[petsc-users] Failure of MUMPS
David Knezevic david.knezevic at akselos.com
Fri Oct 5 20:22:17 CDT 2018
On Fri, Oct 5, 2018 at 9:16 PM Mike Wick <michael.wick.1980 at gmail.com>
wrote:
> Hi Hong:
> There is no explicit error message actually. The solver converge in 0
> iteration and returns an nan number. Looks like a zero pivoting problem.
> Mike
I use MatMumpsGetInfo
<https://www.mcs.anl.gov/petsc/petsc-current/docs/manualpages/Mat/MatMumpsGetInfo.html>
to
get error info returned by MUMPS, e.g.
PetscInt info_1;
MatMumpsGetInfo(pc_mat, 1, &info_1);
Then you can check the value of info_1 to get error diagnostics. One error
that I run into sometimes is when info_1 is -9, in which case I increase
icntl_14 and try again.
Best,
David
> On Fri, Oct 5, 2018 at 6:12 PM Zhang, Hong <hzhang at mcs.anl.gov> wrote:
>> Mike:
>>> Hello PETSc team:
>>> I am trying to solve a PDE problem with high-order finite elements. The
>>> matrix is getting denser and my experience is that MUMPS just outperforms
>>> iterative solvers.
>>> For certain problems, MUMPS just fail in the middle for no clear reason.
>>> I just wander if there is any suggestion to improve the robustness of
>>> MUMPS? Or in general, any suggestion for interative solver with very
>>> high-order finite elements?
>> What error message do you get when MUMPS fails? Out of memory, zero
>> pivoting, or something?
>>  Hong
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181005/dc1d738c/attachment-0001.html>
