[petsc-users] PetscInt overflow
Wed Oct 24 09:14:35 CDT 2018
On Wed, Oct 24, 2018 at 10:03 AM Jan Grießer <griesser.jan at googlemail.com>
wrote:
> This is the error message i get from my program:
> Shape of the dynamical matrix:  (1500000, 1500000)
Petsc installs a signal handler, so there should be a PETSc-specific
message before this one. Is something eating
your output?
     Matt
> =   BAD TERMINATION OF ONE OF YOUR APPLICATION PROCESSES
> =   PID 122676 RUNNING AT n3512.nemo.privat
> =   EXIT CODE: 9
> =   CLEANING UP REMAINING PROCESSES
> =   YOU CAN IGNORE THE BELOW CLEANUP MESSAGES
>    Intel(R) MPI Library troubleshooting guide:
>       https://software.intel.com/node/561764
> Am Mi., 24. Okt. 2018 um 16:01 Uhr schrieb Matthew Knepley <
> knepley at gmail.com>:
>> On Wed, Oct 24, 2018 at 9:38 AM Jan Grießer <griesser.jan at googlemail.com>
>> wrote:
>>> Hey,
>>> i tried to run my program as you said with -bv_type vecs and/or -bv_type
>>> mat, but instead of the PETScInt overflow i now get an MPI Error 9
>> Send the actual error.
>>   Thanks,
>>     Matt
>>> message, which i assume (after googling a little bit around) should be a
>>> memory problem. I tried to run it also on slightly bigger compute nodes on
>>> our cluster with 20 cores with each 12 GB and 24 GB but the problem still
>>> remains. The actual limit appears to be a 1.5 Million x 1.5 Million where
>>> i  searched for NEV = 1500 and MPD = 500/ 200 eigenvalues.
>>> Do you have maybe an idea what the error could be? I appended also the
>>> python method i used to solve the problem. I also tried to solve the
>>> problem with spectrum solving but the error message remains the same.
>>> def solve_eigensystem(DynMatrix_nn, NEV, MPD, Dimension):
>>> # Create the solver
>>> # E is used as an acronym for the EPS solver (EPS = Eigenvalue problem
>>> solver)
>>> E = SLEPc.EPS().create()
>>> # Set the preconditioner
>>> pc = PETSc.PC().create()
>>> pc.setType(pc.Type.BJACOBI)
>>> # Set the linear solver
>>> # Create the KSP object
>>> ksp = PETSc.KSP().create()
>>> # Create the solver, in this case GMRES
>>> ksp.setType(ksp.Type.GMRES)
>>> # Set the tolerances of the GMRES solver
>>>         # Link it to the PC
>>> ksp.setPC(pc)
>>> # Set up the spectral transformations
>>> st = SLEPc.ST().create()
>>> st.setType("shift")
>>> st.setKSP(ksp)
>>> # MPD stands for "maximum projected dimension". It has to due with
>>> computational cost, please read Chap. 2.6.5 of SLEPc docu for
>>> # an explanation. At the moment mpd is only a guess
>>> E.setDimensions(nev=NEV, mpd = MPD)
>>> # Eigenvalues should be real, therefore we start to order them from the
>>> smallest real value |l.real|
>>> E.setWhichEigenpairs(E.Which.SMALLEST_REAL)
>>> # Since the dynamical matrix is symmetric and real it is hermitian
>>> E.setProblemType(SLEPc.EPS.ProblemType.HEP)
>>> # Use the Krylov Schur method to solve the eigenvalue problem
>>> E.setType(E.Type.KRYLOVSCHUR)
>>> # Set the convergence criterion to relative to the eigenvalue and the
>>> maximal number of iterations
>>> E.setConvergenceTest(E.Conv.REL)
>>> E.setTolerances(tol = 1e-8, max_it = 5000)
>>> # Set the matrix in order to solve
>>> E.setOperators(DynMatrix_nn, None)
>>> # Sets EPS options from the options database. This routine must be
>>> called before `setUp()` if the user is to be allowed to set dthe solver
>>> type.
>>> E.setFromOptions()
>>> # Sets up all the internal data structures necessary for the execution
>>> of the eigensolver.
>>> E.setUp()
>>> # Solve eigenvalue problem
>>> E.solve()
>>> Print = PETSc.Sys.Print
>>> Print()
>>> Print("****************************")
>>> Print("***SLEPc Solution Results***")
>>> its = E.getIterationNumber()
>>> Print("Number of iterations of the method: ", its)
>>> eps_type = E.getType()
>>> Print("Solution method: ", eps_type)
>>> nev, ncv, mpd = E.getDimensions()
>>> Print("Number of requested eigenvalues: ", nev)
>>> Print("Number of computeded eigenvectors: ", ncv)
>>> tol, maxit = E.getTolerances()
>>> Print("Stopping condition: (tol, maxit)", (tol, maxit))
>>> # Get the type of convergence
>>> conv_test = E.getConvergenceTest()
>>> Print("Selected convergence test: ", conv_test)
>>> # Get the used spectral transformation
>>> get_st = E.getST()
>>> Print("Selected spectral transformation: ", get_st)
>>> # Get the applied direct solver
>>> get_ksp = E.getDS()
>>> Print("Selected direct solver: ", get_ksp)
>>> nconv = E.getConverged()
>>> Print("Number of converged eigenpairs: ", nconv)
>>> Am Fr., 19. Okt. 2018 um 21:00 Uhr schrieb Smith, Barry F. <
>>> bsmith at mcs.anl.gov>:
>>>> > On Oct 19, 2018, at 7:56 AM, Zhang, Junchao <jczhang at mcs.anl.gov>
>>>> wrote:
>>>> > On Fri, Oct 19, 2018 at 4:02 AM Jan Grießer <
>>>> griesser.jan at googlemail.com> wrote:
>>>> > With more than 1 MPI process you mean i should use spectrum slicing
>>>> in divide the full problem in smaller subproblems?
>>>> > The --with-64-bit-indices is not a possibility for me since i
>>>> configured petsc with mumps, which does not allow to use the 64-bit version
>>>> (At least this was the error message when i tried to configure PETSc )
>>>> > MUMPS 5.1.2 manual chapter 2.4.2 says it supports "Selective 64-bit
>>>> integer feature" and "full 64-bit integer version" as well.
>>>>     They use to achieve this by compiling with special Fortran flags to
>>>> promote integers to 64 bit; this is too fragile for our taste so we never
>>>> hooked PETSc up wit it. If they have a dependable way of using 64 bit
>>>> integers we should add that to our mumps.py and test it.
>>>>    Barry
>>>> > Am Mi., 17. Okt. 2018 um 18:24 Uhr schrieb Jose E. Roman <
>>>> jroman at dsic.upv.es>:
>>>> > To use BVVECS just add the command-line option -bv_type vecs
>>>> > This causes to use a separate Vec for each column, instead of a
>>>> single long Vec of size n*m. But it is considerably slower than the default.
>>>> > Anyway, for such large problems you should consider using more than 1
>>>> MPI process. In that case the error may disappear because the local size is
>>>> smaller than 768000.
>>>> > Jose
>>>> > > El 17 oct 2018, a las 17:58, Matthew Knepley <knepley at gmail.com>
>>>> escribió:
>>>> > > On Wed, Oct 17, 2018 at 11:54 AM Jan Grießer <
>>>> > > Hi all,
>>>> > > i am using slepc4py and petsc4py to solve for the smallest real
>>>> eigenvalues and eigenvectors. For my test cases with a matrix A of the size
>>>> 30k x 30k solving for the smallest soutions works quite well, but when i
>>>> increase the dimension of my system to around A = 768000 x 768000 or 3
>>>> million x 3 million and ask for the smallest real 3000 (the number is
>>>> increasing with increasing system size) eigenvalues and eigenvectors i get
>>>> the output (for the 768000):
>>>> > >  The product 4001 times 768000 overflows the size of PetscInt;
>>>> consider reducing the number of columns, or use BVVECS instead
>>>> > > i understand that the requested number of eigenvectors and
>>>> eigenvalues is causing an overflow but i do not understand the solution of
>>>> the problem which is stated in the error message. Can someone tell me what
>>>> exactly BVVECS is and how i can use it? Or is there any other solution to
>>>> my problem ?
>>>> > > You can also reconfigure with 64-bit integers: --with-64-bit-indices
>>>> > >   Thanks,
>>>> > >     Matt
>>>> > > Thank you very much in advance,
>>>> > > Jan
>>>> > > What most experimenters take for granted before they begin their
>>>> experiments is infinitely more interesting than any results to which their
>>>> experiments lead.
>>>> > > -- Norbert Wiener
>>>> > > https://www.cse.buffalo.edu/~knepley/
>> experiments lead.
>> -- Norbert Wiener
>> <http://www.cse.buffalo.edu/~knepley/>
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181024/3f957cd0/attachment-0001.html>
