[petsc-users] STFILTER in slepc
Moritz Cygorek mcygorek at uottawa.ca
Wed Oct 10 14:10:34 CDT 2018
Thank you for the fast reply.
I've tried running my program (using the defaul Krylov-Schur method for sparse MPI matrices) with the additional options:
-st_type filter -st_filter_degree 2 -st_filter_interval 2.,2.7  -st_filter_range -2000,2000
and I get the following error message:
[0]PETSC ERROR: STFILTER cannot get the filter specified; please adjust your filter parameters (e.g. increasing the polynomial degree)
[0]PETSC ERROR: #1 FILTLAN_GetIntervals() line 451 in /home/applications/sources/libraries/slepc-3.9.2/src/sys/classes/st/impls/filter/filtlan.c
[0]PETSC ERROR: #2 STFilter_FILTLAN_setFilter() line 1016 in /home/applications/sources/libraries/slepc-3.9.2/src/sys/classes/st/impls/filter/filtlan.c
[0]PETSC ERROR: #3 STSetUp_Filter() line 42 in /home/applications/sources/libraries/slepc-3.9.2/src/sys/classes/st/impls/filter/filter.c
[0]PETSC ERROR: #4 STSetUp() line 271 in /home/applications/sources/libraries/slepc-3.9.2/src/sys/classes/st/interface/stsolve.c
[0]PETSC ERROR: #5 EPSSetUp() line 263 in /home/applications/sources/libraries/slepc-3.9.2/src/eps/interface/epssetup.c
[0]PETSC ERROR: #6 EPSSolve() line 135 in /home/applications/sources/libraries/slepc-3.9.2/src/eps/interface/epssolve.c
Do you have a clue what I've missed?
Moritz
Sent: Wednesday, October 10, 2018 2:30 PM
To: Moritz Cygorek
Cc: petsc-users at mcs.anl.gov
Subject: Re: [petsc-users] STFILTER in slepc
> El 10 oct 2018, a las 19:54, Moritz Cygorek <mcygorek at uottawa.ca> escribió:
> Hi,
> in the list of changes to SLEPc version 3.8, it is stated that there is a preliminary implementation of polynomial filtering using STFILTER.
> Because I am struggling to obtain interior eigenvalues and harmonic extraction seems not to be stable enough in my case, I wanted to give it a try, but I could not find any documentation yet.
> Does anybody have an example of how to use STFILTER or any documentation about it?
> Thanks in advance,
> Moritz
There are no examples. You just set the type to STFILTER and set some parameters such as the interval of interest or the polynomial degree. See functions starting with STFilter here: http://slepc.upv.es/documentation/current/docs/manualpages/ST/index.html
In some problems it works well, but don't expect too much. It is still in our to-do list to make it more usable. It will be good to have your feedback. If you want, send results to slepc-maint, maybe we can help tuning the parameters.
Jose
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181010/32523f3c/attachment.html>
