[petsc-users] Slepc: Nonlinear eigenvalue problem
Manav Bhatia
bhatiamanav at gmail.com
Mon Oct 22 14:40:24 CDT 2018
As a followup to this, if I am using a shell matrix for eigensolution (linear or nonlinear eigenproblems), what operations should be defined for the shell matrix?
-Manav
> On Oct 22, 2018, at 2:05 PM, Manav Bhatia <bhatiamanav at gmail.com> wrote:
> Hi,
> I am exploring the nonlinear eigenvalue problem solver in Slepc.
> From the notes in "Sec 6.4: Retrieving the Solution”, it appears that if I expect to find complex eigenpairs then I must compile the library (and Petsc) with complex scalars. Is that correct?
> Is there a way to include support for complex eigenpairs in a library complied with real scalars?
> Regards,
> Manav
