[petsc-users] Increasing norm with finer mesh
Mark Adams mfadams at lbl.gov
Tue Oct 9 02:50:01 CDT 2018
To reiterate what Matt is saying, you seem to have the exact solution on a
10x10 grid. That makes no sense unless the solution can be represented
exactly by your FE space (eg, u(x,y) = x + y).
On Mon, Oct 8, 2018 at 9:33 PM Matthew Knepley <knepley at gmail.com> wrote:
> On Mon, Oct 8, 2018 at 9:28 PM Weizhuo Wang <weizhuo2 at illinois.edu> wrote:
>> The code is attached in case anyone wants to take a look, I will try the
>> high frequency scenario later.
> That is not the error. It is superconvergence at the vertices. The real
> solution is trigonometric, so your
> linear interpolants or whatever you use is not going to get the right
> value in between mesh points. You
> need to do a real integral over the whole interval to get the L_2 error.
>   Thanks,
>      Matt
>> On Mon, Oct 8, 2018 at 7:58 PM Mark Adams <mfadams at lbl.gov> wrote:
>>> On Mon, Oct 8, 2018 at 6:58 PM Weizhuo Wang <weizhuo2 at illinois.edu>
>>> wrote:
>>>> The first plot is the norm with the flag -pc_type lu with respect to
>>>> number of grids in one axis (n), and the second plot is the norm without
>>>> the flag -pc_type lu.
>>> So you are using the default PC w/o LU. The default is ILU. This will
>>> reduce high frequency effectively but is not effective on the low frequency
>>> error. Don't expect your algebraic error reduction to be at the same scale
>>> as the residual reduction (what KSP measures).
>> Wang Weizhuo
> experiments lead.
> -- Norbert Wiener
> <http://www.cse.buffalo.edu/~knepley/>
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181009/a6ba6473/attachment.html>
