[petsc-users] PETSc/SLEPc: Memory consumption, particularly during solver initialization/solve
Thu Oct 4 05:49:25 CDT 2018
On Thu, Oct 4, 2018 at 4:43 AM Ale Foggia <amfoggia at gmail.com> wrote:
> Hello all,
> I'm using SLEPc 3.9.2 (and PETSc 3.9.3) to get the EPS_SMALLEST_REAL of a
> matrix with the following characteristics:
> * type: real, Hermitian, sparse
> * linear size: 2333606220
> * distributed in 2048 processes (64 nodes, 32 procs per node)
> My code first preallocates the necessary memory with
> *MatMPIAIJSetPreallocation*, then fills it with the values and finally it
> calls the following functions to create the solver and diagonalize the
> matrix:
> EPSCreate(PETSC_COMM_WORLD, &solver);
> EPSSetOperators(solver,matrix,NULL);
> EPSSetProblemType(solver, EPS_HEP);
> EPSSetType(solver, EPSLANCZOS);
> EPSSetWhichEigenpairs(solver, EPS_SMALLEST_REAL);
> EPSSetFromOptions(solver);
> EPSSolve(solver);
> I want to make an estimation for larger size problems of the memory used
> by the program (at every step) because I would like to keep it under 16 GB
> per node. I've used the "memory usage" functions provided by PETSc, but
> something happens during the solver stage that I can't explain. This brings
> up two questions.
> 1) In each step I put a call to four memory functions and between them I
> print the value of mem:
Did you call PetscMemorySetGetMaximumUsage() first?
We are computing https://en.wikipedia.org/wiki/Resident_set_size however we
can. Usually with getrusage().
>From this (https://www.binarytides.com/linux-command-check-memory-usage/),
it looks like top also reports
paged out memory.
   Matt
> mem = 0;
> PetscMallocGetCurrentUsage(&mem);
> PetscMallocGetMaximumUsage(&mem);
> PetscMemoryGetCurrentUsage(&mem);
> PetscMemoryGetMaximumUsage(&mem);
> I've read some other question in the mailing list regarding the same issue
> but I can't fully understand this. What is the difference between all of
> them? What information are they actually giving me? (I know this is only a
> "per process" output). I copy the output of two steps of the program as an
> example:
> ==================== step N ====================
> MallocGetCurrent: 314513664.0 B
> MallocGetMaximum: 332723328.0 B
> MemoryGetCurrent: 539996160.0 B
> MemoryGetMaximum: 0.0 B
> ==================== step N+1 ====================
> MallocGetCurrent: 395902912.0 B
> MallocGetMaximum: 415178624.0 B
> MemoryGetCurrent: 623783936.0 B
> MemoryGetMaximum: 623775744.0 B
> 2) I was using this information to make the calculation of the memory
> required per node to run my problem. Also, I'm able to login to the
> computing node while running and I can check the memory consumption (with
> *top*). The memory used that I see with top is more or less the same as the
> one reported by PETSc functions at the beginning. But during the
> inialization of the solver and during the solving, *top* reports a
> consumption two times bigger than the one the functions report. Is it
> possible to know from where this extra memory consumption comes from? What
> things does SLEPc allocate that need that much memory? I've been trying to
> do the math but I think there are things I'm missing. I thought that part
> of it comes from the "BV" that the option -eps_view reports:
> BV Object: 2048 MPI processes
>   type: svec
>   17 columns of global length 2333606220
>   vector orthogonalization method: modified Gram-Schmidt
>   orthogonalization refinement: if needed (eta: 0.7071)
>   block orthogonalization method: GS
>   doing matmult as a single matrix-matrix product
> But "17 * 2333606220 * 8 Bytes / #nodes" only explains on third or less
> of the "extra" memory.
> Ale
experiments lead.
-- Norbert Wiener
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181004/34e3e565/attachment.html>
