[petsc-users] Some Problems in Modifying Parallel Programs
Yingjie Wu yjwu16 at gmail.com
Mon Oct 15 10:12:54 CDT 2018
Thank you very much, Matt.
My problem is actually a two-dimensional problem, and the matrix in my
binary file is actually a two-dimensional array, each point corresponding
to a value on the two-dimensional grid.
Your suggestion is very useful to me. I can try to convert the matrix
binary file into a vector binary file to give program an initial value. So
what I should do is:
1. establish parallel vectors.
 2. reads data from binary files to vectors. (VecLoad())
3. use VecGetArray() in FormInitialGuess() to use vector elements to give
the initial values of the field variables.
I know DM can support parallel computing (domain decomposition). How can I
ensure that the part of the vector built on each processor corresponds to
the index of DM object? (Cause my field variables are established by
DMDACreate2d,  and I want to assign initial values to field variables using
read vectors )
Yingjie
Matthew Knepley <knepley at gmail.com> 于2018年10月15日周一 下午10:52写道:
> On Mon, Oct 15, 2018 at 10:42 AM Yingjie Wu <yjwu16 at gmail.com> wrote:
>> Dear Petsc developer:
>> Hi,
>> Thank you very much for your previous reply.
>> I recently wanted to modify my program to parallel version, and
>> encountered some problems in modifying it.
>> 1. There are functions (read matrix) in the program that reads files,will
>> they affect my parallelism?
> No, MatLoad works in parallel. This will work unchanged if you want the
> default layout. If you want a special partition,
> you must call MatSetSizes() after MatCreate().
>> The codes are as follows:
>> ierr = PetscViewerBinaryOpen (PETSC_COMM_WORLD, file, FILE_MODE_READ,
>> &viewer); CHKERRQ (ierr);
>> ierr = MatCreate (PETSC_COMM_WORLD, &A1); CHKERRQ (ierr);
>> ierr = MatSetFromOptions (A1); CHKERRQ (ierr);
>> ierr = MatCreate (PETSC_COMM_WORLD, &A2); CHKERRQ (ierr);
>> ierr = MatSetFromOptions (A2); CHKERRQ (ierr);
>> ierr = MatLoad (A1, viewer); CHKERRQ (ierr);
>> ierr = MatLoad (A2, viewer); CHKERRQ (ierr);
>> ierr = PetscViewerDestroy (&viewer); CHKERRQ (ierr);
>> I read two matrix information from a binary file and wanted to use it on
>> each processor (in fact, my goal was to use these two matrices to give
>> initial values to the two field variables). The program can run in serial
>> time. Now I want to change it to parallel program. What do I need to
>> modify?
>> 2. Following the last question, I used the following code in giving
>> initial value procedure FormInitialGuess():
>> ierr = MatSeqAIJGetArray (A1, &initial_phi1); CHKERRQ (ierr);
>> ierr = MatSeqAIJGetArray (A2, &initial_phi2); CHKERRQ (ierr);
>> I found this function on manualpages, and I felt that it could fulfill my
>> need to represent the elements of the matrix in arrays to give field
>> variables an initial value in each grid. The matrix A1 and A2 above are
>> actually the matrix information that was read from the file before. Now I
>> want to modify it as a parallel program. How do I use matrix information to
>> give initial values in parallel? (In program, field variables are
>> implemented through DM because parallel computing and Ghost Value are
>> supported)
> I do not understand the use of matrices to initialize field values.
> Usually field values are stored on Vec objects, and this is
> the philosophy of DM objects.
>   Thanks,
>      Matt
>> Thanks,
>> Yingjie
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181015/5d60b58c/attachment.html>
