[petsc-users] pkg-config
Jed Brown jed at jedbrown.org
Sun Oct 7 20:14:00 CDT 2018
This was a bug, now fixed in 'maint' and will be in the next patch
release.  You can repair the PETSc.pc, update to 'maint', or apply this
2-line patch.
https://bitbucket.org/petsc/petsc/commits/e1e675de8c3f48a6c27b15412e00ded76072f735
Adrian Croucher <a.croucher at auckland.ac.nz> writes:
> hi
> I am experimenting with using pkg-config to help build my code, and
> using the PETSc.pc file in $PETSC_DIR/$PETSC_ARCH/lib/pkgconfig.
> At present it is not working, because the PETSc.pc file sets Libs:
> -L${libdir} -lpetsc
> where libdir=${prefix}/lib, and (in my case at least) prefix is equal to
> $PETSC_DIR.
> But the PETSc library is not in $PETSC_DIR/lib, it is in
> $PETSC_DIR/$PETSC_ARCH/lib.
> Have I messed something up in my PETSc config so that the PETSc.pc file
> is not quite right?
> - Adrian
> Dr Adrian Croucher
> Senior Research Fellow
> Department of Engineering Science
> University of Auckland, New Zealand
> email: a.croucher at auckland.ac.nz
> tel: +64 (0)9 923 4611
