[petsc-users] p4est error
Mark Adams mfadams at lbl.gov
Sat Oct 20 15:52:54 CDT 2018
I am getting this error. This was a clean build (nuked the arch directory).
13:50 nid12922 master= ~/petsc_install/petsc$ make
PETSC_DIR=/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel
PETSC_ARCH="" test
Running test examples to verify correct installation
Using
and PETSC_ARCH=
*******************Error detected during compile or link!*******************
See http://www.mcs.anl.gov/petsc/documentation/faq.html
/global/homes/m/madams/petsc_install/petsc/src/snes/examples/tutorials ex19
cc -o ex19.o -c -g -fp-model fast
 -I/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/include
  `pwd`/ex19.c
cc -g -fp-model fast  -o ex19 ex19.o
-L/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib
-Wl,-rpath,/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib
-lpetsc -lcmumps -ldmumps -lsmumps -lzmumps -lmumps_common -lpord
-lscalapack -lfftw3_mpi -lfftw3 -lp4est -lsc -lflapack -lfblas
-lhdf5hl_fortran -lhdf5_fortran -lhdf5_hl -lhdf5 -lchaco -lparmetis -lmetis
-lstdc++ -ldl
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libpetsc.a(dlimpl.o):
In function `PetscDLOpen':
/global/u2/m/madams/petsc_install/petsc/src/sys/dll/dlimpl.c:108: warning:
Using 'dlopen' in statically linked applications requires at runtime the
shared libraries from the glibc version used for linking
/usr/lib64/gcc/x86_64-suse-linux/4.8/../../../../x86_64-suse-linux/bin/ld:
Warning: alignment 8 of symbol `ARCHITECTURE' in
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libchaco.a(user_params.o)
is smaller than 32 in
/opt/cray/pe/pmi/5.0.13/lib64/libpmi.a(_pmi_topology_discovery.o)
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libpetsc.a(send.o):
In function `PetscOpenSocket':
/global/u2/m/madams/petsc_install/petsc/src/sys/classes/viewer/impls/socket/send.c:108:
warning: Using 'gethostbyname' in statically linked applications requires
at runtime the shared libraries from the glibc version used for linking
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libp4est.a(src_libp4est_la-p4est.o):
In function `p4est_checksum':
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/src/p4est.c:3228:
undefined reference to `adler32'
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/src/p4est.c:3236:
undefined reference to `adler32_combine'
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libp4est.a(src_libp4est_la-p4est_communication.o):
In function `p4est_comm_checksum':
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/src/p4est_communication.c:903:
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libp4est.a(src_libp4est_la-p8est.o):
In function `p8est_checksum':
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libp4est.a(src_libp4est_la-p8est_communication.o):
In function `p8est_comm_checksum':
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libsc.a(src_libsc_la-sc_containers.o):
In function `sc_array_checksum':
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/sc/src/sc_containers.c:565:
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/sc/src/sc_containers.c:571:
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/libsc.a(src_libsc_la-sc_io.o):
In function `sc_vtk_write_compressed':
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/sc/src/sc_io.c:492:
undefined reference to `compress2'
/global/u2/m/madams/petsc_install/petsc/arch-cori-haswell-opt-intel/externalpackages/git.p4est/sc/src/sc_io.c:507:
/global/homes/m/madams/petsc_install/petsc-cori-haswell-opt-intel/lib/petsc/conf/test:13:
recipe for target 'ex19' failed
gmake[3]: [ex19] Error 1 (ignored)
true ex19
rm ex19.o
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181020/d8c43d0f/attachment.html>
