[petsc-users] pkg-config
Adrian Croucher
a.croucher at auckland.ac.nz
Sun Oct 7 21:18:03 CDT 2018
OK thanks Jed, that's fixed it.
- Adrian
On 8/10/18 2:14 PM, Jed Brown wrote:
> This was a bug, now fixed in 'maint' and will be in the next patch
> release. You can repair the PETSc.pc, update to 'maint', or apply this
> 2-line patch.
> https://bitbucket.org/petsc/petsc/commits/e1e675de8c3f48a6c27b15412e00ded76072f735
> Adrian Croucher <a.croucher at auckland.ac.nz> writes:
>> hi
>> I am experimenting with using pkg-config to help build my code, and
>> using the PETSc.pc file in $PETSC_DIR/$PETSC_ARCH/lib/pkgconfig.
>> At present it is not working, because the PETSc.pc file sets Libs:
>> -L${libdir} -lpetsc
>> where libdir=${prefix}/lib, and (in my case at least) prefix is equal to
>> $PETSC_DIR.
>> But the PETSc library is not in $PETSC_DIR/lib, it is in
>> $PETSC_DIR/$PETSC_ARCH/lib.
>> Have I messed something up in my PETSc config so that the PETSc.pc file
>> is not quite right?
>> - Adrian
Dr Adrian Croucher
Senior Research Fellow
Department of Engineering Science
University of Auckland, New Zealand
email: a.croucher at auckland.ac.nz
tel: +64 (0)9 923 4611
