[petsc-users] Load dense matrices from hdf5
Sajid Ali
sajidsyed2021 at u.northwestern.edu
Fri Nov 30 17:30:24 CST 2018
I use spack variants which do the same thing behind the scenes. Thanks !
On Fri, Nov 30, 2018 at 5:10 PM Smith, Barry F. <bsmith at mcs.anl.gov> wrote:
> I assume you are ./configure PETSc with --with-scalar-type=complex? If
> so, the values in the file are the real and imaginary parts interlaced:
> That is
> r0 i0 r1 i1 .... where r0 is the first matrix entry's real part and i0
> is the first matrix imaginary part.
> Barry
> > On Nov 30, 2018, at 5:04 PM, Sajid Ali <sajidsyed2021 at u.northwestern.edu>
> wrote:
> > If the matrix is filled with complex numbers is each complex number
> stored as a sequences of doubles ? Or is it better to split the matrix into
> real/imaginary and store each part separately?
Sajid Ali
Applied Physics
Northwestern University
URL: <http://lists.mcs.anl.gov/pipermail/petsc-users/attachments/20181130/83157124/attachment.html>
