment mpd is only a guess
>>>> E.setDimensions(nev=NEV, mpd = MPD)
>>>> # Eigenvalues should be real, therefore we start to order them from the
>>>> smallest real value |l.real|
>>>> E.setWhichEigenpairs(E.Which.SMALLEST_REAL)
>>>> # Since the dynamical matrix is symmetric and real it is hermitian
>>>> E.setProblemType(SLEPc.EPS.ProblemType.HEP)
>>>> # Use the Krylov Schur method to solve the eigenvalue problem
>>>> E.setType(E.Type.KRYLOVSCHUR)
>>>> # Set the convergence criterion to relative to the eigenvalue and the
>>>> maximal number of iterations
>>>> E.setConvergenceTest(E.Conv.REL)
>>>> E.setTolerances(tol = 1e-8, max_it = 5000)
>>>> # Set the matrix in order to solve
>>>> E.setOperators(DynMatrix_nn, None)
>>>> # Sets EPS options from the options database. This routine must be
>>>> called before `setUp()` if the user is to be allowed to set dthe solver
>>>> type.
>>>> E.setFromOptions()
>>>> # Sets up all the internal data structures necessary for the execution
>>>> of the eigensolver.
>>>> E.setUp()
>>>> # Solve eigenvalue problem
>>>> E.solve()
>>>> Print = PETSc.Sys.Print
>>>> Print()
>>>> Print("****************************")
>>>> Print("***SLEPc Solution Results***")
>>>> its = E.getIterationNumber()
>>>> Print("Number of iterations of the method: ", its)
>>>> eps_type = E.getType()
>>>> Print("Solution method: ", eps_type)
>>>> nev, ncv, mpd = E.getDimensions()
>>>> Print("Number of requested eigenvalues: ", nev)
>>>> Print("Number of computeded eigenvectors: ", ncv)
>>>> tol, maxit = E.getTolerances()
>>>> Print("Stopping condition: (tol, maxit)", (tol, maxit))
>>>> # Get the type of convergence
>>>> conv_test = E.getConvergenceTest()
>>>> Print("Selected convergence test: ", conv_test)
>>>> # Get the used spectral transformation
>>>> get_st = E.getST()
>>>> Print("Selected spectral transformation: ", get_st)
>>>> # Get the applied direct solver
>>>> get_ksp = E.getDS()
>>>> Print("Selected direct solver: ", get_ksp)
>>>> nconv = E.getConverged()
>>>> Print("Number of converged eigenpairs: ", nconv)
>>>> Am Fr., 19. Okt. 2018 um 21:00 Uhr schrieb Smith, Barry F. <
>>>> bsmith at mcs.anl.gov>:
>>>>> > On Oct 19, 2018, at 7:56 AM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>>>> wrote:
>>>>> > On Fri, Oct 19, 2018 at 4:02 AM Jan Grießer <
>>>>> griesser.jan at googlemail.com> wrote:
>>>>> > With more than 1 MPI process you mean i should use spectrum slicing
>>>>> in divide the full problem in smaller subproblems?
>>>>> > The --with-64-bit-indices is not a possibility for me since i
>>>>> configured petsc with mumps, which does not allow to use the 64-bit version
>>>>> (At least this was the error message when i tried to configure PETSc )
>>>>> > MUMPS 5.1.2 manual chapter 2.4.2 says it supports "Selective 64-bit
>>>>> integer feature" and "full 64-bit integer version" as well.
>>>>>     They use to achieve this by compiling with special Fortran flags
>>>>> to promote integers to 64 bit; this is too fragile for our taste so we
>>>>> never hooked PETSc up wit it. If they have a dependable way of using 64 bit
>>>>> integers we should add that to our mumps.py and test it.
>>>>>    Barry
>>>>> > Am Mi., 17. Okt. 2018 um 18:24 Uhr schrieb Jose E. Roman <
>>>>> jroman at dsic.upv.es>:
>>>>> > To use BVVECS just add the command-line option -bv_type vecs
>>>>> > This causes to use a separate Vec for each column, instead of a
>>>>> single long Vec of size n*m. But it is considerably slower than the default.
>>>>> > Anyway, for such large problems you should consider using more than
>>>>> 1 MPI process. In that case the error may disappear because the local size
>>>>> is smaller than 768000.
>>>>> > Jose
>>>>> > > El 17 oct 2018, a las 17:58, Matthew Knepley <knepley at gmail.com>
>>>>> escribió:
>>>>> > > On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <
>>>>> > > Hi all,
>>>>> > > i am using slepc4py and petsc4py to solve for the smallest real
>>>>> eigenvalues and eigenvectors. For my test cases with a matrix A of the size
>>>>> 30k x 30k solving for the smallest soutions works quite well, but when i
>>>>> increase the dimension of my system to around A = 768000 x 768000 or 3
>>>>> million x 3 million and ask for the smallest real 3000 (the number is
>>>>> increasing with increasing system size) eigenvalues and eigenvectors i get
>>>>> the output (for the 768000):
>>>>> > >  The product 4001 times 768000 overflows the size of PetscInt;
>>>>> consider reducing the number of columns, or use BVVECS instead
>>>>> > > i understand that the requested number of eigenvectors and
>>>>> eigenvalues is causing an overflow but i do not understand the solution of
>>>>> the problem which is stated in the error message. Can someone tell me what
>>>>> exactly BVVECS is and how i can use it? Or is there any other solution to
>>>>> my problem ?
>>>>> > > You can also reconfigure with 64-bit integers:
>>>>> > >   Thanks,
>>>>> > >     Matt
>>>>> > > Thank you very much in advance,
>>>>> > > Jan
>>>>> > > What most experimenters take for granted before they begin their
>>>>> experiments is infinitely more interesting than any results to which their
>>>>> experiments lead.
>>>>> > > -- Norbert Wiener
>>>>> > > https://www.cse.buffalo.edu/~knepley/
>>> experiments lead.
>>> -- Norbert Wiener
>>> <http://www.cse.buffalo.edu/~knepley/>
> experiments lead.
> -- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181024/a5424641/attachment-0001.html>
