[petsc-users] Load dense matrices from hdf5
Smith, Barry F.
bsmith at mcs.anl.gov
Fri Nov 30 17:10:08 CST 2018
I assume you are ./configure PETSc with --with-scalar-type=complex? If so, the values in the file are the real and imaginary parts interlaced: That is
r0 i0 r1 i1 .... where r0 is the first matrix entry's real part and i0 is the first matrix imaginary part.
Barry
> On Nov 30, 2018, at 5:04 PM, Sajid Ali <sajidsyed2021 at u.northwestern.edu> wrote:
> If the matrix is filled with complex numbers is each complex number stored as a sequences of doubles ? Or is it better to split the matrix into real/imaginary and store each part separately?
