[petsc-users] Parallel LU with MPIDENSE
Zhang, Hong hzhang at mcs.anl.gov
Tue Oct 2 10:26:25 CDT 2018
David :
Petsc does not support parallel LU. For dense matrix, you can use Elemental. See example
petsc/src/ksp/ksp/examples/tests/ex40.c
Hong
Hello,
i was trying to solve a linear system with a MPIDENSE matrix. I did
PC pc;
KSPGetPC(solver, &pc);
PCSetType(pc, PCLU);
KSPSetOperators(solver, a_petsc, a_petsc);
for some KSP solver and some Mat a_petsc. When i run the code sequentially (mpirun -n 1) it works, but once i start it in parallel it breaks with the error message
[0]PETSC ERROR: --------------------- Error Message --------------------------------------------------------------
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/linearsolvertable.html for possible LU and Cholesky solvers
[0]PETSC ERROR: Could not locate a solver package. Perhaps you must ./configure with --download-<package>
[0]PETSC ERROR: See http://www.mcs.anl.gov/petsc/documentation/faq.html for trouble shooting.
[0]PETSC ERROR: Petsc Release Version 3.9.3, unknown
[0]PETSC ERROR: Unknown Name on a arch-linux2-c-debug named manjaroDesktop by david Tue Oct  2 16:47:10 2018
[0]PETSC ERROR: Configure options --download-superlu_dist --download-parmetis --download-metis --download-ptscotch
[0]PETSC ERROR: #1 MatGetFactor() line 4328 in /home/david/lib/petsc/src/mat/interface/matrix.c
I recompiled petsc with the recommended options (and also trying some other options) but the error persists. on the linear solve table there is an X at the required solver package column for dense LU. What does it mean? On
https://www.mcs.anl.gov/petsc/petsc-3.2/docs/linearsolvertable.html
it says "PLAPACK". Did you deprecate it? What is the replacement?
Thanks
David Sommer
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181002/6a6753ee/attachment-0001.html>
